Measuring a cartridge with the Ortofon Test Record
The Ortofon test record has a wrong frequency response and is misleading
Reactions: MMJ
You can use this formula in the Audacity nyquist prompt twice to correct for the drop between 3000 Hz to 800 Hz. Then use SJplot; you can use TRS1007 as record. Use track 3 and 4 (the second pair L and R).
(biquad-m *track* 9.08612614639649000E-01 -5.22931473883012000E-01 -3.44913691685509000E-01 1.00000000000000000E+00 -6.04500910000000000E-01 -3.90945930000000000E-01)
After this it is quite in accord with my CA-TRS1007.
