measuring output of DAC/preamp with multimeter
olds1959special
Los Angeles, CA
My Xduoo TA-84 has a pre out function and I want to test the output voltage when the volume is all the way and it's on the low gain setting. I tried to play a 1khz sine tone at full volume generated by Audacity and measured the + and - of one of the RCA's with my multimeter on the V setting, but the reading kept changing and I'm not sure what I'm doing wrong. How do I do this?
oh it has a AC DC mode button
found the max output on low gain is too hot and by turning the volume down one notch it goes to 2.1V.
For rca 2v is fine, what's your issue?
Use a 60Hz sine wave (or ~200Hz if you suspect your DUT might roll off early).
Too high a frequency and you risk going outside the measurement range of your multimeter, resulting in low voltage readings.
You can use the REW Generator to export test tones in .WAV
thanks, I will try that, but specs for my multi meter say
Frequency:10 kHz
does that mean I'm okay?
Frequency:10 kHz
Probably?
You can check your multimeter's frequency response yourself by measuring voltages using a known good signal generator, e.g. a modern DAC:
for this use....true rms multimeter ;-) ( or test with 50 or 60hz)
