@MatrixAudio I preordered mini-i PRO 3. I have hope it will not dissapoint me, SQ and functionality
Bluetooth is only 1 input option, there's IIS and USB type-c inputs provided. Roon Ready is also bit-perfect.@MatrixAudio this I canot understand, that you produce almost the best implementation of ESS DAC, but software is far behing... for what the best soft and spec when music I must sent to dac via BT? spotify connect or tidal mconnect is nothing new, please cache the trend
That would not be an issue. This is the specs of headphone amp chips, we used 2 pices of TPA6120 to build the balanced headphone amp.The mini-i pro3 has high impedance on the headphone output which could be an issue if you intend to run low impedance headphones.
The balanced headphone amp output impedance is smaller than 22 ohms, the unbalanced output impedance is smaller than 11 ohms.The output impedance of the mini-i pro3 is 22ohms?
Obviously bluetooth is for convenience not for the best sound quality.
I will useit as a streamer with DAC, connected to Musical Fidelity amplifier. I don't use HP.The mini-i pro3 has high impedance on the headphone output which could be an issue if you intend to run low impedance headphones.
Spotofy connect is possible.To be honest I don't need imputs, BT is only to make my wife's and children's life easier.
I was thinking about Spotify connect, Tidal. Stream without useing Roon, I know that it is roon ready but ROON cost extra money.
Will available next month.Is the mini-i PRO 3 product available and if so, how is it ordered in the US?
- Rich
Tidal only via Roon? Element is Tidal "ready".Spotofy connect is possible.
Yes, with Mini-i 3, the best way of listening Tidal music is via Roon, it no companion app, so you cannot send Tidal or Qobuz music bit-perfectly from youe phone.Tidal only via Roon? Element is Tidal "ready".
That’s a bummer. I was waiting for its release but as a non-Roon subscriber whose main source is Tidal and MQA, it’s a no go. Dont have ethernet hard wire so I am relying on wifi. Have Google Fiber which is excellent. Element i doesnt support MQA... might settle with Element i and software decoding of MQA.
Tidal through bluetooth with mini i-3 or Element i?You could just stream Tidal through bluetooth
For element i, play Tidal music in MA app over WLAN/LAN.Tidal through bluetooth with mini i-3 or Element i?
For mini-i 3, play Tidal over bluetooth or AirPlay.
I edited my previous answer, is it easier to understand now?Is SQ over bluetooth or airplay inferior to SQ over WLAN/LAN controlled by MA app?
