Measuring crosstalk cancellation (XTC) at my own ears: a small experiment in a real listening room
RaulFO
I've been developing NatAmbio, an open-source DSP project for spatial stereo reproduction using conventional loudspeakers. One of its components is a crosstalk cancellation (XTC) filter.
I've been listening to it for quite some time, and I enjoy the spatial presentation it produces. But there was a question I couldn't answer with any confidence: what is actually reaching my ears?
So I decided to buy a pair of inexpensive binaural microphones and find out.
1. A new pair of ears (well, almost)
These are my new Earsight binaural microphones, in the XLR version.
My intention was not to perform laboratory-grade measurements or obtain perfectly calibrated HRIRs. I wanted to characterize the acoustic transfer paths from my two loudspeakers to my two ears, in my normal listening room, with myself sitting in my usual listening position.
In a real living room, sitting on a sofa, it's surprisingly difficult to return to exactly the same position, perfectly centered between the loudspeakers and facing straight ahead. But that doesn't prevent us from making meaningful measurements and learning something valuable — perhaps even something a laboratory experiment might overlook: the laboratory is my own living room, and the ears being measured are my own.
I've also been working with Claude (Anthropic's AI assistant), which has helped me write the measurement and analysis scripts, process the results, and explore alternative XTC filter models. I'll mention it throughout this thread because it has played a substantial role in the experiments.
The measurements are real, the listening impressions are mine, and the interpretations remain open to discussion. Claude, meanwhile, has had to deal with a rather uncooperative experimental subject: me.
2. Looking at the impulse responses
I measured the binaural impulse responses using logarithmic sine sweeps and deconvolution, following the technique described in Angelo Farina's excellent paper:
Simultaneous Measurement of Impulse Response and Distortion With a Swept-Sine Technique
For each loudspeaker, both ears were recorded simultaneously, allowing me to obtain the four acoustic impulse responses of the stereo system.
I measured two configurations:
  • DRC: ordinary loudspeaker/room equalization using FIR filters generated with DRC-FIR, based on measurements made with a Behringer ECM8000 omnidirectional microphone.
  • XTC: exactly the same DRC correction, with NatAmbio's XTC filters enabled (XTC + DRC).
Here's a simple Audacity screenshot comparing the two measurements for the right loudspeaker.
The upper channel in each stereo pair channel is the left ear (contralateral when measuring from right speaker), and the lower is the right ear (ipsilateral).
Even visually, the reduction in the initial contralateral response is apparent, while the ipsilateral response remains broadly similar.
Of course, this is just a visual inspection of the waveforms, not a quantitative cancellation measurement. I simply wanted to look at the actual signals before moving on to more elaborate analysis.
3. How much crosstalk is actually reduced?
Here is one of the first results.
For each loudspeaker, the graph shows the frequency-dependent level difference between the contralateral and ipsilateral impulse responses, after applying time windows of 4 ms, 6 ms and 500 ms.
The windowed impulse responses are transformed into the frequency domain, and the plotted quantity is:
20 log10 (|H_contralateral(f)| / |H_ipsilateral(f)|)
In other words, this is interaural separation, expressed in dB. More negative values indicate a lower contralateral level relative to the ipsilateral one.
The green curves represent DRC alone; the purple curves represent XTC + DRC. The difference between the corresponding curves indicates the additional separation introduced by XTC, provided the ipsilateral response remains approximately unchanged.
The measurement window matters considerably. The shorter windows emphasize the direct sound and early arrivals, while the 500 ms window includes much more of the room response. Short windows also limit frequency resolution at low frequencies.
These are measurements from an ordinary domestic listening setup, not an anechoic chamber.
For now, I'll leave the results here. I've collected several sets of measurements, explored the repeatability of the results with changes in listening position, and experimented with different XTC filter designs.
I'll share some of those findings in subsequent posts, along with my own listening impressions — keeping the acoustic measurements and subjective observations clearly separate.
It's been an enjoyable experiment, and a surprisingly educational one.
Same sofa, same loudspeakers, different measurements​
Let's look at the first three measurement sessions, all taken on October 30.
All three were performed in my usual listening position, with the same loudspeakers, microphones and XTC configuration, but at different moments. I simply sat down again and repeated the measurements.
If we were measuring the SINAD of a DAC, we would expect almost perfectly repeatable results.
But we are not measuring a DAC. We are measuring an acoustic system that includes a human being sitting on a sofa.
And human beings are not particularly good at returning to exactly the same position, facing precisely the same direction.
Here are the three measurements, in chronological order.
Measurement 01
Measurement 02
Measurement 03
The differences are quite remarkable, particularly between the first measurement and the following two.
At first glance, this might suggest poor measurement repeatability. But there is another possible explanation: perhaps we are not measuring exactly the same acoustic geometry.
What changed?​
I asked Claude, which has been helping me with the Python measurement and analysis scripts, to examine the binaural impulse responses and estimate the arrival times and apparent loudspeaker angles.
Here is a summary of its analysis:
Parameter010203
Estimated L speaker azimuth11°18°16°
Estimated R speaker azimuth23°17°18°
L speaker, onset ITD+109 µs+169 µs+151 µs
R speaker, onset ITD−221 µs−167 µs−177 µs
L speaker, ITD below 1.5 kHz+139 µs+222 µs+191 µs
R speaker, ITD below 1.5 kHz−274 µs−192 µs−213 µs
The azimuths are approximate estimates derived from the ITDs using a Woodworth–Kuhn head model, not independent measurements of my head orientation.
