Matching the monitor Tops to the Sub.... Edifier MR4 and T5 Sub.
5ynth3t1k
New Zealand
So, the tops have a EQ control and Vol control, the subs have an EQ control and Vol control.
How do I match them. And I don't mean "for the room".
This may confuse people.
( Image you have a three way box: you have to match the three drivers to give an overall "flat" response,
that is room independent. Catch my drift?)
So I have matched them by ear for where I sit behind the "console".
I leave the EQ on the Tops zeroed out. and the Vol is at aprox 75%
The Sub treble cut is down til it sounds ok and same with the Vol.
I adjust Vol at my monitor send. Sounds ok to me... but is my mix telling fibs?
I have no test program for "nesting" the Tops and the Sub. Suggestions?
My pal has a UMIK and will bring it over when he is back in town. We will do tests etc.
Any advice accepted except the " get better gear" type exceptions.
I really really like this little system a lot. It's cheap and sounds great to me.
Thank you!
PS Im trying to match the Speakers together, not "to the room".
( we can argue what that means if you insist...)
If it sounds ok that's probably the best you can do until you can measure it. I assume you've followed the T5 manual for connection and setup, and that once you've adjusted the speaker and sub volume controls you leave them alone and make volume changes upstream.
Yes. I did the manual. There really is not much to it.
Measuring is the key I guess. I was hoping there was some kind of magic wand I could wave
at it that would get the cut off right and the levels balanced...
By ear will have to do for the now.
Thank you for replying!
