I have Roon Lifetime subscription so for me Roon Ready is a must have. The miniDSP SHD is under Roon certification right now and it measured really well. I also have an ARCAM ST60 Streamer which is Roon Ready and also DLNA capable.
Oh yeah, I forgot you mentioned about having the ARCAM ST60. How does it compare to the Matrix Mini as far as DAC sound quality goes? cheersI have Roon Lifetime subscription so for my Roon is a must have. the miniDSP SHD is under Roon certification right now and it measured really well. I also have an ARCAM ST60 Streamer which is Roon Ready and also DLNA capable.
Great setup!!!!! Ok, thanks for all the feedback, I guess I have homework to do and will choose between those two for my setup.!! Happy listening!!To be honest, I did a side by side comparison, and to my ears, they sound identical. Both, the mini-i Pro 3 and ARCAM ST60 have the same DAC. The ARCAM ST60 is in my living room setup.
\Great setup!!!!! Ok, thanks for all the feedback, I guess I have homework to do and will choose between those two for my setup.!! Happy listening!!
Yeah!! I like the way the Arcam looks too!!! I will check out roon again, maybe one day they will have a discount on the lifetime sub!!
I have no issues driving my DCA AEON 2 Noire's up to ear bleeding levels. The Noire's are rated 12ohms.Would the 22ohm balanced out impedance be an issue with the Sony Z1R as it is only a 64ohm headphone? Seems as the biggest thing keeping me from this all in one is the output impedance.
Any similar (power, features, etc) all in ones with lower impedance out there? DX7 pro, Monolith THX, RME ADI or something else?
Driving the headphones shouldn’t be an issue as there is plenty of power out of this amp. From what I have read, the FR of the headphone will be negatively effected due to the high impedance output from the amp. Usually the impedance needs to be 8-10x lower the the headphones impedance. At 22ohm out of the 4.4, it’s only about 3x.I have no issues driving my DCA AEON 2 Noire's up to ear bleeding levels. The Noire's are rated 12ohms.
I don’t think so, they are pushing the subscription model.Yeah!! I like the way the Arcam looks too!!! I will check out roon again, maybe one day they will have a discount on the lifetime sub!!
At the moment you can accelerate the volume using Roon. I understand that it could be done differently in the unit.Hey @MatrixAudio,
I've been using the Mini-i Pro 3 for the last seven months now. So far: very happy with it, overall. Still, there is a lot of room for improvements I expected to come with some firmware updates (to date, the last one is from... May). Two major expectations:
- You really do need to introduce some volume acceleration. This is the biggest downside of this unit to me. Volume adjustment is waaaay too slow, for whatever preamp or headamp usages. Could this be done by firmware, or are we talking about unsolvable hardware limitation?
- Some feature that has been requested on Matrix Digi forum: there is only two brightness levels for the (great) screen. I think many are looking for a third one that would dim the screen completely.
+1 on the screen brightness controlHey @MatrixAudio,
Cheers.
