When I first saw schematics of vintage Kenwood KA-5010 amplifier, 2 years ago, I was immediately attracted and decided to build a circuit copy, better say a copy of the circuit topology with some newer solid state parts used. There were 2 points leading me to this decision - frequency compensation used and 3EF output stage, that grossly reduces loading of the VAS stage. I used lower supply voltage, like 2x25V - just what I had at the moment. The clone schematics looks like this:
This was built as a complete 2-channel stereo in a case with side heatsinks.
The result was much better than I expected, so please let me share some measurements with you. First, THD and THD+N at 1kHz, 5W/4ohm
Kenwood KA-5010 distortion 1kHz 5W/4ohm
Next, THD vs. amplitude at 1kHz, 4ohm load
Kenwood KA-5010 clone THD vs. amplitude at 1kHz and 4ohm load
Next, THD vs. frequency at 5W/4ohm
Kenwood KA-5010 clone THD vs. frequency at 5W/4ohm
Last, 19+20kHz CCIF IMD measurement
Kenwood KA-5010 clone CCIF 19+20kHz IMD at 12.5Wpeak/4ohm
These are very good results and the result of 19+20kHz IMD is simply great by any means. It shows that the amplifier has excellent HF linearity and that it keeps low distortion at high frequencies, as also seen from THD vs. frequency plot.
If there is an original somewhere, it would be nice, IMO, if Amir had an opportunity to make a measurement and compare.
