Master Thread: Are Measurements Everything or Nothing?
Where do you draw the line?
I don't have a clearly defined line. But I think that proportionality is a good guide. Of course I wouldn't buy a DAC for $10K. The medical profession didn't say: buy a $10K essential oil for your nose if you feel it will help you, even if it doesn't objectively. If there are two DACs for 300, one of which has worse measurements than the other, but both below the audibility threshold, then I might buy the “worse” one because I find it nicer. That gives me a better feeling, just as someone else might buy the other one because of its better (but just as irrelevant) measurements.
Second example: Amir recommends absolutely useless devices such as the Fosi Audio LC30 or McIntosh MPM4000. Why? Because they have a fun factor and - at least in the case of the Fosi - won't do too much damage to your wallet.
As long as I keep proportionality, money spent on objective useless equipment can be a win in my system.
That's all I wanted to say.
But that is something completely different. You know upfront that it doesn't make a difference.
They are recommended because they don't interact with the source and can therefore be used without potential issues.
Those VU meters might be useless, but they are also objectively not detrimental. The same goes for your $ 300 DAC that you liked better than the other one.
Are measurements Everything or Nothing?​
I'd say 'most-thing' if such a term ever existed. I've been told first hand by speaker designers that even a 'pretty darned perfect' measuring speaker (okay, on axis), can be further refined by tweaking crossover frequencies and tweeter level by a tad each way. I don't know enough to delve into the phase tracking over crossover points but on a three-way for example, it's vital I'd suggest, getting the blending right, and not sure this can be fully and seamlessly done in a passive crossover...
Another question is "Are the measurements sufficient?". Now, that leads to what does "sufficient" mean?
I would wager the usual/commonly used measurements are sufficient for most applications. However, are not scientifically exhaustive.
One example is system compatibility. Two devices can measure practically identically in the usual tests, yet one may experience common mode induced noise (say 60Hz "hum") in a system while the other does not. Similarly with amplifier tests into purely resistive loads.
Now, I do not believe all test methods must be expanded. That would be impractical.
Simply that one does have exhaustive evidence that there would never be any audible differences in specific cases.
I don't think that's the point I was trying to make. The authors of the study said sometimes evidence is not so important, not always. The title of the thread is Are measurements Everything or Nothing? My conclusion from the article is that in medicine, as in music, measurements are very important, but other things like subjective feelings are not unimportant either.
And that is a valid comment on the thread title. But the journalists were describing a simple example of the placebo effect, yet the way they wrote, "The application (. . .) leads to an improvement in a number of subjective feelings associated with a cold", suggests they think the cold bath was actually improving colds due to some physical effect that was being subjectively noticed but not measured. Although that is one possibility, it cannot be the conclusion until the placebo effect has been eliminated as a variable.
My conclusion is that there is a bigger difference in sound between recordings than there is between the mediums we buy the recording on.
I have superb sounding LPs and CDs
I have poor sounding LPs and CDs.
That’s my experience too.
However, I think we of course, have to acknowledge that when CDs came out people dropped LP’s pretty quickly for CDs.
Some of this may be attributed to the marketing of CDs, And the various conveniences associated with CDs. But also most of us heard better quality with CDs. So there was definitely a “ better sound quality factor” associated with the format itself.
My own experience in getting back into records, and purchasing what seems to be a really good turntable, was to revisit those comparisons. As it turns out, at least in terms of my impressions through my own system, yeah CD maintains those well-known Sonic advantages.
But on revisiting the differences, I have found the gap closed from perhaps how I perceived it when CD first arose, and the Sonic experience was totally new.
It turns out that I actually enjoy some of the Sonic character of LPs for its own sake, even while acknowledging I can hear it’s not as accurate. And also, the reacquaintance has reminded me of just how fantastic vinyl can actually sound. Over the years I started to associate vinyl sound with old dusty moth-eaten records, not well taken care of, with all sorts of noise and pops and ticks.
But now I’m experiencing newly produced vinyl, as well as picking up plenty of used vinyl in good (“NM” or “M”) condition which I clean with an ultrasonic cleaner.
And the result is that I can enjoy fantastic sound from vinyl as well as fantastic sound from CD. And in the end, I find the quality of recordings themselves more prominent in establishing the sound quality than Weather. I happen to be playing a record or a ripped CD.
