Hello everyone,
I’d like to measure my stereo system, which consists of two active speakers (B&O Balance). I’ve connected a Wiim Pro Plus with a 10-band parametric EQ beforehand. For the measurement, I’m using the classic combination of REW and UMIK-1. I’ve set up a test configuration, but during my research I’ve come across different approaches:
I’m now wondering whether it’s best to measure the room response of both speakers simultaneously, or to measure each speaker individually. On the EQ side, I can separate left and right; otherwise, that wouldn’t even be an option. One speaker is placed against a straight wall, the other directly in a corner, so I can definitely see how measuring them individually makes sense. BUT: In the end, both speakers always affect the room response...
What would you recommend? Is measuring them individually overkill, or is it worth the effort?
Thanks, everyone, and best regards!
