Measurements of LJM CS4398 DAC kit
audio_tony
Here are measurements of the LJM CS4398 DAC kit (still available on Ebay)
I built this around 2018 / 2019 IIRC.
The board has had some mods (specifics not shown here).
My test setup: Asus Xonar STX sound card with a self built buffer / gain box in front of that. Host PC is an Intel i7 running Windows 10 with 32G RAM and SSD - no mechanical disks or CDROM drive present.
I also use an Altor Audio Olivine-2 ADC, however the Asus Xonar was used these measurements.
Sound card input was set to 24bit/96kHz
I used an S.M.S.L. PO100AK as a USB to coax bridge, as the I do not use the limited USB input on board.
I used Arta for the measurements.
Output to DAC was set to 24/192kHz
My DAC assembled:
Board as advertised on Ebay:
THD 0dB
THD -3dB
THD -6dB
THD -30dB
THD -60dB
THD -90dB
Digital silence:
Frequency response (Arta sweep) - don't think this is right...
Frequency response (smoothed white noise):
Jitter:
THD vs Frequency:
Kinda high. What are the analog supplies and opamp on this guy?
Supplies are 12-0-12 and opamp is NJM2043DD. Any other 'jelly bean' opamp yields the same result.
I have a couple of other CS4398 based DACs and they are the same at 0dB.
When I exported the response to a text (CSV) file it was suspiciously flat, i.e. all zeroes for the amplitude!
I have attached an example of the export. The response surely cannot be this flat...
Still, almost 0.01% THD+N is way short of chip specs. This guy should be able to achieve -98 dB worst-case. It's almost like there is some kind of oscillation or something, or the analog supply current is causing jitter?
Why not? The chip itself has a combined filter FR spec of -0.01 to +0.01 dB (10 Hz to 20 kHz), plus whatever the output stage does. You're seeing -0.001 dB at 10 Hz to +0.011 dB at 20 kHz. Digital filter response itself at 96 kHz would be within 0.003 dB from 0 to 20 kHz.
Updated measurements.
Following the somewhat disappointing results (I was sure this had measured better previously) some further investigation found that Windows 10 was the issue here.
So I measured again using Linux.
As can be seen, the multitone and the -0.1dB results are hugely improved.
I guess my next quest is to re-measure all the CD players I did as well. Windows... :facepalm::facepalm::facepalm:
