Jimster480
The issue is that they are amping the RCA outputs... So he is trying to balance the RCA output to match a level of another DAC (in this case the Topping) but if he does so, then the wave falls apart as he mentioned.I am no expert on the digital side of things but analogue volume controls rarely need "full volume" for rated output and in many traditional amps the rated power is achieved at the nominal sensitivity with the volume control well below maximum, allowing a bit of headroom for inputs with a lower output. I don't know whether this is a limitation with this product but "full volume" on a traditional amp may well be well into clipping.
It is 30 years + since I checked myself but the amp I had then went into clipping using the rated input voltage with the volume control around 1 o'clock, where the end stop was around 4 o'clock.
If this product used a traditional RCA output like every other product, then "volume" wouldn't be a concern and it would be left to 100% (assuming its also a pre-amp) so that it gets the cleanest output.