That’s how it’s worked in playing things through my own speakers in my own room.
If I were listening through really high-quality headphones, I might find a shortcomings of vinyl more pronounced. But it sure sounds great through my speakers!
I seem to remember an LP thread on whatsthebest forums (Amir's old forum). One in which they purchased new records and recording the result. Seems they found a surprisingly large drop in the above 10 khz range with just a few plays. This was all using top notch LP gear too.
Not saying those experiments were wrong.
But there’s also tests like this one that I have posted before. a record played 100 times on a cheap turntable versus played 100 times on a good turntable. The sound of the recordings is compared as are the recorded waveforms, suggesting negligible differences between the first and hundredth play on the better turntable:
My practical experience using test records to set up turntables was that the highest frequency tracks were vulnerable to wear and could only be completely trusted when new. I've also seen occasional evidence presented that disagrees with my experience, but I know what I measured across hundreds of turntables and test disks.
Interesting: We are currently experiencing a wave of colds in Germany. Today, a daily newspaper reported on a scientific study on the topic: “How well do essential oils help?” One result was that a meta-analysis from 2022 found that almost all study participants felt a relieving effect - and were able to sleep much better after using a cold bath or balm. However, one study result was also that objective measurement parameters such as nasal breathing resistance did not improve measurably. The newspaper says: Nevertheless, the study authors from the UK are mild: sometimes the evidence is not so important. “The application (. . .) leads to an improvement in a number of subjective feelings associated with a cold.”
In the end, that's what counts, isn't it?
That is really just the placebo effect which is known to work in the medical field and I, personally, believe is the only explanation that some people prefer something added to their HiFi which makes no difference in reality, just the same and fine if you have enough money...
Assuming the tests were properly administered blind tests, it need not be due to the placebo effect. It simply means the mechanism of effect is different than "nasal breathing resistance".
This is a review and detailed measurements of the Naim Uniti Atom streamer, DAC and integrated amplifier. It is on kind loan from a member and costs US $3,799.
The overall industry design is attractive and has a high-end look to it. Alas, every part of the unit has an ultra sharp edge from heatsinks to edges of the plexiglass (?) front panel. It is a heavy box which makes you really feel those sharp edges as if they are going to tear into your skin. It was unpleasant every time I had to move or rotate the unit.
The front panel is large and sharp which I like. Alas, and strangely so, it is not a touch screen. In this day and age and at this price, a touchscreen is a requirement in my opinion. A very large rotary control managed the volume. It seem to have some kind of acceleration but wasn't very intuitive.
Here is the back panel:
I was surprised to see the compact binding posts that are made only for banana plugs. Likewise there is no USB B to use the unit as a DAC. Maybe you can use the type-A connector for that but even so, it is very unusual choice. Nice to see a floating ground switch. In my testing, it only impacted the networked tests. Otherwise it had no effect.
Inclusion of HDMI is very important to allow sound from TV to be piped into it.
Upon booting and with Ethernet cable plugged in, it nicely told me there is new firmware. It took something like 10 minutes to download the image and then went into a seemingly infinity cycles of booting, dark screen, non-descript progress bar and power button that would fade on or off or solid on. I left there for probably half hour when it finally seem to be ready.
There is the usual app to control it but I opted for the included remote control. It too has very sharp edges but otherwise functional.
Naim Uniti Atom DAC Measurements
I started by testing the unit using Coax due to lack of type-B or type-c USB port. Here is our usual dashboard:
Distortion dominates causing our SINAD (noise+distortion) to barely reach into "fair" category:
Distortion rises into the noise floor of even 16 bit content so not a good first showing. As noted, changing the grounding mode made no difference in any of these measurements.
The output stage is capable of higher voltage which is nice:
Good to see the output does not become all distorted once the internal amplifier is pushed beyond clipping.
Noise performance is not competitive with even budget DACs but almost good enough for 16-bit playback:
Multitone distortion was quite high:
Jitter display looks clean but noise floor is high and is masking interference patterns:
Levels of those spurious tones though is quite low and inaudible (-128 dB).
