Matrix Audio X-SABRE Pro MQA: Best Audio DAC in the World?
RichB
Massachusetts
Hi both,
The displaying logics now is:
1. When X-SABRE 3 receives streaming music, it will display the sampling rate, audio format(PCM/DSD/MQA) and filter type for the first several seconds, then it changes to another screen which only shows cover image with a streaming logo on top.
2. Every time you control volume, after the volume page disappears, the display will get back to sampling rate page first for several seconds, and then change to album art page.
FWIW, I prefer seeing the volume as the resting state.
- Rich
enricoclaudio
Houston, TX - USA
My X-SABRE 3 was shipped today ;) It should be delivered by Wednesday next week.
enricoclaudio
Houston, TX - USA
Got my X-SABRE 3 delivered today. Going to move the X-SABRE 3 conversation to a new thread. See you there.
Gotoro
I reviewed the Matrix Element X streamer and DAC a few months ago which achieved the highest measured performance of any DAC I have yet measured. Will the X-Sabre Pro MQA match or possibly beat it? I am here to answer that question. Company was kind enough to send me a unit for testing. It is not cheap at US $1,999.
If there was a measure of weight per square inch in audio products, the X-Sabre Pro certainly is the champion of it. Despite being rather small, the thing weighs a ton, making it almost impossible to pick up with one hand! The industrial design as with Element X is excellent, being modern but have a bit of "retro" look to it with the circular display:
A set of touch controls flank the unit allowing instant selection of inputs and volume levels.
Unit configuration is a bit obscure though. You have to hold the power button down where it counts with one, two and three dashes and shuts down. Continue holding the button and you will be greeted with configuration menu. Volume + and - then control the option and the power button is your select button. I did not mess with much in there other than selecting the different audio filters, upon which the unit will power cycle. It does this quickly but does cause the player to complain that it has lost connection with the unit.
There is a remote control but gives no filter setting controls. Wish they would add a button to it for that purpose for people who want to mess with it (not me). Or at least a setup button to get you into that mode rather than the long press on the power button.
For my testing, I focused on USB input as I always do. And unless noted, the main output I tested was XLR balanced output.
DAC Audio Measurements
OK, here is the moment of truth: the Element X garnered a SINAD (signal over noise and distortion) of 120 dB, pushing the limits of my Audio Precision APx555 analyzer. Let's see how X-Sabre Pro MQA does:
That's right! The previous record is shattered. With the output level reduced to 4 volt with -1 dBFS of input, we reach 121 dB. If you let it be at full level of nearly 4.4 volts, you lose 1 dB so still superb. Here is the official ranking graph:
Note that distortion products are at -126 dB or so. This means that the SINAD is actually more determined by noise level which includes my analyzer noise. In reality then, performance is even better than 121 dB! Wow!
Now we have to hold our breath through the rest of the measurements to see if anything else is a let down. How about linearity?
Nailed! Perfectly flat despite noise that impacts both the analyzer and DAC in this measurement. And it does this for both balanced XLR and unbalanced RCA output.
Jitter test shows incredibly low noise floor which naturally reveals a few spikes here and there but they are utterly inconsequential:
How about intermodulation distortion versus level? Could we see the dreaded "ESS IMD Hump?"
Of course not. The Topping DX3 Pro is very tough to beat in this test yet, the Matrix Audio X-Sabre Pro sails past it with significantly lower noise and intermodulation distortion.
Here is the intermodulation test with 32 tones instead of the two above:
We essentially clear the -120 dB mark meaning all distortions are below 20 bits (120 divided by 6).
Since some of you are in love with intermodulation tests of all sorts, here is the test of 19 and 20 kHz tones:
For grins, I left in there the TotalDAC d1-six dac measurements in red. You rather have your soup with a bunch of flies in it or bug-free?
Signal to noise ratio is spectacular:
It is actually 3 dB better than that of Element X.
THD+N versus frequency with a bandwidth of 90 kHz shows highly controlled distortion and ultrasonic junk:
Here is the response of the different reconstruction filters with #2 being the default:
I would probably go with filter 3.
The Matrix Audio X-Sabre Pro MQA is beautifully made, putting to shame many products in its price range. It oozes class and quality.
That beauty runs deep when it comes to performance as Matrix Audio X-Sabre Pro MQA unseats its own brother to take the crown of the best DAC I have ever measured. Considering that the list now includes nearly 160 DACs, this is an incredible achievement.
I met the team behind Matrix Audio at the last audio show and you have not seen a more soft-spoken, unassuming team of engineers than them. None of the ego that is so prevalent in high-end audio. The company is active here and on some other forums. And of course volunteers to have its products tested by us, rather than hiding in the bushes. So they score high on both product and customer service.
Needless to say, it is my absolute pleasure to recommend the Matrix Audio X-Sabre Pro MQA. We are here to find the best engineered audio products and the Matrix Audio Proves that it is among a handful of companies to produce such trophy class products one after the other. It put a huge smile on my face after testing it, one that will be hard to erase!
Driving around Portland Oregon, enjoying the incredible beauty Dahlia flowers at an amazing farm here (we come every year). Had to board the Panthers and so when I get home, have to pay the bill for that. So please donate generously using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
Hi Amir, enjoyed all your measurement and reviews. Are there any other DACs that measured as good as this, also in the price range between $1500 and $4K?
AdamG
Debunking the “Infomercial” hawkers & fabricators
Moderator
Reality
piaseczek
I believe so too, but it make me feel not very good to found one drawback in the almost perfect product. I checked the manual and found some settings may cause the problem.
And here is the manual: https://www.matrix-digi.com/pdf/X-SABRE_Pro_MQA_Manual_EN.pdf
Hi, probably the main reason for higher jitter in the x sabre pro mqa compared to the element x is lack of the "low" DPLL setting.
It improves jitter performance quite a bit as you can notice for example here:
Listening impressions of different DPLL settings:
piaseczek
Hi @piaseczek , we have no plan of adding LOW DPLL setting to X-SABRE Pro MQA.
Sorry.
Sorry to say that but this is a typical approach to firmware update for chinese companies.
Matrix x sabre pro mqa is your previous top model, the "low" DPLL setting is now a standard even in cheaper matrix' streamers. Last but not least, you know that this setting sounds better and it's very easy to implement.
Please reconsider your approach to firmware update, believe me or not, it'll be profitable for you in a longer term because of higher loyalty.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
Any evidence on the audibility part, or just the typical claims?
Reactions: SIY
BDWoody
Chief Cat Herder
Moderator
No evidence on the audibility, only Amir's measurements showing lower jitter.
Lower does not mean you will have an audible difference.
Do you know what jitter sounds like, or how high it has to be before it might be an issue? I found this link helpful.
Bamyasi
Those measurements were done for different device. There is no reason to blindly interpolate the results to a different device.
piaseczek
Take a look at the matrix element i measurements:
comparison between low, normal and high DPLL setting:
SIY
Alfred, NY
OK, so the worst case is ridiculously better than audible limits. It's not something I'd sweat.
dan_uk
Anyone know if it displays "MQA" when you play MQA via Roon? IT's got the little info screen, I was hoping it would but mine doesn't. The kHz change to match Roon.
piaseczek
gustard x18 is only using the sync mode (no asrc mode, can't be changed), and can do much better here
Probably because spdif in the x18 is reclocked in FPGA using one of accusilicons.
In the x sabre pro (mqa)/x sabre 3 spdif after the AKM digital receiver goes directly to es9038pro so jitter is much higher in sync mode.
truemise
May I get a proposal for a dac higher spec in measurements than the x-sabre pro nowadays?
