How would you react to this scenario.
A loaner pair of affordable speakers are offered for an in home audition, there are no specifications or measurements available, but since there is no obligation or cost for the audition, you give them a listen and love the way the sound.
Would you consider purchasing them before also seeing measurements?
Measure them myself.
With a laptop and a cheap microphone. My time and the mic are likely less expensive than the speakers. I'm also not in need of more clutter, and as you can see by some of the tests I have posted I have plenty of speakers, so I would use the opportunity to make sure I will like the sound, with measurements, probably MMM. I would be even more careful if I didn't have plenty of speakers I like already or the speakers were expensive, perhaps a SPIN using a simple set of measurements, as I do.
FYI, the two best sounding speakers I own were purchased based on measurements only. One set are JBL M2 I built myself, I copied JBL's crossover settings, based on measurements. Instead of ported, I went sealed with Linkwitz transform for the bass, based on measurements. I used measurements to quantify the reduction in output I get with the sealed/transform. I tried a number of other things I thought would be interesting, including a 3-way and 2.5-way configurations, but rejected them based on what I heard and was able to verify, based on measurements. Everything I heard was verifiable in the measurements. They are in my room that I have measured so that I don't accidentally put them in a place where I get large bass peaks, otherwise I am likely to come away with the opinion that the bass is awesome. Or put them where I get a null, and come away with the impression that bass is super-tight. I also used measurements in the room to chase down rattles in the HVAC, and to setup the subwoofers.
I'm also happy to see measurements on old speakers I have owned. I finally understand why my Vandersteen IIc sounded the way they did, based on Erin's measurements. Same for LS3/5A and NS-10 speakers that were so popular back in the day on our store's used shelves, I now understand the sound and use conditions for these, and the dramatic unit to unit variability of the LS3/5A. And some of the very odd opinions I
So yeah, the measured sound is what the speaker produces. And despite my opinion that I am a good listener, with some measurements to back that up, I am not Spock. So I measure.
I'm not being sarcastic. Measuring is such a simple thing. I notice this forum is drifting away from fundamentals of sound and the realities of human perception, a reverting to the misdirection and confusion that we had back in the day.
