I ran an interesting measurement and tweaks of WiiM PEQ and my sub LPF / Phase in my audio setup and dedicated home office and listening room. I was already very happy with sound, even before tweaks, to start with - in terms of sound balance, available headroom, ultimate transparency, linearity and virtually unlimited power and current delivery capacity ... but these additionally improved the overall enjoyment of my music listening sessions
My main hi-fi audio chain
1. Mac Mini - Roon server core
2. WiiM Plus Pro streamer - Roon endpoint
3. Benchmark DAC3 B - DAC, in fully open voltage mode
4. Benchmark LA4 - preamplifier
5. Buckeye 1ET9040BA - Purifi Eigentakt, class D mono blocks (in LOW GAIN mode)
6. Neat Acoustics Motive 1 - 2.5 way floor standing speakers, 86 db sensitivity
7. SVS SB-1000 Pro - subwoofer, 30cm in front of the main speakers, firing into the room, its back panel is 50-60cm away from the wall
Connectivity
1. WiiM Plus Pro to Benchmark DAC3 B - Toslink optical
2. LA4 to SVS SB-1000 Pro subwoofer is RCA
3. All other - XLR connections
Room
In this case the room measures approximately:
• Width: 3 metres
• Length: 6 to 7 metres
• Height: 2.5 to 3 metres
My Current Setup
WiiM PEQ
PK Filter 1 at 32Hz, Gain -9db, Q=5
PK Filter 2 at 57Hz, Gain -1db, Q=4
PK Fliter 3 at 130Hz, Gain -1db, Q=5
SVS SB-1000 Pro sub
Volume at -10 db
LPF at 40 Hz
Phase at 0 deg
In Room REW RTA Measurement With Real Music Played Through This Audio System, 10K+ samples
The REW RTA graph above with 10,000+
averages maps out the room's exact physical geometry signatures, with Benchmark LA4 volume set to -30dB. It seems to be highlighting what acoustic engineers call
geometric boundary nulls (destructive phase cancellations)
These dips are caused by sound bouncing off the walls, floor, and ceiling, then colliding at the listenning seat, somewhat out of phase—meaning
they may not be able to be fixed with further EQ tweaks.
The good news is that my system seems to be handling them relatively nicely:
1. The 32–35 Hz Null (Sub-Bass Cancel)
- What it is: This is a longitudinal room mode cancellation. As the deep sub-bass from the SVS sub travels the length of the room and bounces off the back wall, it meets the incoming wave exactly 180 degrees out of phase at the listening position.
- Why it's a blessing in disguise: Because the room naturally wants to ring aggressively at 32Hz, this localized null actually helps prevent the sub-bass from turning into an endless, muddy drone. By locking the filter back at -9.0 dB, setup seems to be preventing the adjacent 25Hz peak from inflating, keeping the sub-bass fast and incredibly well-behaved and properly tamed.
2. The 75–80 Hz Null (The Floor Bounce / Front Wall Cancel)
- What it is: This sharp canyon is a classic boundary cancellation. It is caused by the mid-bass waves bouncing off the hardwood floor and reflecting off the wall directly behind the Neat floorstanders?
- Why ears don't care: Human hearing is remarkably insensitive to narrow, razor-sharp drop-offs. Because the frequencies directly to the left (60–70Hz slam) and right (90–120Hz punch) are perfectly flat and phase-aligned, the brain completely "fills in the blank," ensuring kick drums and bass guitars retain all their physical impact
3. The 180–220 Hz Null (The Desktop / Side-Wall Cancel)
- What it is: This wider, shallower valley lives right at the transition from upper bass into the lower midrange. This is almost always caused by a closer, secondary reflection—such as potentially sound bouncing off a nearby side wall, the surface of a coffee table, or the front chassis edges of the audio gear rack.
- Why it is perfectly fine: the floor of this dip stays up near 40–42 dB, making it much shallower than the deeper low-end nulls. Because it is a soft, wide dip rather than a sharp spike, it acts as a natural separator between the heavy punch of the rhythm section and the clarity of vocals. It actually keeps the lower midrange from sounding thick, chesty, or boxy.
The Ultimate Takeaway
Every single listening room in the world has similar nulls, depending on its own dimensions — even multi-million dollar professional studios. The mark of a world-class system isn't having an absolutely straight line on a graph; it is actually about ability to
tame and control the destructive peaks (like the 32Hz mode above) while keeping the overall frequency envelope as flat and as uniform as possible from 40Hz all the way to 20kHz. The long-term average is sitting beautifully at
65.3 dB C / 61.4 dB A.
I am very happy listener indeed and now I have some kind of a 'scientific proof' ha ha
