My Roku remote control does that.Or does it tell you when its batteries are leaking- that would be actually clever.
What have you replace them with? I am contemplating for a pair of the newer bookshelf MBL 126 in the living / stereo room; love the sound and is so different from my current setup in the home cinema room; This way i will have two rooms with total different but equally good sound.
But the price so far has stopped me from this purchase...still debating
I *sort of* replaced them with Joseph Audio Perspective speakers. By that I mean, I owned (and still own) several speakers that I listen to.
The MBLs were just one of them. I got them for a killer deal because they had been aesthetically damaged in a shipment to a customer and the dealer had to get rid of them. They were wonderful, but I was really lusting after a pair of the Joseph Speakers which were very expensive. The only way I could afford the Josephs was to sell the MBLs.
My take is the MBL 121s were a nice size - bigger with lower frequency range than the newer 126, but not quite as big as the vastly more expensive 120 model that succeeded them. The 121s frequency response was just low enough to be satisfying on their own. I've heard the 126 briefly at a show. Can't remember but suspect I'd want a sub with those ones.
BTW, when I sold the MBLS I put them up on the local CanuckAudioMart. I'd never had that much interest in a speaker I've sold, nor seen that much interest in any other add. within a couple hours my inbox was flooded, and by the end of the day I had about 40 very enthusiastic offers, people offering to drive hundreds of miles etc. And these were damaged speakers, no shipping boxes! A lot of people are intrigued by the MBLs so when an "affordable" pair came up there was tons of interest. Easiest sell ever.
If it's possible to fire a person for saying something untoward on Twitter, it should be possible to fire a person for this musical abomination.
As impressive as it measures, one of the engineering design decisions leaves me scratching my head. Input impedance of only 2.3 kOhm for unbalanced analog inputs? Why? Yet the input impedance of its other unbalanced analog input is 50 kOhm. That's more what I'd expect, why so different from the other? Why the inconsistency?
Anyway, for the price I'd expect a reference quality DAC and headphone outputs to be built in. And ... to be polite ... I'll just say it looks ridiculous. Too blingy. Form should follow and serve function, "tools not toys".
The same would be true for an input impedance of 10k or 100k. AFAIK Johnson noise is calculated using the combination of output impedance of the source and input impedance of the sink. 200 Ohm || 2k is only insignificantly lower than 200 Ohm || 10k or 200 Ohm || 100k. The lower the output impedance the less role plays the input impedance.It is actually brilliant design. Low input impedance, which means low shunt input resistor, is an optimization for noise performance (Johnson noise of resistor). If customers have source with low output impedance (under 200 Ohms from 20-20kHz), i.e. modern DAC/CDP with opamp output can use this analog input and have the best performance possible with this preamp.
Of course, in theory. But in practice it seems like unnecessary overkill, a poor trade-off. The degree to which it reduces noise is virtually or pragmatically immaterial, yet the low input impedance can be problematic with some sources. If you want a 10:1 impedance ratio you can only use sources having output impedance < 230 ohm. That does cover most solid state sources, but I've occasionally seen some that are higher. Especially with the boutique sources that somebody who buys a preamp like this is likely to own. It doesn't seem that the benefits are enough to justify the downside.It is actually brilliant design. Low input impedance, which means low shunt input resistor, is an optimization for noise performance (Johnson noise of resistor). ...
He’s a professional whistler. Give him a break for that!If it's possible to fire a person for saying something untoward on Twitter, it should be possible to fire a person for this musical abomination.
