Zathanann1122
- Joined
- Oct 9, 2026
- Messages
- 8
- Likes
- 2
Hello all!
Let me preface everything I'm going to write by asking for your understanding and patience. I'm well aware that I'm a beginner in audio so please correct me if anything I write is wrong. Second thing is - English isn't my native language so I may sometimes write in a hard to understand way. (Also I use a lot of parentheses like this), I know.
I've been thinking about upgrading my measuring setup (which consists of umik2) to anything better, as I'm thinking about designing speakers in the future (plus just having something better to correct in room stuff).
I don't want to recalibrate my mic every 2 years for it to stay accurate so I need a class 1 capsule (as far as I understand they are better in essentially every aspect, including the time they stay in calibration). I also want a good ADC for the new mic because I don't really trust that what they put inside of the usb ones is really that good (maybe I'm overreacting but I'd like to have peace of mind that it's good and I know how it measures). If I understand correctly both the DAC and ADC need to be in a single device (or connect 2 devices which support word clock) to avoid time drift.
For the mic I'm thinking about earthworks m23 gen2. Now, a couple questions:
1. Is the factory calibration (as in files I get) good enough for semi critical work? I've seen some threads about csl calibrated umik1 and 2 and the differences are pretty large especially in the higher frequencies.
2. If the factory cal is "meh" like with umiks, should I buy an already calibrated one from some store like the ones you can buy from csl? (preferably in EU)
3. Are there any accessories I should buy aside from a mic stand?
4. Is there anything better in that price/as good but cheaper?
Coming back to interfaces: I'd like to also be able to listen in high quality and have decent power for headphones. I've looked through many interfaces (motu, focusrite, rme, topping etc.) (mind you I haven't checked literally every model). ADI-2 Pro FS R and PRO EX have exactly what I want but are mad expensive. Topping e2x2 has mid DAC but decent ADC. Motu product are also a mixed bag. Is there anything besides RME that does what I want? It's just too expensive. If possible Id like to fit below 800$ for the interface. Maybe thers a way to make a do with 2 devices that would come out cheaper than the ADIs? EQ on them is also very nice although I know that's its probably entirely impossible to ALSO make that a requirement under 800$ (I know I can use software eq on my pc like apo/peace). I don't know what to think about Focusrite Scarlett gen4 lineup, because as far as I know it uses the CS43198 chip that can be problematic (see: https://www.audiosciencereview.com/...1xx-based-devices-a-comparative-review.63038/ ). I've also been searching for measurements of antelope zen quadro (is it good?).
That would be all for now. Any and every help is appreciated.
