- Joined
- May 22, 2020
- Messages
- 10
- Likes
- 5
Noticed that both of my minis downloaded firmware D013B8. Any changelog/notes on this release @MatrixAudio ?
Good question. It has been a year I'm waiting for this, @MatrixAudio ...Any changelog/notes on this release @MatrixAudio ?
New firmware available. Unfortunately, still no volume acceleration, @MatrixAudio
No, you don't. Full 0dB balanced output is 4.2Vrms, so pretty standard.Do I have to do this? And if so, how?
Thanks. But that doesn't answer my initial question at all... Will the Mini-i 3 Pro come with volume acceleration at last, or not? That is an highly frustrating situation, where the manufacturer says "Yes, we could do it" (correction : you really should have in the first place) and nothing comes 14 months after that.@ericisright @VintageFlanker
Hi, the D0 firmware update for mini-i Pro 3 improves the system stability.
I had sudden stops via Roon with mine, however firmware update resolved it.... Sorry that the info doesn't help you much.@MatrixAudio hey guys, glad I found this thread. I've owned the mini-i Pro 3 since August 22'. I recently expanded my listening to Spotify, and when I listen with the mini-i Pro 3, I experience frequent/constant stutter/clipping with every track I listen to. Would you be aware of any known issues that could be causing this? This happens with Apple Music also.
It does not happen with other services like Tidal, or Roon (local files and streaming). I have the latest firmware (updated today Dec 2nd, 22), and I use a M1 Macbook Pro 2021 model.
thanks I'll check out that thread too. Though I'm not entirely sure it's the mini-i pro 3's fault...listening to Roon or YouTube, doesn't encounter the clipping/stuttering. Only seems to happen with Apple Music and Spotify. Could it be that the mini-i pro 3 can't/doesn't process the Dolby Atmos?I've had my mini-i 3 pro for a couple of years (since introduction) and use it fairly regularly. 98% of what I listen to on my mini-i has been via Roon (hard wired lan connection) and I've never had any issues with playback. I've also done some listening via Bluetooth with the source being about 20' away from the unit. For this scenario, I initially tried LDAC but found that connection to be unreliable (drop outs) and ended up switching to regular Bluetooth...which worked fine.
Here's the link to the support thread in the Matrix Audio sponsored community. They are actually pretty good about answering questions and or providing help. You can also use it to see if others are having similar issues.
Is there any alternatives to this today with similar/better specs? - and still including Roon streaming option?
Hi friend. This version improved AirPlay playback.Apparently there is another OTA firmware release D113B8, does anyone know what’s new? @MatrixAudio
Hi, no such plan yet. Sorry.Hi @MatrixAudio , is there any plan to have this mini-i pro3 support Tidal/Spotify connect?
Most likely the fuse is blown. I would contact @MatrixAudio directly and ask them for troubleshooting steps.Hello, i have one problem. i connected it to 220v but the button was changed to 115v so now its not turning on . is any wat to fix this problem? and if yes, please tell me how to dissasembly this small guy, thanks.
@MatrixAudio can you help me?
