Master Thread: Are Measurements Everything or Nothing?
If testing subjects for statistically relevant preference, then yes the result preferred by the population may not be the same as your preference.
If (as is more often the case) testing subjects for detectable differences, then it is likely that the results do apply to you. Unless your personal hearing is much better than the hearing of the study's subjects, or much worse, which is a bit of a corner case study then.
Exactly- there is no way to predict with any certainty exactly the preferences of any particular individual. For individuals not looking to roll dice, it makes more sense to listen for one's self in one's room and system before committing rather than relying on the opinions of others.
Actually, a third possibility is tests like ABX tests aren't for everybody, need a ton of concentration to perform especially if the differences are small, and some people just can't complete the test with rigor from start to finish. I sometimes get flat out bored, loose interest... In which case a null result means nothing.
Well, yes, there is that, isn't there?
Some of us have found designers, manufacturers, or reviewers we trust explicitly.
The guy who designed my (previous) speakers I've loved for 40 years I would (and have) bought anything he produces. I absolutely know his talents, taste, and priorities and have spent many hours in his sound room.
I have always been a trust but verify sort of person, rather than a kool-aid drinker. Clearly, your mileage may vary.
I would rather call it evidence that 70% of listeners subjectively preferred A to B. I wouldn't make the leap that I would "probably" like it too- I don't buy equipment on a "probably".
...there is no way to predict with any certainty exactly the preferences of any particular individual. For individuals not looking to roll dice, it makes more sense to listen for one's self in one's room and system before committing rather than relying on the opinions of others.
Perhaps you could avail yourself of the actual science on preference in sound reproduction, instead of point scoring over silly hypotheticals involving amps that, if competently designed for a flat frequency response and applied in a situation where they won't 'run out of power', simply won't be able to be distinguished by any percent, never mind 70 percent.
The best available experimental evidence that I have seen indicates that people are universally consistent in their preference for sound reproduction that delivers an initial sound wave, the so-called direct or first arrival sound, that has a flat, smooth and extended frequency response in the audible band. The only exception being people with significant hearing damage.
That's why it's a very important finding: it is not "70 percent" and applies to you "probably". It is so reliable that the sensible course is to assume it does apply to oneself, and put the burden on oneself to prove otherwise before ignoring it.
cheers
Which is why the measurements, and ability to understand them and relate them to my preference.
After all, I can’t control my mood as well as a mic.
cheers
Well perhaps I am one of those with significant hearing loss, which means then that it doesn't apply to me. When it comes to matters of taste and personal preference, I prefer to judge for myself in my system and in my room. I am not arguing against studies that show that at a certain level of objective performance amps will be indistinguishable to most, I am simply saying that I prefer, and can understand why others might as well, to decide for myself in my room with my system, rather than take anyone else's opinion or study result, into my decision making process.
Well perhaps I am one of those with significant hearing loss, which means then that it doesn't apply to me. When it comes to matters of taste and personal preference, I prefer to judge for myself in my system and in my room. I am not arguing against studies that show that at a certain level of objective performance amps will be indistinguishable to most, I am simply saying that I prefer, and can understand why others might as well, to decide for myself in my room with my system, rather than take anyone else's opinion into my decision making process.
Are you suggesting that your hearing loss drives your preference?
Where was it written that you should take other people’s opinion into account for deciding on which gear? You are actually being told you shouldn’t let someone’s opinion on one piece vs. the other sway you.
And the science does show that these people are completely useless at identifying even their own preference. They can't pick the same preferred component this morning vs afternoon, today vs tomorrow. People without such damage are really quite reliable and consistent. You definitely want to be in that group.
You are rushing far too hastily to claim that the findings may not apply to you.
Again, avail yourself of the actual science. It shows that the method you describe above will create opinions, including preferences, that are dominated by non-sonic factors. You aren't even identifying your own preference for sound waves, using that method.
Whether or not I have hearing loss is beside my point, which is I prefer to screen equipment based on objective performance parameters, then audition the candidates in my room and system to decide which I want and which I don't. I don't believe in taking the opinions of others as part of my decision making process. That's all.
Maybe he meant he wants to get the speakers home to measure in his room to verify an already established preferred response.;)
OK, prolly not.:p
I assure you I have no issues with my preferences.
Well, whether they do or they don't is of little interest to me. What I am concerned about is my own findings.
I don't recall recounting my methods other than saying I screen by objective performance and then listen to those that meet my requirements in my system in my room.
Once again, nobody is giving you an opinion on what to buy. You are getting information on what has been demonstrated to actually create biased opinions, in others and in yourself.
Please give a citation to the published paper(s) that you believe make this claim.
But it's what I personally prefer that matters to me and as you agree, there can always be outliers- maybe the guy asking me my opinion about a set of speaker is an outlier. Maybe I am... Thus, I can not rely on such evidence. This kind of data may be valid in gross, but I don't find that reliable for anyone in particular. I just don't see much confidence in its predictive power regardless of how it was obtained. I am at a loss to understand the logic behind taking subjective data in a controlled way, summing it, and then saying the sum of a sample of subjective data has now been transformed into an objective result....
I would rather call it evidence that 70% of listeners subjectively preferred A to B. Not sure how you can make the leap that I would "probably" like it too- I don't buy equipment on a "probably".
Goryu, measurements don't tell you what you like, but it can accurately describes something so you can make your own judgement. If you prefer speakers that exaggerate low frequencies, looking at speaker measurements will tell you that. It's been shown over and over again humans are not reliable in describing sound. A consumer is best served by 1) understanding his own preference, and 2) understanding how gear is measured and what those measurements mean
Please state the specific claim.
What you wrote:
Claim #1: "people are universally consistent in their preference for sound reproduction that delivers an initial sound wave, the so-called direct or first arrival sound, that has a flat, smooth and extended frequency response in the audible band" [underlining added]
Claim #2: "The only exception being people with significant hearing damage" [italics in original]
Well, if the results of hypothetical double blind test is that 70% prefer amp A, then amp B clearly isn't competently designed...why is that silly or impossible?
