Sorry my English is not good enough so I can't translate everything in the link, see if someone can translate it. The filtering of commond mode noise is mentioned in this paragraph:
前面不是有個1.6V嗎?怎麼不見了?
如果那1.6V雜訊同時出現在這5V與ground上呢?因為電壓是二個點的相對值,你就看不見那雜訊,所以稱之為common mode noise,用電容濾不掉,得用common mode choke;
當你的DAC的ground接通這USB的地線,也就會有個1.6V雜訊出現在DAC的ground;好比某人不停的跳上跳下,你和他握手,你也會被帶著上下抖動!雖然你的DAC沒用到USB那5V電源,你的DAC的電源(ground)照樣被污染了!
In addition, I wrote an email to ask matrix audio. They replied that although element i does not use a USB 5V power supply (my actual test is also true), but the ground of the USB input and the ground of the computer are in common. Use the isolator (If it can completely isolate the ground wire of the USB ). The device can isolate the interference from the computer power.
The contents of the letter are as follows:
Re: Re: 您好,想請問Matrix X-SABRE Pro MQA的USB輸入介面是否吃電腦的5
您好,
Elemen i的USB接口不从前端设备取电,但是他们的地线是共地的。
据我们了解,USB2.0 HighSpeed协议 480Mbps的速度没有办法实现地线完全隔离的。
你给出的这个链接我们无法打开,如果这是一个电源过滤类的产品,那么它对Element i是无用的,因为该设备不从前端获取电源。
如果它是真正能实现地线完全隔离的,那么它将会隔离来自于电脑开关电源的一些干扰。
供您参考。
谢谢!