Claude's interpretation was:
In measurement 01, your head was turned approximately 6 degrees to the left. Measurements 02 and 03 are much closer to a centered listening position.
And I think it is probably right!
I remember taking that first measurement rather casually, without paying much attention to my exact orientation. I hadn't even noticed that I was slightly turned.
The second and third measurements show much more consistent estimates, with both loudspeakers appearing approximately 16–18° from the forward direction.
And what happened to crosstalk cancellation?​
Claude also calculated the additional cancellation relative to DRC alone, using the short direct-sound window.
Some of the results are particularly interesting:
Speaker / session500 Hz–1 kHz1–2 kHz2–4 kHz4–8 kHz
L — 01+4.4 dB+1.5 dB−4.5 dB−2.6 dB
L — 02+6.8 dB+13.5 dB+4.5 dB+1.5 dB
L — 03+6.5 dB+12.7 dB+2.7 dB−0.1 dB
R — 01+2.3 dB+7.2 dB−1.6 dB−3.6 dB
R — 02+6.4 dB+2.8 dB+3.4 dB+0.2 dB
R — 03+8.3 dB+5.4 dB+3.0 dB+2.3 dB
Positive values indicate improved interaural separation with XTC; negative values indicate that separation became worse in that frequency band.
These are band-averaged results for the direct-sound window, not maximum cancellation values at individual frequencies.
Notice what happens to the left loudspeaker between 1 and 2 kHz: from just 1.5 dB in measurement 01 to approximately 13 dB in measurements 02 and 03.
That's an enormous difference for measurements taken in what I would casually describe as the same listening position.
But apparently, my idea of the same position is not sufficiently precise for acoustic measurements!
Does this make the measurements unreliable?​
I don't think so. It means we need to be careful about what we are measuring and what conclusions we draw.
For a fixed listening geometry, the acoustic transfer paths can be treated as approximately linear and time-invariant (LTI). An impulse response is therefore a very useful description of that particular configuration.
But when I move or rotate my head, the geometry changes, and so do the transfer functions.
The measurements are not necessarily inaccurate. The system being measured is not perfectly repeatable because the listener's position is not perfectly repeatable.
This distinction matters.
We can characterize a particular position, compare different positions, and investigate which XTC properties remain reasonably stable across them. But quoting a cancellation figure to tenths of a decibel without considering the listening geometry would give a misleading impression of precision.
And this is exactly why I find measuring in a real living room so interesting.
A surprisingly forgiving listening experience​
There is something important I should add from my own listening experience.
When listening to music, I don't need to sit perfectly centered or keep my head pointing straight ahead. I can turn my head slightly or move a little away from the symmetry axis, and the wide spatial presentation remains remarkably stable. Only with larger movements or rotations do I begin to notice a significant change.
This is particularly interesting because the measured crosstalk cancellation can vary considerably with small changes in listening geometry.
In other words, the sensitivity of the acoustic measurements does not necessarily translate into an equally strong sensitivity of the perceived spatial effect.
This is only my subjective observation, not a controlled psychoacoustic result. But it is an important part of the experiment: a system that produces impressive cancellation figures at one precisely defined position is not necessarily more enjoyable or more useful than one that provides a convincing spatial presentation under normal listening conditions.
What about listening?​
There is one more consideration that I want to keep in mind throughout these experiments.
Measured cancellation and perceived spatial performance are related, but they are not the same thing.
My ears are part of the measurement apparatus, but they are also the final judges of the listening experience.
The measurements must make physical sense, and my subjective impressions must remain consistent with what the measurements can reasonably explain. Neither should be used as a substitute for the other.
I already had a particular listening impression before starting these experiments: NatAmbio produced a very wide soundstage, but the image towards the right was more stable and better anchored than the image towards the left.
The binaural measurements eventually helped me investigate that asymmetry.
In the next posts I'll describe how this led to independent XTC parameters for the left and right loudspeakers, and later to a revised, smooth frequency-dependent XTC model.
And, of course, I'll also discuss what I actually heard after making those changes.
For now, the first lesson is simple:
When measuring crosstalk cancellation in a domestic listening room, don't forget that the listener is part of the acoustic system.
Unfortunately, this particular listener has a rather annoying habit of moving his head.
Claude is beginning to discover that too. :)
Interesting work, RaulFO.
One thing I’d be curious to see is a similar in-ear measurement using a short (~5 s) excerpt from the Sheffield Lab channel-test track — specifically the “Channel test… Left channel” clip (left channel only). Or any other audio clip of your suggestion.
I’m wondering how the resulting frequency-domain graph of the contralateral residual would look compared with the windowed impulse-response separation plots you’ve already shown.
I did something along those lines with a practical listening sample here:
https://www.audiosciencereview.com/...d-colouration-measurements-–-ctxmatrix.71575/
Would be interesting to compare the two approaches on the same type of short speech stimulus.
Any BACCH, Soundpimp, Camilo and others can also share the graphs or even a WAV file can be useful.
ST
I don't understand this.
To me "crosstalk" means an unintentional pickup of a signal in one channel into another channel.
