Regarding section1 "complex load”:
A buffered op‑amp input is high‑impedance, but it is not a purely resistive, zero‑interaction load. The DAC still drives: finite input impedance, cable capacitance and inductance, dielectric absorption, the op‑amp’s input bias network, and any RF filtering at the input. Those elements form a real transfer function that affects HF phase, settling behavior, and noise modulation. That’s why different line stages and cable/interface combinations can measure identically at 1 kHz yet differ in wideband behavior and time‑domain performance.
and regarding number 2 “no preamp is always more accurate”:
“DAC → amp is always truer” is only valid in an ideal system with zero output impedance, infinite input impedance, zero cable reactance, and a DAC output stage designed purely as a line driver. In practice, many DACs have modest output stages optimized for short, easy to drive loads, not for driving longer interconnects or more complex input networks. A dedicated preamp with lower output impedance, higher current capability, better common‑mode and RF rejection, and cleaner wideband behavior can reduce interface‑induced errors (HF phase shift, noise modulation, level‑dependent distortion). It doesn’t “add information”; it reduces the degradation that occurs when the DAC is forced to do both precision conversion and heavy line‑driving at the same time. That is why my Gustard R26 DAC replaced my SMSL SU-10 DAC. It sounded better.
I would purchase a Rockna Wavedream DAC, but I ain't rich like you guys.
