JUST ONE WAFER THIN MINT?Calories?! It’s only 5!
His video is about how amplifiers can sound different, depending on the amplifier and speaker load.
I would have thought that rather obvious when combining amplifiers with load dependent frequency response and speakers with widely varying impedance with frequency.
Both of these amp have a poor damping factor. Of course they influence the frequency response.
Nothing but clickbait nonsense.
The 275 has a damping factor of 14. That is still poor.Erin says the McIntosh amp “ behaves quite well in terms of output impedance” (which is one reason why he did the comparison between the McIntosh and the prima Luna amp, showing how much the prima Luna amp with it’s much higher output, impedance deviated from the McIntosh) .
Anyway, why prove your point with two tube amps?
They are just used to manufacture an issue that properly functioning amps reduce to the inaudible.
With that kind of a clickbait title, you’ll get my clickbait response… it’s as simple as that. I’m sure his data is correct, and his conclusions are somewhat nuanced. But frankly, there is nothing new here, and it will just strengthen some people’s beliefs that all amps sound different.Erin is doing excellent audio education. Not sure why it needs to be greeted so dismissively . But I guess I can’t convince you out of it.
So, you will play a roulette game with your speakers until you find the "magic sauce" or you will use a good amp and then add some EQ if you want?
Thousands vs EQ via software / integrated in today preamps.
FWIW Dept: Mac and EV lead the charge during the 1950s for using Voltage drive rules in loudspeakers, the idea being using an amp that behaves as a Voltage source driving the speaker (the goal being better 'plug and play' with less adjustments needed). Its no surprise the Mac 275 is perfectly capable of this behavior as its output impedance is actually pretty low due to sufficient feedback. I suspect the Prima Luna is not.Both of these amp have a poor damping factor. Of course they influence the frequency response.
Human's ability to "hear through the room" is sometimes overlooked with the easy availability of measurements and graphs and DSP. A good measuring speaker with transparent electronics (easy unless you go out of your way to find something broken) is going to sound good in most rooms. That doesn't mean that the measured sound isn't negatively affected by the room or that it couldn't be improved with placement, treatment, or DSP but rather our brains do a lot of work filtering out room effects. Whenever I am frustrated with my in room measurements I take a look at the measurement with "psychoacoustic smoothing" or "ERB smoothing" and feel better and then go enjoy listening.I’m afraid I’m the worst. I just buy the best things I can afford that test well, install them where they fit in the room, and learn to live with it.
I would advise everyone to acoustically measure their system, ‘golden ears’ not required.