In an amp or DAC, this is typically miniscule and well below what you can hear.
In a recording, you may have some instruments panned left or right and some centered, quite intentionally.
So, is this crosstalk cancellation idea just about reducing the volume of centre-panned sounds, and is this not a many decades-old "stereo expansion" effect?
https://www.audiosciencereview.com/forum/index.php?threads/crosstalk-cancellation-xtc-attenuation-and-colouration-measurements-–-ctxmatrix.71575/
Hi STC,
Thanks for your suggestion! I've been reading your CTXMatrix measurements with interest. I think your experiment connects very nicely with something I was planning to discuss in this thread: the practical use of the Linear Time-Invariant (LTI) model.
Perhaps it's worth introducing the concept briefly, because it's fundamental to understanding what an impulse response actually tells us.
A Linear Time-Invariant system is one that obeys two basic properties: linearity (superposition) and time invariance. In simple terms, its response to a signal can be described by a fixed relationship that doesn't depend on when the signal is applied.
The remarkable thing is that a large part of our audio reproduction chain, from the digital audio processing to the loudspeakers, the room and our ears, can be approximated very well by an LTI system, provided the operating conditions and listening geometry remain reasonably stable.
Of course, real audio systems are not perfectly linear. Loudspeakers, amplifiers and other components introduce nonlinear effects, commonly referred to as distortion. However, under normal operating conditions, these effects are often much smaller than the dominant linear response. Time-varying processing or moving the listener can also violate the LTI assumptions.
Both ordinary stereo acoustic crosstalk and frequency-response equalization are particularly well suited to LTI modelling. XTC filters are themselves designed to modify these linear acoustic transfer paths.
And this brings us to the impulse response.
An LTI system can be completely characterized by its impulse response, usually denoted by h(t). Its Fourier transform gives us the frequency response, including both magnitude and phase.
In audio DSP, we commonly work directly with impulse responses as digital filters, particularly FIR filters for equalization, convolution reverb or XTC.
Once we know the impulse response, we can predict the output for virtually any input signal using convolution.
In that sense, convolution becomes a very useful kind of LTI simulator.
For example, since I've measured the four acoustic transfer paths from my two loudspeakers to my two ears, I can take your Sheffield Lab speech excerpt — or a recording of an opera, for that matter — and convolve it with those measured impulse responses.
The result is a predicted binaural recording of what would reach my ears in my own listening room, at the precise listening position where the measurements were taken.
I could even listen to that binaural reconstruction through in-ear headphones, provided their own acoustic response is suitably accounted for, and obtain an approximation of the original listening experience.
And here's the particularly useful part: I can also introduce different XTC filters into that LTI model and predict their effects without making new acoustic measurements.
This is why I find measured impulse responses so powerful. They don't just describe how the system responded to a particular test signal. They provide a model that can be used to investigate its response to many other signals and processing configurations.
Your five-second speech experiment and my impulse-response measurements are therefore not fundamentally different acoustic phenomena. They are two ways of observing the response of the same kind of system, although the analysis windows and spectral estimators can lead to different representations.
I'll develop this model further in a forthcoming post, including some practical examples of using convolution to explore XTC configurations without repeatedly measuring the acoustic system.
I think this is one of the most interesting aspects of the whole experiment!
There is one important consequence of all this.
Under the LTI assumption, the acoustic behaviour of the system does not depend on whether we excite it with an impulse, a logarithmic sweep, a speech recording or a piece of music. Provided the system remains unchanged, all these signals are governed by the same transfer functions.
Therefore, if we estimate the transfer functions correctly, the underlying frequency-dependent effect of XTC should be the same regardless of the excitation signal. Different measurement and analysis methods may, of course, produce different estimates.
The real advantage of measuring impulse responses is not that they reveal a different acoustic reality, but that they give us much greater flexibility for subsequent analysis.
For example, consider the time windows used in my first graphs: 4 ms, 6 ms and 500 ms.
With an impulse response, I can isolate the first arrivals, include progressively more room reflections, and examine how the measured interaural separation changes with the observation window.
Doing the equivalent analysis directly on a five-second speech recording is considerably more complicated, because the direct sound and the reflections overlap throughout the recording.
And this distinction matters for XTC. Measuring the first 4 ms is not the same as measuring the response over 500 ms. The resulting cancellation figures can be very different, because they describe different portions of the acoustic response.
How these physical differences relate to what we actually hear is another, much more complicated question. It requires combining acoustic measurements with listening experiments rather than assuming that a particular cancellation figure directly predicts the perceived spatial effect.
That's something I'll return to later in this thread.
Good question! Here we're talking about acoustic crosstalk, also known as interaural crosstalk, rather than electrical crosstalk between audio channels.
With conventional stereo loudspeakers, sound from the left speaker reaches both ears, not just the left one. Similarly, sound from the right speaker reaches both ears.
The signal reaching each ear is therefore a combination of the acoustic contributions from both loudspeakers, including their respective delays, levels and frequency responses.
Crosstalk cancellation (XTC) uses additional, carefully filtered signals sent through the loudspeakers to reduce these unwanted contralateral contributions at the listener's ears.
The objective is to reproduce the intended left and right signals more independently at the two ears, while preserving the desired ipsilateral responses as much as possible.
