Phallic Brutalism is very popular in the trade.They look cooler
And Primaluna has that delightful chaotic impedance interaction with your speakers.
We all have our opinions on Kool.They look cooler
The statement "well measuring" is often left out.Really? I think that is a highly controversial statement for ASR. Please elaborate.
Read the quote again. That is not what he said.So when Amir says he’s listened to hundreds of valve amps at shows and never liked them
LOL, Personally I do find that a handsome little integrated amp.Phallic Brutalism is very popular in the trade.
Apologies, he didn’t say “hundreds at shows” he said “ probably 100+ at shows and friend's houses.”Read the quote again. That is not what he said.
Maybe, but your assertion fails your own test. You are basing it off anecdotes.
Saying that an industry expert can't reliably discern significantly bad distortion without doing a blind test is a form of denialism. We don't have to be that skeptical.
In particular, he didn't sayApologies, he didn’t say “hundreds at shows” he said “ probably 100+ at shows and friend's houses.”
I’m not sure how that changes my contention though. He’s listened to a lot either way and subjectively he prefers the sound of solid state. It’s still anecdotal
He said :Amir says he’s listened to hundreds of valve amps at shows and never liked them
(My bold in both cases)and have listened to probably 100+ at shows and friend's houses, and I have never, ever heard it sound better than solid state.
And in my correction I saidA very different statement. Not that he didn't like all of them. Just that he's never heard a tube amp sounding better than solid state.
However, my point remains that even quoting his words precisely (which I confess I didn’t do), his comments are just anecdotes.He’s listened to a lot either way and subjectively he prefers the sound of solid state. It’s still anecdotal
...aaaaand no one said they weren't. Straw man like the way you keep misquoting.his comments are just anecdotes.
Okay, I did it, and here's my report:
It's not a common thing here at all and you made that up for reasons unknown. You call it "self-deprecation" but it's not--you're deprecating others, not yourself.
Picking the best bits of the replies already posted, and trying to be really succinct, I would put it this way: although most amps are designed for transparency and do sound the same with every speaker when not being overdriven, this transparency is not true of every amp out there. So, the 'ASR line' is that amps do sound the same if they are designed for transparency and are built to spec, but some are misconceived, or underpowered for some uses, and these will not sound the same.
cheers
Still not what he said - he did not say in that post that he prefers the sound of solid state - just that he's not heard one sound better than solid state, and has heard plenty that sound worse.And in my correction I said
Again you are missing my point. I’m not good at expressing this stuff so I’ll try again.Still not what he said - he did not say in that post that he prefers the sound of solid state - just that he's not heard one sound better than solid state, and has heard plenty that sound worse.
Well put. With the exception that it is missing: and those amplifiers (typically tube) designed to operate/sound different from solid state.
And this:What was stated is that we can reasonably have confidence in him, as a significantly trained listener, to tell some bad devices by ear without proving it to anyone (your requirement) in a double blind test
Considering we're talking about High Fidelity here, and that Amir has measured and heard so many amplifiers. I can't think of a better person to be
able to pick out the accurate from the inaccurate.
It’s like saying you could walk into a room where all the components are behind an acoustically transparent curtain and pick whether the amp being used is valve or solid state.
Are you saying that is not possible to pick out one of the "boutique" non-NFB tube amps (or an SET) driving a loudspeaker that has high reactance in the bass?
