Sharok
- Joined
- Sep 22, 2022
- Messages
- 60
- Likes
- 7
I have a 5.1 system (Fronts are set to large, Center and Surrounds are set to small with a crossover of 60Hz).
In the following screenshot of the MX100 web interface, there is a crossover frequency setup and a bass low pass filter.
My front speakers are large the rest are small and I use "LFE" (NOT "LFE + Main").
I understand the crossover frequency and I set them up per speaker, but I don't know what to set the Bass Low Pass Frequency? The minimum I can set that is 80Hz while my crossover for Center and Surrounds are set to 60Hz. what should I set the Bass Low Pass filter to if I don't need to use it? Will that crossover be ignored since I use "LFE" and not "LFE + Main"?
I called McIntosh but I did not get a black & White answer.
After I ran Audyssey, it set my fronts to 40Hz (while I set them up as "Large") will it be ignored since my fronts are Large?