This is quite different from conventional stereo widening based on manipulating the sum and difference (L+R / L−R) signals. XTC attempts to compensate for the physical acoustic paths between the loudspeakers and the ears.
It is not intended to reduce the volume of centre-panned sounds. Ideally, a centrally located phantom image should remain centred, while the reproduction of interaural spatial cues can be improved.
Of course, the cancellation is imperfect and depends on frequency, listening geometry and room acoustics. That's precisely what I'm investigating with these binaural measurements.
Reactions: FTB
I know how stereo works, but isn't music mixed to sound as intended on typical speakers in typical rooms? If not, surely that implies recording and mastering engineers are not able to do their jobs properly? If I want binaural, I can use headphones, but I much prefer speakers, in rooms.
I think we're mixing several different concepts here.
First, nobody is suggesting that recording or mastering engineers are doing their jobs incorrectly. Conventional stereo recordings are generally produced and monitored for conventional stereo reproduction, and that is perfectly legitimate.
But crosstalk cancellation (XTC) is a reproduction technique, not a recording or mixing technique.
It attempts to compensate for the acoustic paths by which each loudspeaker reaches both ears. Whether that produces a more convincing spatial presentation depends on the recording, the reproduction system and the listener.
Second, listening through headphones is not necessarily binaural reproduction. Headphones provide independent signals to the two ears, but ordinary stereo recordings do not automatically contain the appropriate binaural spatial cues. Proper binaural reproduction involves a different set of requirements.
And third, XTC and binaural recording are two different concepts, even though both involve the signals reaching our ears. XTC can be applied to conventional stereo recordings without requiring them to have been recorded binaurally.
I've discussed this distinction, and my own approach to XTC, in another thread:
https://www.audiosciencereview.com/...-xct-should-be-done.73583/page-3#post-2696557
I'm not claiming that XTC is inherently superior to conventional stereo, or that everyone should prefer it. My purpose in this thread is much simpler: to measure what XTC actually does at my ears, understand its limitations, and compare those measurements with my own listening experience.
Whether someone prefers conventional stereo, headphones or XTC is a separate question.
Ahhh… you are like me. With XTC, you are listening to what sounds like binaural with loudspeakers. It makes your stereo to sound like binaural.
@RaulFO
I understand your position.
Could you at least share the left-channel impulse response you used? I can then post a measurement and audio capture of the playback so we can see whether what the IR predicts actually translates to what we hear. That would be interesting.
ST
I'm failing to see the use of this!
I'll skip the thread to save everyone time and keyboard wear. :)
Think of crosstalk cancellation as "headphones at a distance". You get some of the benefits of headphones, along with the benefits of loudspeakers. Headphones sound remarkably clear, part of it is removal of room influence as well as very little crosstalk. But they do not sound "external", the sound always feels confined to your head. And headphones tuned for a test dummy may not match your HRTF so everyone hears a different result. As I understand it, XTC attempts to restore the clarity of headphones with the externalization of loudspeakers.
Using convolution to predict XTC performance — and checking if it actually works​
In my previous posts I introduced the idea of treating the acoustic system as approximately LTI (Linear Time-Invariant).
Now comes the fun part: can we use our measured impulse responses to predict what a different XTC configuration would do, without measuring it?
This was particularly interesting to me because I had already noticed something while listening to NatAmbio: the soundstage was very wide, but the image towards the right was better defined and more stable than the image towards the left.
Could I understand why? And, more importantly, could I improve it?
I worked with Claude to develop Python scripts for this investigation. The idea was simple: use convolution to explore the XTC parameters, identify promising configurations, and only then make new acoustic measurements to see whether the predictions were correct.
1. First, does the LTI model actually work?​
My listening system uses NatAmbio, a convolution engine that combines loudspeaker room correction (DRC), subwoofer processing and crosstalk cancellation (XTC).
For these experiments I used:
  • Earsight in-ear binaural microphones, with their relative response and input levels characterized beforehand.
  • Exponential sine sweeps from 20 Hz to 20 kHz, 12 seconds long, at 48 kHz.
  • A second instance of the audio engine reproducing the same front-channel processing as my normal listening configuration.
  • Two loudspeakers at approximately ±20°.
Each measurement sequence was automated: left DRC, right DRC, left XTC+DRC and right XTC+DRC, without deliberately changing my position between takes.
The first question was whether the XTC responses could be reconstructed from the DRC-only measurements.
For each ear, the predicted response is obtained by convolving the measured DRC responses with the appropriate XTC filters and adding the two contributions:
L_xtc(ear) = direct * L_drc(ear) + cross * R_drc(ear)
R_xtc(ear) = direct * R_drc(ear) + cross * L_drc(ear)
Here, * denotes convolution.
The DRC measurements already contain the acoustic behaviour of the loudspeakers, room, head, ears and microphone capsules. I used the actual XTC filters extracted from the audio engine, rather than merely assuming that my mathematical implementation generated the correct filters.
The extracted filters agreed with the Python model to within approximately ±0.1 dB above 300 Hz.
And here came the first pleasant surprise: the predictions worked remarkably well.
Across three listening positions, without fitting or time-aligning the predicted responses to the measured XTC responses:
  • Correlations between predicted and measured responses were approximately 0.93–0.99, with the best lag at 0 ±0.1 samples.
