KenMasters
Oops I copied the subs from the previous person's post. But something still doesn't make sense. Arendal 1723 1s has a -3 dB point of 18 Hz. Your room is not small enough to be getting that much room gain. Normally to get 6 Hz, you need some kind of monster sealed sub (like JTR Captivator) with room gain. Measurement mics may not be accurate that low too.
The mic is a UMIK-1 with associated cal files. My living room is oddly shaped with low ceilings, side effect of converting an over 100 year old factory into an apartment building. The system is located between the end wall and a large support pillar, one sub in the far corner, one in the pillar corner - might be the reason? The dual Velodyne SPL-1000 Ultras I had before the Arendals managed to get down to 20Hz before dropping off precipitously in the same position.
