I was editing my post when yours popped up, now I have to leave it unedited.Let's not confuse timbre with timber. Unless we're speakings wooden instruments.
I kinda like the timber timbre and you're not the first to mix both, so I hope you felt it was good natured!I was editing my post when yours popped up, now I have to leave it unedited.![]()
All recordings are artificial. How much have you done?Close miking is very much artificial, since you don't usually stick your head into saxophone bell.
The recorded music I listen to and care about is precisely classical live acoustic.With the exception of classical music, almost no recorded music is seeking to reproduce live acoustic music
Without familiarity with live sound, you have no idea whether playback of a recording is producing a good facsimile of live sound.and listening to live music will tell you nothing at all about the accuracy or quality of a home system.
All of them are neutral. You need to know which venue (and which audience location within the venue) that the recording is trying to reproduce. This is usually clear from the recording itself (if it's a good one).A violin sounds dramatically different if it's being played in a church or a concert hall or a coffee shop or a small room. It also sounds very different depending on whether you're 18" from the instrument, and 18 feet from the instrument. Which of these is "neutral"?
As Floyd Toole says, "I recall the early spaced-omni microphone phase". Those are my favorite Telarc recordings. They sound most like a real orchestra to me.That was the folklore.
Right, that acoustic reference really is just a whole world full of if's, and's, or but's, that it's very rarely applicable.I get the live music point for acoustic stuff, knowing what a real cello or flute sounds like is a decent sanity check. But even when the musicians played and sang live in the studio, the final version has been heavily processed in mixing and mastering, so there’s no live equivalent to compare it to. The only real “original” is what the engineer heard on their monitors, and those vary all over the place (Toole’s circle of confusion).
Mostly very true. There are very few recordings done that are capable of reproducing the exact sound of any particular acoustic instrument.All recordings are artificial.
True. And completely beside the point for all recordings that position the recording as the original event, not the performance. I would argue that the vast majority of music is not trying to recreate a performance. I would go so far as to say that most music posits the recording as the original and performance is a variation on that recording adapted for a live event.Without familiarity with live sound, you have no idea whether playback of a recording is producing a good facsimile of live sound.
Man, I agree. That's all that needs to be said.All recordings are artificial.
There are two problems with this assertion about live music - the first is that the initial comment from MarkS didn't specify "unamplified acoustic" live music, just live music generally, and if you're micing and amplifying live music, typically you're getting much worse capture and reproduction than you would in a studio, with uneven FR, all kinds of weird room interactions, imperfect mic placement and reliance on dynamic mics instead of condensers, etcs.I agree with the rest, but this is IMO an overstretched argument. Instrument timbre is retained in most situations, apart from explicit effects processing.
While harmonics can be highlighted or missed in certain acoustic spaces, I'd not infer that live music tells you nothing. You learn the main spectral content of said instrument and how it generally sounds. Bad THD and wrapped FR doesn't modify the partials in the recording. Even moreso, incorrect FR affects all the instruments in the same way, so the relative harmonic partials structure is retained between instruments.
Saxophones emit sound not just from the bell but from the nearest open tone holeit would be emitting, from its bell the sound the mic is recording
Fair, you're right about the first point. That's perhaps since "unamplified acoustic" feels like a natural benchmark to relate to on an audio forum and it is a bad assumption to make.There are two problems with this assertion about live music - the first is that the initial comment from MarkS didn't specify "unamplified acoustic" live music, just live music generally, and if you're micing and amplifying live music, typically you're getting much worse capture and reproduction than you would in a studio, with uneven FR, all kinds of weird room interactions, imperfect mic placement and reliance on dynamic mics instead of condensers, etcs.
Look, I might not have a proper career and years of experience recording, but I am a bedroom artist (bad one, but the process holds), so it's not like it's entirely a foreign matter to me, okay? Other thing to get at the end of all the mixing, mastering, etc. is to also adopt what you recorded to limited hardware capabilities of a typical consumer, limited dynamic range that one operates (given typical housing noise/listening in cars), limited medium dynamics (hello vinyl!), bla bla bla I am not that dumb, yo.The second issue is that you're ignoring the recording half of the equation. It is recorded, in a studio, and a million decisions are made by the producer and recording engineer in the process of recording that music that will impact how the recording sounds, before it ever gets to your speakers and your room. Mic placement compression, saturation, room interactions, EQ on the mic preamp, EQ on the mixing bus, etc. etc. You're never just hearing a magical transparent capture of a moment of live music - you're hearing the mics, the preamps, the mixers, the production and mixing and mastering decisions. Setting aside the issue of our inability to remember subtle details of sound long enough to compare a live performance and a recording, all of these intervening steps and decisions means you cannot possibly know, unless you were present during the performance that was captured and have a superhuman photographic memory, whether the reproduction is an accurate representation of the original sound or whether it has been significantly altered by all of these production and engineering choices.