  • At the contralateral ear, correlation with the actual XTC response improved from 0.76–0.93 using DRC alone to 0.94–0.985 using the convolution prediction.
  • Average cancellation over 0.5–8 kHz was generally predicted within approximately 1–3 dB.
Even the measurement in which I had inadvertently turned my head by about 6° was informative. In the 2–8 kHz region, the model predicted that XTC would actually make separation worse: approximately −3.5 / −3.0 dB, compared with measured values of −4.5 / −2.6 dB.
In other words, the model could predict an unsuccessful result too!
There were limitations, of course. Below approximately 500 Hz, the short measurement window and differences in low-frequency processing became important. Above 8 kHz, small movements of my head between measurements could produce substantial differences. The depths of narrow spectral notches also differed by several dB.
But over the main frequency range of interest, the agreement was encouraging.
Figure 1 — Original symmetric XTC: prediction versus measurement
Green represents measured DRC-only separation, purple the predicted XTC response, and black the actual measured XTC response in the 4 ms window.
The important point is not that the curves match perfectly. They don't. But their overall behaviour is sufficiently similar to make the model useful.
And now I had a very convenient experimental tool: I could test many XTC configurations using the same measured acoustic geometry, without getting up from the sofa!
There is a small detail worth mentioning here.
Long before buying the binaural microphones, I had already considered that real listening environments might require asymmetric XTC filters. In July 2026, I developed and documented a mathematical extension of NatAmbio XTC for non-symmetric acoustic configurations.
The important point is that the loudspeakers don't necessarily need to be placed asymmetrically. Even with a geometrically symmetric arrangement, the acoustic transfer paths may differ because of the room, the listener's position or anatomy.
So the asymmetric XTC model was already there. What I didn't know was whether my own listening setup would actually benefit from it.
The binaural measurements finally gave me a good reason to find out.
2. The mystery of the asymmetric soundstage​
My original XTC used the same parameters for both sides, including a nominal crosstalk delay of 180 µs.
But the measurements were telling a different story.
The left-speaker cancellation was reasonably effective, while the right-speaker cancellation was clearly weaker above 1 kHz and practically absent in the 4–8 kHz band.
This was interesting because it was consistent with what I had been hearing: the image towards the right was better anchored than the image towards the left.
The measured effective delays also suggested an asymmetry. One side was close to the configured 180 µs, while the other was approximately 148–156 µs.
Of course, I cannot attribute this difference exclusively to my anatomy. Loudspeaker geometry, head orientation, microphone positioning and room acoustics can all contribute.
But I didn't need to identify the exact physical origin of every difference to ask a practical question:
What if the two sides simply used different XTC parameters?
3. An unexpected result from the sensitivity study​
This is where convolution became particularly useful.
Claude helped me explore the response of the system to changes in XTC parameters, starting with the attenuation of the cancelling signal.
My first intuition was straightforward: if one side cancels poorly, perhaps it needs a stronger cancelling signal.
Well... not necessarily!
Increasing the cancelling signal improved one side but made the other worse, reducing its average cancellation from approximately +3.1 to +1.3 dB.
The explanation was phase.
If the cancelling signal has a phase error, increasing its amplitude does not necessarily reduce the residual. For a simple narrowband model, the optimum cancelling amplitude is proportional to the unwanted signal amplitude multiplied by the cosine of the phase error.
So adding more cancellation signal can actually increase the unwanted residual!
The lesson was simple: correct the timing before trying to correct the level.
I then explored the timing independently for each side.
Reducing the right-side delay from 180 to 150 µs produced a substantial improvement, particularly at higher frequencies. Only after correcting that delay did increasing the cancelling signal become beneficial.
The configuration I selected for the first practical test was:
ParameterLeft XTC pathRight XTC path
Delay180 µs150 µs
Attenuation parameter10 dB10 dB
The model predicted approximately +1.6 dB additional average cancellation for the left side and +2.4 dB for the right, with improved interaural correlation metrics, limited ipsilateral coloration (within approximately 2 dB), and an additional headroom requirement of about 0.8 dB.
Promising enough to get the microphones out again!
4. Back to the real world: measuring the prediction​
I made a new binaural measurement with the asymmetric configuration.
To avoid confusing parameter changes with differences in head position, I also calculated the predictions for both symmetric and asymmetric XTC using the DRC measurements from this same session.
Here are the results, averaged over 0.5–8 kHz using a 4 ms direct-sound window.
ConfigurationLeft speakerRight speaker
Original symmetric XTC — predicted+6.6 dB+2.6 dB
Asymmetric XTC — predicted+7.7 dB+4.3 dB
Asymmetric XTC — measured+8.2 dB+5.1 dB
The prediction wasn't exact, but it was certainly useful.
Correlation between predicted and measured impulse responses was approximately 0.954–0.996, with relative lag between 0 and −0.3 samples.
The right side, previously problematic, now showed measurable cancellation in the 4–8 kHz band, improving from approximately −1.6 to +4.8 dB in this comparison.
The early interaural cross-correlation measure, IACC_E3 (0–80 ms), also decreased from approximately 0.45 with DRC alone to 0.21 / 0.32 with XTC.
Figure 2 — Measured performance with asymmetric XTC
Figure 3 — Predicted performance, with the actual measurement overlaid
For me, this was the most satisfying part of the experiment.
