I'm trying to measure an EAR 834P valve (tube) MM phono preamp.
It has very high gain: 49dB.
According to the Stereophile review, its input impedance is roughly 50 kOhms and output impedance is roughly 500 Ohms.
When doing a stepped sine THD vs level test in REW, to determine the input overload point, I'm getting some strange results.
1. Directly connected to the audio interface (input impedance specified at 12 kOhms - not sure if that is for balanced TRS or unbalanced TS, it can be used with both, I'm using TS - what difference would the two connection types make?):
* Overload point with a 1kHz sine wave is at 17mV (generated) which is 4.9V at the input.
2. Connected the 834P via the line in (24 kOhms input impedance) and tape out on a Rotel amp:
* Overload point is at 33mV generated, 8V at the audio interface input, which is the same as the measured input overload for this amp on its own, so difficult to tell if the phono stage is the limiting factor here - but obviously much better.
3. Connected the 834P via line in/tape out on another amp with a specified input impedance of 47 kOhms and specified overload point of 6.5V:
* Overload point is 16mV generated (4.5V at the interface input) - worse than the direct connection.
REW graphs below.
This is very odd to me: the results cannot be correlated to the input impedance seen by the phono stage, as the best result is at 22 kOhms, and both higher and lower impedances deliver much worse results.
What is going on here?
Generator level vs THD:
Input level vs THD:
REW graphs below.
Input level vs THD:
