Master Thread: Are Measurements Everything or Nothing?
Sounds like an audiophile salesman trying to belittle objective measuring of equipment in order to create more room for subjective BS based sales talk.
About Klippel not being perfect - Nothing is perfect, but somebody please point out a better practical way of finding out actual speaker performance.
About ABX being stressful - I guess taking a lie detector can be stressful to some...
About accuracy - Trying to refer to recording process is totally lame. HiFi is about faithful reproduction of the *result of the recording process* regardless of what was done during that process.
About speaker measurements not going to match perfectly - I'm not sure exactly what he means by this, but again, just because something is not perfect, does not mean that it could not be better than other available methods.
About floor bounce - Seriously, is this meant to be some kind of big revelation? Yes, room (floor included) acoustics is a significant factor. So what?
Not sure if all of the above is after watching the video, or direct criticism of my post. Criticizing is easy. Being a keyboard warrior is even easier. Enjoy the inflated ego. :)
Just to expand on the floor bounce matter - to me it was a very important insight gained from watching that video. Why? My Neumann is setup higher than ear level pointing down, and with the higher than normal setup, there is a floor bounce cancellation in my measurement.
My frequency response measurement will show a gaping valley. I have been wondering if I should find a way to deal with the floor bounce cancellation. The insight I gained from AJ's talk was that we as humans live with floor bounce all our lives, and our brain would have learned to compensate for it. With that insight, it convinced me that I do not need to do anything about the floor bounce.
To me, I learn something new. I got new insight from watching the video. Therefore I shared it as it may be useful to others.
If that piece of information is useless, by all means, discard it. Doesn't concern me at all.
The takedown and trashing is a little bit too much... for sharing my insights / opinion.
Don't like what I share, by all means, put me on your ignore list :)
Or report my post ... and get me banned.
You might like this too. (link to a post by an ASR Luminary)
[edit: another one]
My take has always been that we can measure everything we hear. Instruments are much more precise than humans. But the difficulty is in interpreting those results and trying to translate what we see into what we hear.
Speaker measurements are really useful for identifying inherent problems with speakers, but it is extremely hard to translate that info to what the specific results would mean in your own room. And things like wide/narrow dispersion can cause huge variatons in how the speakers sound in your room, even if the FR is identical. That said, if you buy a well measuring speaker blind, you still have high chances that you can tune it to your own preference with EQ, which you cannot do with speakers that have inherent flaws like resonances etc.
I think one negative aspect with science and measurements is the fact that to some degree it removes the ability to leverage our brain's susceptibility to bias. Because if you think something should sound better, you probably really feel like it does and that makes it just as real to you as something you can measure, atleast in that moment. Value of that kind of enjoyment is of course questionable, as it usually won't last very long (not worth spending huge amounts of money).
About the (importance of) floor bounce and Andrew Jones mentioning it, could it be that coaxial-'coincident' speakers (like his designs) have an advantage in that facet in that the 'bounced' summed sounds in the crossover region are better in phase than when the tweeter sits above the midrange driver? Or perhaps only in theory.. (Maybe Mr. Jones mentions this in the video - I haven't seen it, so sorry for the speculating.)
Maybe if you listen in a store, but if you compare them then with other speakers, other aspects/biases might play a larger role. If you already bought well-measuring speakers you are sort of used to the sound when this effect wears off and if you are lucky, relieved from upgraditis. Now that can wear off as well, but chances are often smaller than with a not so good measuring speaker of which you initially like the sound.
What I meant by that, is that if you have a way of verifying by measurements that you did not get any benefit from a new dac or pair of new cables, then you cannot buy yourself a christmast presents that will make your music sound better for few weeks. If you already have a perfect measuring system, then you have basically lost one easy way to make you feel better. You can of course then use the money elsewhere, and probably in a more sensible way, but nevertheless you lost one option.
I think what he meant with the floor bounce is that since it is always present, our brains have accustomed to it and we do not perceive it so much. Ceiling and side walls are much more noticable and there it helps if you have evenly radiating drivers like coaxials, where you are getting more easily predictable radiation pattern.
I think that Randy made a nice remark about the specific speaker that he liked and how he cannot know beforehand what speaker would be the one that he would like. I think that he would benefit a lot by measuring the response he is getting from those speakers, so he could EQ almost any decent speaker to that sound profile without trying to find a pair that has it baked in.
[edit: another one]
Thank you for sharing! I must have missed those old posts. Pretty much similar to what AJ said.
There is no doubt that ceiling floor reflections are audible, but the best designed experiment I know of indicated that listeners were not happy when the floor reflection was removed. Humans have evolved with a hard reflective surface always under their feet. Section 7.4.7 in the 3rd edition discusses it.
Siegfried Linkwitz also decided that “The floor reflection, which is mostly unavoidable, and which is readily seen in the steady-state on-axis frequency response as dips and peaks, is not necessarily audible on program material.” (Linkwitz, 2009).
But there is an intriguing logic to the notion that humans evolved while standing on something, and most of what we hear includes reflections from what is under our feet.
I understand that, but that also means that if it would be completely damped, or maybe differs too much from the direct sound in a certain way, our brain suddenly 'misses'/detect it, which could be experienced as less natural. To make it more complicated, it could exist in the recording as well. A main advantage of good coaxials is the good vertical radiation anyhow.
How true! That's why I am always seeking out knowledge linking measurement to what I hear.
I am slowly learning that certain wiggles seen in the measurement should/can be ignored (like floor bounce).
Funnily when seeing large wiggles in the measurement, somehow motivates me to start thinking if I should do something about it. My nature I guess.
Yeah, true. I already learnt from past experiments that a flat in-room frequency response does not sound good to my ears.
What sounded good is a downward tilt from >200Hz, with one or two gentle wide-Q EQ to flatten any wide ranging frequency response humps.
Below 200Hz I use as many high-Q EQ as needed to whack down resonating peaks (as seen in waterfall chart), and ignore high-Q dips.
Ah, of course, I was focused on speakers and that you ment high expectation bias with a well measuring speaker!
Had a few drinks and it's almost two o-clock pm (verifying... yes that's at night) so I probably call it a day. Peace
I was critical about those opinions You pointed out as presented on the video. I was not criticizing You. I don't quite see how the opinions I presented would tell anything about the size of my ego, but whatever...
That's odd... There seems to be 2 weeks worth of posts missing between post 15400 & 15401.
Did a server go down?
All I know is the better the Stats the more it costs. Then you add fancy cabinets made out of African Fairywood and you can add another $100k. Why is there a correlation? We are not all idiots. Okay, let me think about that.
Maybe someday measurements will exist that can quantify these nuances. Then even cheap mass-produced gear will be equal to great gear that is able to deliver flat frequency and phase response AND precise imaging AND that inky blackness that all the magic emerges from.
Until then "audiophools" will just have to endure ignoramuses pretending this technology exists NOW and all the important stuff has already been identified.
Do you have a single example of something that has been proven audible (via controlled testing) in audio electronics (not speakers) that can't be accounted for with known measurements?
Technically, human beings cannot be objective. They can only be subjective.
Only non-human constructions (machines and instruments) can be objective. They, in turn, cannot be subjective.
Although I don't have a really high opinion of Wikipedia, I think they have a good explanation of the issue here. (The bolds are mine.)
" Something is subjective if it is dependent on minds. If a claim is true exclusively when considering the claim from the viewpoint of a sentient being, it is subjectively true. For example, one person may consider the weather to be pleasantly warm, and another person may consider the same weather to be too hot; both views are subjective.
Something is objective if it can be confirmed or assumed independently of any minds. If a claim is true even when considering it outside the viewpoint of a sentient being, then it may be labelled objectively true."
The mechanisms that prevent us from accurately evaluating subjectivity (much less controlling it) are explained in these two publications:
You can't just wave your hand and change the language.
Miriam Webster defines *objectivity* as...
the quality or character of being objective : lack of favoritism toward one side or another : freedom from bias.
Nowhere does it say only machines can be objective. You dismiss a great number of experienced humans by saying they can't possibly be objective.
How can they be when all their inputs are interpreted by organic matter controlled by feelings, emotion, experience, self interest, hormones and memory? Every sensory input is a perception filtered by a biased operator. Truly objective data is only obtainable by a non-conscious device incapable of interpretation.