Microphones aren't ears and don't work the same way ears do. By way of a single example that recording engineers have to deal with all the time - microphone placement. I often record acoustic instruments like flute and violin. When I am recording the violinist in my band, I can place a microphone very close to the violin. Doing so isolates the violin from the room, but the microphone's proximity to the instrument creates a bass boost effect. We hear a lot more of the physical sound of the bow on the strings. We hear more of the high frequency harmonics of the instrument as well that would be less pronounced in the room. If I place a microphone at a typical listening distance from the violin, I capture much more of the room sound than will probably be wanted in the recording, I don't have bass boost but the instrument can sound a bit dull or muddy. So how do you record a violin to get "neutral" sound? You blend those microphones, carefully picking a balance between a close mic and a far mic. You apply some compression and you apply some EQ to reduce the proximity effect on the close mic. Maybe you add some reverb via an IR VST, if the room you're recording in is very dry. If I do my job right, the resulting recording is evocative of a performance in a live room, but it is not simply a performance in a room - it has been manipulated in a thousand ways, and we haven't even touched on frequency response of microphones, and the changes to FR and distortion introduced by the microphone circuit, microphone preamp, amount of gain applied, and impedance matching of the mic and the pre, phase changes caused by EQ, etc.
Which artist? the principal violinist? the percussionist? some sort of mean average of all the musicians? the conductor? the (likely dead) composer? the record producer? the recording engineer? Unless you're talking about self-produced, self-recorded, self-performed, self-composed (or improvised) solo music, records require many people to make artistic and technical decisions.Purpose of proper engineering is capturing what and how the artist wanted to be heard.
This is a fantastic point to make, actually. Let's just agree on "whatever the intent of the person in charge was". Like Kevin Shields hiring & firing 10 or so sound engineers when recording "Loveless" since they just didn't click.Which artist? the principle violinist? the percussionist? some sort of mean average of all the musicians? the conductor? the (likely dead) composer? the record producer? the recording engineer? Unless you're talking about self-produced, self-recorded, self-performed, self-composed (or improvised) solo music, records require many people to make artistic and technical decisions.
Music is so inescapably collaborative that we can't ever hope to pin down something as amorphous and individual as "how the artist wanted to be heard."
Can't agree, sorry. I'm with Barthes, Wimsatt, and Beardsley: intent is inherently unknowable.Let's just agree on "whatever the intent of the person in charge was"
Right, I should've just known you're going to bring this one upCan't agree, sorry. I'm with Barthes, Wimsatt, and Beardsley: intent is inherently unknowable.
Maybe the person you think was in charge wasn't really in charge. Maybe they did complain. Loveless came out on a label, after all--maybe Shields complained a lot to the Creation Records guys?if the person in charge didn't complain
What I pretend to know (from what was written) is that Kevin was close to bankrupting Creation. I bet they complained a lot!Maybe the person you think was in charge wasn't really in charge. Maybe they did complain. Loveless came out on a label, after all--maybe Shields complained a lot to the Creation Records guys?
Maybe they hate it for a personal reason that has nothing to do with music or sound (they got divorced during the record, they were in the depths of addiction and later they cleaned up, they just didn't like their bandmates, whatever). Maybe they love it for similarly extramusical reasons? Maybe they say one thing but inside they feel the opposite?
We'll never know![]()
Fair point, and no need to prove yourself. I think it's sometimes worth getting in the weeds on all the things that go into actually making a recording, as in my experience, many folks on the internet who spend a great deal of time talking about the reproduction/listening side of things have a giant blind spot about how those recordings are actually made, and the amount of manipulation and alteration that goes into making a good-sounding recording. That this isn't you is great and sorry if it felt like I was condescending to you from my enormous pedestal of occasional production and engineering work on studio recordings.Please note that I specifically referred to timbre. Okay, compression/limiting bend the sound spectrum, but we have to somehow differentiate what happens during recording vs what happens during synthesis.
Unless you subscribe to the idea that those aren't different at all, which would be a fair position to have.
Because of that, timbral/spectral point of reference taken from live music is carried towards recorded music, be it on headphones or speakers. Or even if you tried beatboxing it.
I once read this interesting question (but I can't remember where) - would Miles Davis play the same if he didn't hear his idols through a terrible quality radio speaker? That was probably his first point of reference.
It's a very stimulating discussion, despite now feeling the need to prove myself.
