In this thread Followed Aune S8
Actually, I had a bad impression of Aune products before.But since this product quotes ASR data for publicity, and there are some new features that are specifically advertised. I certainly want to buy one for measurement.
So ... look at things first
This is a pure decoder. The built-in volume function I think is a function from the ESS9038 chip (instead of a separate preamp circuit).
In fact, I think the design of the Aune series is good.But the surface treatment part is not good enough. I bought all black ones. The main problem is that there will be various "scratches" on the surface-in fact, it is not the surface that is scratched but debris from your nails or skin. The mark left --- it can be easily wiped off-but it looks uncomfortable.
In this case, I would recommend buying silver units instead of black ones-but I think their silver looks "cheaper".
Anyway, measure it!
For the standard level of 4V / 2V, the measurement volume is set to 118 (120Full)
It's weird here. In the case of AES input, there is interference around the 450hz frequency. Considering that there is no such interference in the case of USB input, a reasonable question is: Is the AES input design of this machine poor? (Actually, interference still exists on coaxial and fiber optic cables, and amplitude and frequency have changed)
:facepalm::facepalm::facepalm::facepalm::facepalm::facepalm::facepalm:
J-Test FFT192K Avg16
Anyway, measure it!
