Meet the new Pataki Audio VST plugins
ppataki
Budapest
I have been using various DSP and DRC solutions (VST plugins mostly) in the last 10+ years
I have tried literally hundreds of those for various purposes like EQ-ing (both surgical for room correction and broad for room curves), crossover, plugin-chaining, tube distortion, dynamics processing, signal analysis, etc. etc.
While there are many excellent plugins already on the market I thought that it was high time for me to fill the void (at least from my perspective) for some specific, targeted use-cases that hopefully many others here and out there might benefit from
I have so far developed two VST3 plugins that I would like to share here
The first is called Metahost - it is a multichannel plugin chainer specifically developed to be used in Jriver where this is not possible out of the box for multichannel audio
There are plugins that can already do that (like Metaplugin) but I have been struggling with it massively since it is highly unstable in my environment
Metahost is lean and rock-solid, it can handle 16 channels (8 pairs) in two rows - so basically you can load 8 stereo plugins to manipulate 8 channel pairs (e.g. for a crossover setup) and you can add a second plugin for example to fine-tune each channel individually with an EQ (third row might be added in the future, if requested)
Just make sure to load the same plugin in a row since there is no latency compensation between the channel pairs
The other plugin is called Janus. It is a FIR linear phase crossover plugin. It has an LPF and a HPF component with a variable slope setting (from 1 to 48dB / octave in decimal steps)
It has three latency modes and each mode has a limit in terms of frequency and slope combination in order to keep the filters precise. If you increase the latency you can increase the slope and decrease the frequency accordingly. The main design goal here was to minimize the audible pre-ringing. With Janus in my setup I cannot hear pre-ringing at 80Hz using 48dB / octave slope when crossing between my woofers and subs - I invite you all to give it a try
Both of these plugins are available to download from my website: There are other plugins in the pipeline, I will keep on posting them here as they get created
These plugins are free of charge but donations are highly appreciated; if they help you (like they help me tremendously), please throw something in the tip jar.
Thank you and enjoy! :)
Want to share some good news: there are two new plugins available in the Pataki Audio plugin family!
The first new member of the Pataki Audio plugin family is called Voicing
It is essentially a 3-band equalizer with a low-shelf, a bell and a high-shelf filter
It is nothing special but then why bother? I wanted to create a very simple but perfect tool to apply 'room curves' to the signal in a very 'musical' manner
Hence I went for the Baxandall curves that in my experience are the best to use when trying to set the tonality to taste
I use this after Dirac Live's target curve is set to flat, so then I can sculpt the low end and the high end way easier and in a more versatile manner vs. in Dirac itself
The other newcomer is called Bitscope
It is very similar to Bitter but this one actually works with Jriver
It is showing how many bits are actually in use and if there is any sample clipping and intersample clipping
It works in a multichannel environment too, you can select which two channels to analyze
I am using it to check if my signal flow is 64-bit floating all across the plugin chain (turns out not, since Dirac Live Processor is only 32-bit...)
Additionally, both MetaHost and Janus are updated to have full 64-bit floating precision + MetaHost now supports 3 rows of plugins with working PDC latency reporting
There are 3 new plugins in the pipeline, stay tuned! ;)
And again, if you like them, donations are much appreciated!
Happy to announce two newcomers to the band!
Helios is a soft-saturating waveshaper that adds 300B SET inspired tube warmth (=distortion) to the signal. It has an even-dominant harmonic ladder, ~20 dB per even order at reference Drive, with some small odd companion harmonics.
Drive moves along the saturation curve, Mix blends wet and dry. Auto Gain compensates for level changes from Drive.
It is extremely straightforward to use + has a live harmonics display and near-zero latency
Chronos is a double-precision convolution engine for room correction, active crossover work, and audiophile playback. End-to-end 64-bit floating point including the FFT itself — not the float-FFT-with-double-buffer compromise most convolvers ship. Non-uniform partitioned, with user-controllable head block size, hot-swap WAV loading, multi-rate filter sets, and an honest latency readout.
It currently supports 2 channels but when combined with MetaHost it can be used in a multichannel environment too.
For this one, I recommend reading the manual about the multi-rate file naming convention (very simple logic)
Enjoy! :)