I had identified a problem, explored possible solutions using a model based on real acoustic measurements, selected a configuration, and then physically measured the result.
The model did not need to reproduce every little spectral detail to be useful. It needed to predict the important trends well enough to guide the next experiment.
And it did.
5. What happened afterwards?​
This was only the beginning.
I've since used the same predict-then-measure procedure to explore the frequency dependence of the XTC attenuation, alternative smooth spectral models, high-frequency fading and a further adjustment of the right-side delay from 150 to 140 µs.
In subsequent measured checks, differences in average cancellation between prediction and measurement were typically around 0.3–1.5 dB. The best measured session so far has exceeded +7.5 dB on both sides.
I'll describe those changes separately, because they introduced some interesting questions about filter complexity, sensitivity and robustness.
There are also important limitations to remember.
Head posture has a major influence on the results. Across sessions, cancellation can vary by as much as approximately 5 dB, which is larger than many of the improvements obtained by adjusting individual parameters.
That's why I prefer comparing candidate filters by convolution using the same measured DRC responses, rather than comparing two physical measurements taken after getting up and sitting down again.
Also, the left/right timing asymmetry cannot yet be assigned to a single cause. A 30 µs delay corresponds to only about 10 mm of acoustic path length, so microphone positioning and small geometrical differences matter.
And finally, these results describe what reaches my ears, not necessarily what I perceive.
That distinction is fundamental. Acoustic cancellation, soundstage width and spatial stability are related, but they are not interchangeable quantities. Listening tests are needed to understand the perceptual consequences.
For now, however, I think the main result is already interesting:
A few measured impulse responses can become a remarkably useful experimental model, allowing us to investigate XTC configurations by convolution and reserve physical measurements for confirmation.
Not a perfect simulator. Not an anechoic laboratory.
Just a practical engineering tool, using my own loudspeakers, my own room and my own ears.
And that, for an amateur experiment conducted on a sofa, is quite satisfying. :)
What does XTC actually sound like? Some personal observations​
After discussing the measurements, I'd like to share something more subjective: how I actually perceive the spatial presentation produced by XTC.
This is not a controlled psychoacoustic study. It's simply my experience after years of listening to and experimenting with NatAmbio.
I think we sometimes make a mistake when describing XTC as "listening to headphones through loudspeakers".
Headphones, conventional stereo loudspeakers, multichannel systems, binaural reproduction and XTC all offer different spatial listening experiences. Each has its own characteristics, and I don't see much point in declaring one universally superior to the others.
XTC, at least as I experience it, has a spatial character of its own.
The phantom center and acoustic crosstalk​
In conventional stereo reproduction, each loudspeaker reaches both ears. These four acoustic paths interact, producing frequency-dependent interference patterns.
A particularly interesting case is the phantom center, where the same signal is reproduced by both loudspeakers.
The acoustic contributions interfere at each ear, producing comb-filtering effects that depend on frequency and listening geometry. This is a well-known issue, discussed for example in Earl Vickers' paper Fixing the Phantom Center: Diffusing Acoustical Crosstalk.
This doesn't mean that conventional stereo cannot produce an excellent phantom center. Of course it can. But its acoustic behaviour is not equivalent to that of a real sound source located directly in front of the listener.
One of the things I particularly enjoy with XTC is the clarity and stability of the central image.
In my listening setup, centrally located voices and instruments seem remarkably well anchored. As sources move towards the lateral extremes, their apparent positions gradually become less precise.
And here comes the interesting part: those lateral extremes can extend far beyond the physical positions of my loudspeakers.
Wide soundstage, but not equally precise everywhere​
My loudspeakers are placed at approximately ±20°.
Nevertheless, with XTC I frequently perceive a much wider frontal soundstage, sometimes extending to approximately ±60°, depending on the recording.
These angles are subjective estimates, not measured source-localization results.
What I find particularly interesting is that the soundstage doesn't behave like a collection of virtual loudspeakers positioned at fixed angles.
Instead, I perceive a very stable central region, followed by progressively wider and more diffuse lateral regions.
The extreme positions are not necessarily the most precisely localized ones.
In other words, soundstage width and localization precision are not the same thing.
This distinction became especially important during my recent experiments. Some XTC adjustments improved the stability of lateral sources without noticeably increasing the overall soundstage width.
Anticorrelation and the extreme lateral image​
There is another aspect of stereo recordings that I find particularly interesting.
Hard panning is not the only way to obtain a very wide perceived image.
The relationship between the phases of the two stereo channels also matters. In particular, strongly anticorrelated signals can produce unusual lateral or diffuse spatial impressions when reproduced through an XTC system.
In my listening experience, combinations of panning and anticorrelation can produce some of the most extreme apparent positions in the frontal soundstage.
These impressions are often less precisely localized than ordinary correlated sources, but they contribute greatly to the sensation of spaciousness.
And this observation became important in the development of another NatAmbio component: the Natural Ambient Extractor (NAE).
What I call the ambient aura​
NAE uses a PCA-based decomposition of the stereo signal into two stereo components, derived from the dominant and secondary directions of the signal distribution.
One component is internally correlated, while the other is internally anticorrelated. The two components are decorrelated from each other by the decomposition.
The mathematical development is described here:
NatAmbio — Natural Ambient Extractor (NAE)
The particularly interesting component is the anticorrelated one.
