I certainly get your point, but I would add some caveats…
That is one view of the job of high end/hi fi equipment. There are other points of view, for instance high Fidelity to the experience of hearing live instruments in real acoustic space. (Hi Fidelity started off as a goal to re-create the sound of real voices and instruments).
So it’s possible for a system to be doing its job in this sense well, not necessarily in the sense you are advocating.
So you’ve suggested there’s a criteria by which you can decide which piece of equipment is objectively doing a worse or better job than another. Fair enough. But let’s look at a challenge to this.
Let’s take an example.
Let’s see you have a recording you want to reproduce:
Leonard Bernstein conducting Gustav Mahler’s Symphony No. 5 with the Vienna Philharmonic Orchestra, recorded in 1987 for Deutsche Grammophon.
Now we want to reproduce that recording accurately.
So what is on that recording? It’s a recording of an entire Symphony Orchestra playing an extremely dynamic orchestral piece of music.
That’s what the recording represents.
Now let’s say you have a very nice room for playback acoustically, and you set up two different loudspeakers on which to play this recording:
The
Genelec G Three active speaker:
The specs for this speaker are : 54Hz–20kHz, ±2.5dB.
And they measure almost impeccably neutral.
Now here is the second loudspeaker:
Wilson Wamm Master Chronosonic loudspeaker:
Frequency Response: 20Hz-33kHz ±2dB
No measurements available for this loudspeaker, but Wilson speakers have often been slammed here for their design and lack neutral measurements.
Measurements for one of their large loudspeakers here
So let’s assume that these large speakers have some significant deviations from neutrality.
So, for the goal of reproducing our selected recording, here’s the question:
How would you determine which one of these loudspeakers is objectively worse at doing its job?
Even if that job is to re-create the information in the recorded signal?
If you went with strict neutrality as the criteria, it suggest you would choose that tiny little Genelec speaker.
But that Genelec speaker is missing plenty of the lower frequencies - frequencies in the recording - that the Wilson speaker is able to reproduce.
More pointedly, if the job of the loudspeaker is to faithfully reproduce the information represented in the recorded signal, again the information represents a bombastic performance by an entire Symphony Orchestra. So which speaker is going to be better (even if not perfect) at doing that job?
It seems the huge Wilson speaker, even if not fully neutral, would be much more adept at producing the sense of scale and power and dynamics of that orchestral recording than the tiny Genelec. (again we don’t have measurements though listeners have generally reported being in awe in terms of these attributes of those speakers - the ability in terms of sound staging size and imaging and power in creating the sense of being in front of large scale sound sources like symphonies).
(I suspect also that one can find very neutral stand mounted loudspeakers that may also go down to 20Hz, but which would still lose the fight with the Wilson speakers in terms of the impression of convincing scale and power hand dynamics).
So I’m curious how you (or anyone else who wants to chime in), decide which loudspeaker is doing the objectively better job of reproducing the recording.
It seems to me in such scenarios, and given the variety of speaker designs and recordings that could be a great many such comparisons, some level of arbitrariness is going to be involved even when invoking this “objective criteria.”
