Measurements of my Unico 90, help
Could you please translate your post into English?
As for the measurements, they show an Amplifier with good output power, but high noise and distortion, as well as high output impedance.
This means that from a pure performance standpoint, it is no longer competitive with modern designs that offer orders of magnitude lower noise, distortion, and output impedance.
Though the Amp is by no means bad enough that you need to replace it for good sound, if you're considering buying one, at least personally I would not spend much more than $200 on it.
Sorry, I thought it was in English. So it's not a good amplifier? What would be better? A Marantz Model 50 or a Denon 1700?
If you want an Amplifier and nothing else, then I'd buy a 3e Audio Amplifier.
They have a few different models with varying channel count, minimum load impedance, and output power:
Though even better would be something with built-in DSP, for example WiiM Amp Pro/WiiM Amp Ultra.
OK, thanks! Or maybe a Hypex, controlling the volume from my Wii U Pro Plus? Won't the sound be affected by using the digital domain? Thanks
Also a great choice.
When making use of DSP for speaker correction/room correction, then the sound will be improved by using the digital domain.
And when you disable DSP, the sound will not be affected because modern ADCs and DACs are utterly transparent.
+1 to what @staticV3 says as usual. The amp you currently have is unusual in that it is expected to affect the sound a bit, based on the measurements. Even changing volume level affects frequency response. The distortion is also high compared to most modern amps. I think this amp really delivers a 'vintage' experience... with the somewhat unpredictable results that implies.
Good advice on what amp to try next.
The right amp to buy to replace it would mostly be determined by your speakers and how many watts you need to reach the SPL you need in your room / at your listening distance.
Thanks everyone for your valuable replies. I'm Italian and I bought this Italian-made amplifier because I liked the hybrid idea and because many people were raving about it, but the dimensions aren't exactly the best. Perhaps the distortion adds a touch of warmth? Anyway, I could sell it and get something more modern, perhaps an all-in-one or a power amp that can be controlled via the streamer. As for speakers, I have Harbeth C7ES3s XD, but I was thinking of selling them too and downsizing everything with KEF Q7 Metas.