When reproduced through XTC, I often perceive it as a very wide, rather diffuse spatial field surrounding the more clearly localized musical sources.
I've come to call this perceptual effect an ambient aura.
It is not necessarily a collection of identifiable sound sources, nor does the mathematical decomposition prove that the extracted material is exclusively acoustic ambience. It is a particular way of organizing the spatial information already present in a stereo recording.
With conventional stereo loudspeaker reproduction, I find this aura much more spatially constrained, generally remaining around the region defined by the physical loudspeakers.
With XTC, it can extend considerably further.
This is one of the reasons I became interested in combining ambient extraction with crosstalk cancellation in NatAmbio.
Not headphones, not conventional stereo​
So, when someone describes XTC as simply making loudspeakers behave like headphones, I feel that something important is being lost.
Yes, XTC attempts to reduce acoustic crosstalk and thereby provide greater independence between the signals reaching the two ears.
But the resulting listening experience is not necessarily equivalent to ordinary stereo headphone listening, nor is it automatically equivalent to proper binaural reproduction.
For me, it is a different spatial presentation: a particularly stable center, a wide frontal scene, increasingly diffuse lateral extremes and, with suitable recordings, a remarkable sensation of ambient spaciousness.
Of course, all this depends on the recording, the XTC implementation, the loudspeaker geometry, the room and the listener.
And I wouldn't claim that everyone will perceive it as I do.
What I'm trying to understand with these binaural measurements is the relationship between this subjective experience and the acoustic signals actually reaching my ears.
The measurements have already taught me quite a lot about cancellation, asymmetry, frequency response and sensitivity to head position.
But they have also reminded me that a few additional decibels of measured cancellation do not necessarily produce a correspondingly dramatic change in the listening experience.
That's why I find it important to keep both aspects of the experiment: measuring and listening.
And ultimately, the reason I continue developing NatAmbio is quite simple.
I enjoy the way music sounds through it. :)
I find XTC causes a feeling of slight pressure difference between ears.
I guess thats a sign its working!
I do like the effects of XTC and have it on most of the time.
Interesting, because I experience that, too. I've been wondering if it's an issue with how my XTC, itself, is configured or if it is some kind of room node(s) that are excited right at my listening position. I find it slightly annoying and would prefer that it not exist.
THe pressure is due to sensing out of phase signal exceeding the cancellation. If possible try to move a few inches forward or backward to see if it disappears.
ST
Hi STC,
Absolutely correct. I discovered on my own, yesterday, that I had neglected to put in the XTC delay on the "dry" channels as well as the "wet channel. Having both on my calculated 21 sample delay seems to have solved this issue for me---plus things definitely sound cleaner!
How much can the frequency-dependent ILD curve improve XTC?
After adjusting the left/right asymmetry of my XTC model, I became curious about something else: how much could I improve the cancellation simply by changing the frequency dependence of the ILD?
My model uses a very simple logarithmic relationship:
ILD(f) = alpha * 10 * log10(f/1000 + 1) * sin(azimuth)
Here, alpha controls the shape of the frequency dependence. Interestingly, alpha and azimuth are not independent in this expression: only their product matters.
So I asked Claude to sweep alpha from 1.0 to 3.0, keeping all other parameters unchanged, and predict the resulting XTC by convolving the generated filters with my previously measured binaural impulse responses (DRC only).
The predictions use three measurements with my head approximately centred, and evaluate cancellation between 500 Hz and 8 kHz.
The result was rather uneventful!
The left speaker reaches its maximum cancellation around alpha = 1.9, at +8.2 dB. The right speaker behaves differently: cancellation gradually decreases as alpha increases.
But the average of both speakers barely changes between alpha = 1.6 and 1.9, staying around 7 dB. Even across the entire range from 1.0 to 3.0, the average changes by only about 1.2 dB.
The graph also shows that alpha mainly affects the lower part of the XTC band. Above roughly 4 kHz, there is very little to gain by adjusting it.
I also explored replacing the logarithmic curve with a simple first-order shelf. That offered a small additional improvement, at most about 0.8 dB with independent adjustments for each side.
So my interpretation is that the simple logarithmic model was already doing a reasonably good job. There is no indication that fine-tuning alpha is going to transform the cancellation performance.
Of course, these are convolution predictions based on my measured room and ears, not a universal optimum for XTC.
For now, I am keeping alpha = 1.9. Not because it is some magical value, but because it sits in a broad region where further adjustment offers very little.
Sometimes an experiment is useful precisely because it tells you when to stop adjusting things. :)
A better frequency-dependent ILD curve for my XTC? A small improvement, and a useful lesson​
In my previous experiment, I varied the alpha parameter of the logarithmic ILD curve used by NatAmbio's parametric XTC.
The result was a rather broad optimum around alpha = 1.8–2.0. Changing alpha further offered very little improvement.
But that left me wondering: what if the limitation wasn't the value of alpha, but the shape of the curve itself?
The original model uses a smooth logarithmic relationship between ILD and frequency. It is simple, easy to adjust, and gives quite reasonable results. But real acoustic crosstalk around a human head is not particularly smooth!
So, with Claude helping me analyse my binaural measurements and explore different filters, I tried three alternatives:
  • A simple first-order head-shadow shelf instead of the logarithmic ILD curve.