We have a rather odd filter response:
This partially contributes to rather poor noise+distortion relative to frequency:
Finally, linearity matches the fair performance of the rest of the system:
Naim Uniti Atom Amplifier Measurement
Given the choice of analog or digital input, I tested both which producing 5 watts:
Performance is very close so I opted to use analog in as that makes the comparison to other amps easier. Notice the high power supply noise at 120 Hz (double mains frequency in US). Overall ranking is well below average:
Frequency response test with analog input shows a brick wall filter which indicates input is being digitized:
Shame then that no DSP functionality is provided. The roll off filter in the ADC causes some drooping in the high frequencies.
Crosstalk response was kind of shaky but overall good:
Multitone test once again shows less than optimal performance:
Rated power is low and that is what we see:
Sweeping the frequency for power measurement we get orderly response:
Notice the typical sharp drop in power at 20 Hz. This is why you need more powerful amplifier than you think you are getting. Power is needed in bass but the reservoir capacitors in the power supply get depleted and you don't get as much output.
Naim Unit Headphone Amplifier Measurements
I expected the headphone output to be "junk" but it actually is not:
That is plenty of output for satisfactory response of high impedance headphones. Noise floor is not competitive with any modern/recommended headphone amp but could have been far worse. At 32 ohm though, available power is much more limited:
Sweeping the load we see that the headphone amplifier is not capable of much current delivery:
So best to stay with high impedance headphones.
Naim Uniti Atom Streaming Measurements
I ran the streaming tests a day later and here, I noticed noise bleeding into the output:
So I tried the ground lift switch and it remedied that:
SINAD though is dominated by high distortion so didn't matter one way or the other. And performance is the same as local/coax S/PDIF input.
Performance of Naim Atom ranges from fair/adequate to rather poor. Shame that when you pay so much for a piece of audio, not much design hygiene is included. I suspect more went into software development and enclosure design than making sure the hardware is performant. I hope for a version 2 the company works to substantially improve the performance of these subsystems. I am sure many buy a Naim product thinking they are getting great audio performance.
I can't recommend the Naim Uniti Atom streaming amplifier.
P.S. I was going to give the mailman panther rating to the unit but he is out making deliveries......
It’s always interesting to read your reviews! The funny thing is, whenever high-end products are reviewed, they always seem to fall short—while the best measurements go to Topping? Really? LoL! So you truly believe that just because something measures well, it sounds good?
I’ve found the opposite to be true. I owned the Topping A90 a few years ago and, like many, bought it based on reviews. However, I quickly realized it was just an okay amp—nothing special. The sound was uninspiring, and it didn’t live up to the hype at all.
On the other hand, I own the Naim Uniti Atom HE, which, to my ears, sounds miles ahead of the Topping. The comparison isn’t even close—it would be laughable to put Naim alongside a brand like Topping, which is essentially a budget audio manufacturer from China. They focus on the latest specs and measurements to claim superiority, but in reality, they can’t be considered a true high-end audio brand.
Come on, listen to music—not just measure it, for god’s sake! Numbers won’t give you the feeling of a song.
I’m not sure how you conduct your measurements, but based on both reading your reviews and listening to many of the products you’ve tested, I find your conclusions misleading and, honestly, quite meaningless.
Some may prefer having noise and distortion added to their music. Nothing wrong with that. Happy listening.
Relocated this post here because you would be amazed how many times someone has said almost exactly what you did .
Welcome,
Ever heard about Dunning Kruger effect ?
So you believe just because something is expensive it sounds good?
A preamp should not sound. It should be a wire with gain. The Topping is close to perfect at this. There is nothing to inspire, because there is nothing to hear.
Yes, please do listen… and ONLY listen: level matched, double blind!
Are you suggesting they are wrong?
Electronics like DACs and amps are not EQ devices. If you want to alter the sound, use actual EQ!
So, what makes something high-end audio?
don't bother replying to @vjzapp he just came on here to tell us Amir is wrong.
It's a 'hit and run' post and will not engage in an endless discussion.
Audio is magic ...
It’s not exactly a hit-and-run. I find it interesting that the results don’t quite compare to my actual experience with the gear I tested. Maybe I don’t know what good sound quality is—but I don’t believe that. I’ve tried so-called “perfect-measuring” gear, and more often than not, it sounded lifeless, without soul. That’s my real experience, not just something on paper—especially when the measurement tools themselves haven’t even been proven to provide accurate, real-world reflections of sound quality.
Feel so sick of this and this is false information...
