Recognisable values for sure , I certainly can relate to that iv just never felt the need to turn it into a ' identity ' in the sense of ' I am a objectivists ' . Then iv never felt the need to label myself in any way whatsoever . I personally find self labling and much of what seems to me to be a rapidly increasing need for self definition through labeling, interesting but ultimately a source of some hilarity while also rather worrying when seen in a larger context.
As definitions go , you're definition of ' objectivist' is a admirable one . ' I'm human ' , that's about as far as I go with all that.
TLDR: categories can be helpful and informative, and don’t need to be restrictive. The fact some used categories in an unhelpful way doesn’t mean they can’t be used in a helpful way.
Full:
I think perhaps that you are taking the issue more seriously than I am or perhaps in a direction I am not taking it.
I think we would agree with the pernicious aspects of identity politics. And I am of the mind that any sense of personal identity should be held loosely, so our self identities do not constrict how we can grow as people, change what we believe, learn new things, etc. I bet I’ve done as much as anybody here to defend not just my approach but varying viewpoints.
However, terms of convenience don’t require us to make them into some overriding, restrictive identity. If I’m driving home in a big rainstorm and the weather forecast on the radio says “
motorists should avoid the McKinley exit due to flooding of that offramp” I have no problem identifying as a “ motorist” in order to understand how that warning would apply to me. I’m not afterward running out to make myself T-shirts or baseball caps with “motorist” printed on them.
That goes for any number of terms that can help describe one viewpoint we might hold, which doesn’t mean that viewpoint is our identity or restrains us.
For instance, Philosophically, I’d be termed a Moral Realist. Even though that leaves a hell of a lot off the table in terms of details, it carries some information to somebody into philosophy. Also, I am a Compatibilist on Free Will (and in the sub category of Leeway Compatibilism). Those are simply convenient terms for some views I hold. They are not everything about me. I am open to changing those views. And again I’m not putting them on T-shirts or baseball caps or attending Compatibilist rallies.
The reason such terms arose (eg Compatibilism, Incompatibilism) is because many people thinking about these subjects found that there were at bottom, some
fundamental differences that explained a lot of peoples views and intuitions on a range of subjects relating to free will.
By the same token we can try to explain the type of conflicts that regularly arise in the audiophile community.
Why do we have threads devoted to snake oil? Virtually nobody here would purchase the type of things in the snake oil threads… yet there are plenty of audiophile who do.
Why?
Why do threads about cables notoriously erupt into fractious debates? On some audiophile forums cable discussions are actually banned!
What causes the conflict?
As I’ve argued before, it is best described or predicted by identifying epistemic attitudes in terms of what audiophiles are relying on to gain knowledge about audio gear.
A . If it is your view that, ultimately, the most reliable method of evaluating the performance of audio gear is based on one’s subjective impressions during informal (not controlled for biases) listening…
You are most likely to find that attitude among those arguing that high priced cables provide better performance.
B. If it is your view that, ultimately, the most reliable information about the performance of audio gear comes from measurements and / or listening tests control for bias..,
There are good reasons why we are most likely to find that attitude on the side arguing against the claims made for “high end” expensive cables.
So it essentially drills down on where we place the greatest confidence - in uncontrolled
subjective experience, or in
objective tools that help us overcome the limitations and unreliability of our perception - measurements (carefully correlated to subjective experience), listening tests controlling for bias etc.
This should hardly be controversial. This demarcation is made all the time in this forum. It doesn’t need to be some derogatory stance - that would come from whatever attitude somebody has towards other people. It’s simply factual… comprehending some information that helps explain certain phenomena among audiophiles. Using terms like “subjectivist” in the first category and
“ objectivist” for the other category Isn’t adding more constraint to the categories you’ve already identified. It’s simply using some shorthand terms to refer to those different approaches.
Just like “compatibilist” and “incompatibilist” are useful philosophical reference terms for those viewpoints.
That leaves (objectivist/subjectivist) all the room open for somebody to fill in any of the details of their view.
It also leaves all the room open for people to identify in neither category. And all the room open for people to have views that might end up somewhere in between, or jump back-and-forth on one subject or another, or whatever.
But so long as there remain some relevant proportion of people who incline one way or the other, it is a useful and informative demarcation conceptually, and there’s nothing wrong with having terms for those views.
As you’ve seen even my own understanding of “objectivist” doesn’t even restrict how one engages in the hobby.
I think whether one sees such terms as derogatory or restrictive or making too much of one’s identity… I guess that will depend on one’s own attitude. I myself try not to use the terms in such a fashion.
Cheers.