  • Gradually fading out XTC at high frequencies.
  • Allowing the ITD to vary with frequency.
The third option was rather disappointing: the optimisation converged back towards a constant ITD.
The high-frequency fade didn't improve cancellation with my head centred, but it helped limit the deterioration when I moved my head.
The shelf was the only change that produced a consistent improvement.
1. What does the measured crosstalk actually look like?​
[Figure 1 — Shape of the cross filter: logarithmic ILD vs head-shadow shelf]
This graph compares the old logarithmic filters (grey), the new shelf filters (green), and the measured acoustic crosstalk they are supposed to cancel (dotted curves).
The measured responses come from eight different listening positions, with their variability shown by the shaded regions.
My first observation was rather humbling: neither smooth curve follows the measured crosstalk particularly well!
There are peaks, dips and irregularities from the head, pinnae and room that a simple smooth model cannot reproduce.
And yet both models provide useful cancellation.
This is because matching the magnitude of the unwanted crosstalk is not enough. The cancelling signal also has to arrive with the correct phase. If the phase relationship is imperfect, increasing the cancelling signal to match the measured magnitude can actually make things worse.
The shelf doesn't magically solve these problems. It simply gives a more suitable overall frequency trend: flatter through much of the midrange, with a gentler transition towards the higher frequencies.
2. Comparing filters without moving my head​
Here is a methodological problem I encountered repeatedly during this investigation.
Every time I got up, walked to the computer and returned to the sofa for another measurement, my head ended up in a slightly different position.
And those small differences sometimes changed the measured cancellation by several decibels!
That made it difficult to know whether a new XTC configuration was genuinely better.
Fortunately, I had already verified that I could predict the binaural response of a new XTC filter by convolving it with my DRC-only measurements.
So I took eight measured listening positions and applied the different filters to exactly the same acoustic responses.
[Figure 2 — Log vs shelf ILD in the same head positions]
The upper plots show the average predicted cancellation versus frequency. The lower plots show what happens in each individual seating.
Three configurations are compared:
Previous logarithmic ILD+7.0 dB+4.9 dB
Shelf ILD, right ITD 150 µs+7.6 dB+5.8 dB
Shelf ILD, right ITD 140 µs+7.6 dB+6.2 dB
Mean predicted cancellation, 0.5–8 kHz.
The shelf provides a modest improvement on both sides. A further adjustment of the right-side ITD from 150 to 140 µs gives another small improvement on average.
But look at the individual seatings.
The differences between head positions are often much greater than the differences between filters.
That is perhaps the most useful lesson from this comparison.
A filter that appears excellent in one measurement might simply have benefited from a particularly favourable head position.
3. Do the predictions agree with actual measurements?​
Of course, predicting improvements is one thing. Measuring them is another.
I implemented the shelf model in NatAmbio and made several new binaural measurements.
[Figure 3 — Predicted vs measured]
Each point compares the cancellation predicted by convolution with the cancellation actually measured using that configuration.
The diagonal represents perfect agreement. The shaded region is ±1.5 dB.
The encouraging result is that all the points fall within that region.
Even the less favourable listening positions are predicted reasonably well.
This gives me confidence that the convolution method is useful for comparing XTC designs without having to physically measure every candidate.
It is not a substitute for measurement, but it makes the exploration much easier.
4. What happened in the actual binaural measurements?​
[Figure 4 — Measured interaural separation with the final shelf model]
This is one of the measurements with the final configuration, including the 140 µs right-side ITD.
The violet curves show the interaural separation with XTC, and the green curves show the DRC-only reference. The lower the violet curve falls below the green one, the more crosstalk has been cancelled.
In this session I measured approximately +7.7 dB of average cancellation for the left speaker and +7.8 dB for the right, between 500 Hz and 8 kHz.
I was particularly pleased to see the right speaker cancelling effectively in the higher frequencies, where the original model had performed less well.
For comparison, here is an earlier measurement using the logarithmic model:
[Figure 5 — Measured interaural separation with the previous logarithmic model]
There is an important qualification: these two figures come from different listening sessions. They illustrate actual measured behaviour, but they are not a controlled, same-position comparison.
The evidence for the shelf's improvement comes from Figure 2, where the filters are compared using the same measured acoustic paths.
Figure 3 tells us how closely those predictions agree with subsequent physical measurements.
5. Was it worth changing the model?​
I think so, although the improvement is modest.
The shelf adds around 0.6 dB of average cancellation on the left and 0.9 dB on the right when compared with the previous logarithmic model at the same ITDs. The additional right-side ITD adjustment brings the right improvement to about 1.3 dB.
Nothing spectacular.
And the measurements also suggest a practical limit: once the timing and overall level are reasonably well adjusted, changing one smooth frequency-response curve for another can only accomplish so much.
Real HRTFs have fine spectral structure that these simple models cannot follow, and small head movements remain a much larger source of variation.
Still, I like the result. The model remains simple, the adjustments have a physical interpretation, and the improvement has been evaluated with actual binaural data rather than relying only on listening impressions.
Sometimes the most useful result of an experiment is discovering that the simple solution was already pretty good.
And, as usual, this is one listener, one room and one pair of loudspeakers. These results describe measured acoustic cancellation, not a claim that the new configuration necessarily sounds better.
I'll leave the listening adventures for another post. :)
