Tell
- Joined
- Mar 30, 2024
- Messages
- 1,070
- Likes
- 1,516
So what is the "real advantages" of MEHs? Controller directivity from a single point is what I gather, and also that there is advantages in lower distortion from the mid drivers according to some (but not according to OP it seems). And getting that down to 500Hzish is still way better than what most normal speakers do today isn't it? Or is it something inherently important with getting that very last bit controlled as well?I wouldn't use a smaller horn aperture than ~32" horizontally and ~19" vertically...because you're giving up the real advantages of doing MEHs by using a smaller horn mouth.
And building or buying a larger MEH mouth is bird feed in terms of added costs. Why not just find a way to integrate into your room? If your room REALLY IS too small for larger horn mouths--first consider using headphones instead. Your listening room is too small.
(I don't like to use any listening room less than 13'-14' in depth/horizontal dimensions because of problems of first bounce reflections from the back of the room that come too soon to the listeners.)
Right now, I can go out and buy a Celestion Axi2050 and put it on a K-402 horn, and not do any crossing to lower frequency drivers--and I get down to 200-250 Hz at the lower breakpoint frequency using only one amplifier channel and amplitude (SPL) EQ only--and it will perform just as well or better in-room for home hi-fi audio as an MEH built to go down to that frequency (or higher).
You don't need to have all the "MEH rigamarole" to get down to 200 Hz. The real reason why I think MEHs are used is because their horn apertures support at least horizontal polar control down to ~200 Hz or lower.
Before doing your "small MEH", first go listen to a full-range MEH that have been dialed-in--like the ones that Danley makes in its Synergy series...in a room that's treated for early reflections (less than 4 ms). Listen to the neutrality of sound quality that comes with flattened amplitude AND phase response...AND full-range directivity down to the room's calculated Schroeder frequency.
You'll never want to go back after hearing it.
Chris
And yeah sure I can buy either of those compression drivers you guys suggested and put it in a Klipsch horn, I'm sure it would sound awesome! ...or maybe I can't because I don't have that kind of money to spend and from a quick search I'm not sure I can even buy them "locally". Instead I'm aiming for all the drivers for around maybe a third of the cost of a single one of those Celestion drivers and then 3D print the horn it self, so it will be a fun DIY project for not too much money
About the size, yeah sure I can fit quite a large one in my 4x5meterish living room, but I have to consider WAF and also I personally wouldn't like a too big of a thing cluttering the space, that 55" TV is enough. But I'm aiming for maybe 40cm or maaybe 45cm at the widest, will still give nice directivity for most of the range.
I would LOVE to have a listen to a proper full range MEH yeah, but I have no idea where I would do that. You know anyone near Oslo with one?
