It depends on the situation (and mood). For one pair of speakers, I need positive correction to eliminate the speaker's own dips. MathAudio Room EQ doesn't offer this option. In this case, I use a convolver with the appropriate correction.
Interesting I’ve run into similar issues with notches/dips in the past.
At one point I tried to correct a sharp dip around 120 Hz using a parametric EQ (EasyQ) together with MathAudio. On moderate listening levels, the response looked and sounded more balanced. However, when playing louder I started to hear distortion and some audible strain from the speakers.
This behavior matches MathAudio’s design philosophy. Their Room EQ intentionally avoids boosting deep notches and mainly reduces peaks. As they explain, boosting deep dips can require large driver excursions, increase distortion, and lead to overcompensation of room effects.
In the first measurement (see my first screenshot), you can see the sharp dip around 120 Hz. That was the dip I initially tried to compensate with EasyQ. It “worked” at low levels, but at higher SPL the distortion became noticeable.
In the second measurement (after changes to the room), the dip is much less severe. Instead of forcing correction electronically, I addressed the acoustics by adding a new blind and a curtain. This reduced the null naturally and eliminated the distortion issue at higher volumes.
So from my experience:
- Boosting deep, narrow dips can work at low levels but may cause distortion at higher SPL
- Many deep nulls could be room-related cancellations and not truly fixable with EQ
- Acoustic treatment or repositioning is often the safer and more effective solution
That said, if a dip is clearly due to the speaker itself rather than the room, it looks like a different approach (like convolution) make more sense.
