Matching speakers Yamaha RN600
whyrhd
Hi all!
I'm kinda new to all this and I'm looking to buy a Yamaha rn600a (because I like yamaha and musiccast). I would mainly stream from Tidal.
Which speakers would be best suited for my needs?
I listen mainly to metal and hard rock, blues, but also just mainstream radio during daytime.
The listening space is 30m²
Some options (budget is 500-600 for speakers, if really needed more)
Wharfedale denton 85 (too bright?)
Wharfedale super denton
(both look awesome)
Wharfedale Linton will probably be too huge for my listing space (placement)
Yamaha ns-f51 (cheap and maybe a good match since Yamaha?)
Monitor Audio Bronze 200 (can get for 600 a pair)
Super Denton is out of your price range. Denton 85 not bad anyway.
Monitor Audio Bronze 200 is a floorstanding speaker, which will be the best option for bass, but not if you need a bookshelf speaker.
NS-F51 is underwhelming to look at and I've never been impressed by Yamaha's lower end speakers (but they have a high end line that's nice - just out of your budget).
Among your options I'd look at the Monitor Audio Bronze 200 if you can get them within your budget.
I am uncertain of prices in your locale....
Consider looking at the Polk Audio 'ES' line of loudspeakers. Amir has reviewed the ES20 bookshelf speaker and the ES60 tower loudspeaker and recommends them when Parametric equalization can be applied.
I like Yamaha gear. Before purchasing the Yamaha RN-600A, consider whether a WiiM amplifier has the feature set you desire.
WiiM streaming amplifiers support Tidal Connect and offer access to Parametric EQ and their RoomFit room correction feature.
Most loudspeakers and headphones benefit from the application of Parametric EQ and most listening spaces benefit from room correction.
Thank, will do.
I could also get Dali oberon 5 for around 700€ here.
Are the Denton 85 not too bright when matching with a Yamaha (or wiim)?
Elac Debut DBR62 is also a good option and arround 500€ in Europe. The Revel M16 can be found for arround 600€ if you search a bit (altough mostly it's arround 700€) and it's also a great speaker fit for your amp. Both are reviewed here.
