Solar Paul
- Joined
- Jan 4, 2021
- Messages
- 7
- Likes
- 5
Hi, I'm planning for a subwoofer build for the LFE channel of a 5.1 surround system:
Thanks in advance
Solar Paul
- We are more interested in drama than slam bam action pics, so we are probably more at the musical end of the spectrum and there won't usually be very high volumes
- Plan is for a dual opposed 10 inch sub. Current leading contender for the drivers is SB Acoustics SB29SWNRX-S75-6. These are rated at 200wrms (86db sensitivity) with an impedance of 6ohm, so wired up they would be 3ohm in parallel or 12 ohm in series
- Cost is a factor, so I'm considering a cheapish plate amp from Aliexpress https://www.aliexpress.com/item/1005002806616053.html This is rated at 350w (max400w) and advises suitable impedance: 4-8Ω
Thanks in advance
Solar Paul
