Measurability of 'digital noise' in the real world
klettermann
Coastal Connecticut
I'm exploring this topic on a forum concerned with such matters as well as audiophile switches, special ethernet cables, etc. My thesis is that such things probably do introduce some kind of electrical noise, but even if they do it doesn't work in such a way as to mangle all those little tiny bits. I used ChatGBT 5.2 to propose a simple test method to see if any of the stuff upstream of the DAC output can carry through the system in a way that moves the noise floor. It's kind of brute force method but seems to make sense. Please do have a look and see if you agree. Suggestions and comments welcome! Thanks and cheers,
ChatGBT:
Equipment required:
  • DAC or streamer under test with analog outputs
  • Low-noise audio interface / ADC (RME, MOTU, Focusrite-class or better)
  • Computer running REW
  • Ethernet switch and Ethernet cables (UTP and optional STP)
  • Optional: fiber media converters, battery or alternative supply for the switch
Physical setup:
  • Connect the DAC’s analog output directly to the audio interface line input
  • Disable any DSP, volume normalization, or software gain changes
  • Set a fixed gain on the audio interface and do not change it
  • Stream digital silence (zero signal) so the DAC is active
REW configuration (FFT / noise measurement):
  • Use RTA or Spectrum mode (no sweep)
  • FFT length: 65k or 128k
  • Window: Hann
  • Averaging: Infinite (or ≥30 seconds)
  • Frequency range: 0–96 kHz (or interface limit)
  • Vertical scale: fixed, same scale for all measurements
  • Disable autoscaling and smoothing
This configuration provides sufficient frequency resolution and averaging to reveal low-level broadband noise and discrete spurs without introducing visual artifacts.
What is measured:
  • Broadband noise floor at the DAC’s analog output
  • Presence or absence of discrete tones (hum, switching noise, HF hash)
  • Changes in spectral shape rather than single-bin fluctuations
Test conditions (change one variable at a time):
  • Ethernet connected vs disconnected
  • Switch powered on vs powered off
  • UTP vs STP cable
  • Copper Ethernet vs fiber Ethernet
  • Switch on same AC circuit vs different circuit
  • Optional: switch powered from battery or alternative supply
How “noise tracking” is determined:
  • Repeat the FFT measurement under each condition
  • Overlay or directly compare spectra using identical scaling
  • If noise level or spectral content changes repeatably when an Ethernet condition changes, the noise is said to track that condition
  • If spectra are identical within measurement repeatability, Ethernet is not contributing to analog noise
What does not count:
  • Autoscaled plots
  • Single-shot measurements
  • Differences below the measurement system’s noise floor
  • Subjective listening impressions without correlated output changes
Interpretation:
  • No change at analog output → Ethernet irrelevant to audio
  • Changes correlated with shielding or grounding → grounding issue
  • Changes visible on analog power rails → internal isolation or design issue
There is no domestic situation which requires Screened Twisted Pair (STP). An STP installation requires considerable skill to eliminate the risk of earth loops and analogue sections having general radio frequency noise injected into them.
UTP on the other hand is perfectly suitable for any domestic audio and video consumption and does not risk accidental noise injection.
As Amir states he has proved that Ethernet infrastructure has no impact on audio.
The measurement ADC must be fully galvanically isolated, using an USB Isolator and excellent isolated supply. Otherwise it can easily affect and dominate noise measurement.
The go-to tool would be the Cosmos ADC-Iso, which the chatbot forgot. It is also very low noise.
Chatbot also did not suggest proper settings for REW.
Note that it also forgot to mention that many DACs mute their outputs with no signal present (digital zero). It is best to use a low-level (-80dB) pilot tone to keep the audio paths open.
No wonder, as chatbots really don't "know" anything. Better ask real human experts.
Many thanks to all for the comments and corrections. That's exactly what I was looking for - I suspected that some details would be wrong or omitted. Chgeers,
Chgeers = cheers generated by ChatGPT? ;)
No, OP said he used ChatGBT , which apparently is a thing (at least it has a page: chatgbt.org), but I can't tell if it's legit or some kind of scam. There is a chatbot there, but when you ask it:
"What is the difference between this chatgbt and chatgpt"
it says:
"There seems to be a slight typographical error in your question, as "Chatgbt" is not a recognized term in the context of AI."
:oops:
The original procedure above was ChatGBT. It does good from time to time but still useful. The rest was me. No scams or tricks.
The ChatGBT.org site seems very fishy. I don't think OpenAI has anything to do with developing ChatGBT, other than ChatGBT may be using OpenAI's services. A web search does not reveal any linkage between OpenAI and ChatGBT.org.
Btw, I just made a joke about the typo. No other comment about the thread was intended.... :cool:
