Did I mention that even though I'm 70, I have to keep resisting the advances from Sydney Sweeney?
Yesterday, on an entirely different forum, I learned that if you make a typo in her name, you get Sydneys weeney.
What I’m wondering is whether the measurements suggest that the amplifier could indeed result in audible colorations on a loudspeaker versus a good solid state amplifier.
Agreed.Yes, the measured frequency response swings clearly show that this amplifier will add coloration compared to a typical solid state design. Because it has high output impedance and low damping factor, the amplifier effectively forms a voltage divider with the speaker's changing impedance, causing level shifts by several decibels across different frequencies. These deviations, on the order of 3 dB or more, might be audible, potentially giving the amplifier a characteristic voicing that reflects the speaker's own impedance curve rather than simply amplifying the input signal.
One thing to have a listen to someone else's system and be intoxicated.
Different when you listen to it every day and eventually the same colouration plastered across every recording starts to grate.
I agree, it's not a one size fits all thing, sometimes it works - in the right situation and if it's subtle. A lot of the time, it isn't but it may still impress on a short audition.I don't think all types of coloration will necessarily give “sameness” to everything played, as different types of music and tracks will not have the same amount of energy over the frequency range.
Some coloration may just add that little extra that makes sense things sound more natural to someone’s ears, in a similar way as some people may like a little bit more energy in the bass than other listeners. That doesn't mean that the higher amount of bass will necessarily introduce “sameness”, it may instead just make most of the music sound more balanced in general to that person.
The amount of bass is just one example, it can as likely be other things like a BBC dip that takes off a little edge that makes things sound less fatiguing over time, or maybe an tube amp that technically may be inferior but brings the right type of distortion to everything for some listeners without necessarily making everything sounding the same, again because different music productions don't sound the same, to begin with.
I always think of this as "the speaker is playing the amplifier"I’ve mentioned elsewhere my anecdotal experience of listening to a pair of small floorstanding speakers at my friends place, powered by a 300 B tube amp. I found myself intoxicated with the sound. In a way that I did not get from when they were hooked up to a Hegel solid-state amplifier.
I see that the amp has been measured, and since I’m not good enough at this stuff to confidently derive any conclusions, does anybody want to take a look at the measurements?
Excerpt:
Here we can see significant deviations of about 4dB from 4 ohms to no load through the flat part of the audioband (100Hz to 10kHz), reaching as high as about 6.5dB at 20Hz. This is an indication of a very low damping factor, or high output impedance. The variation in RMS level when a real speaker was used is about 3.5dB through most of the audioband.
To expand on the Lybra’s frequency response when using a real speaker, the chart below . . .View attachment 417756
. . . shows the frequency response (relative to 1kHz) using a continuous sweep for the Focal Chora 806. Again we see deviations of up to 3.5dB within the audioband. It’s important to mention that deviations of this magnitude would be clearly audible, giving the Lybra amplifier a “sound” that would change based on the characteristic impedance curve of the speaker it’s connected to.
Do folks here concur?
That output resistance may well be frequency dependent which would be hard to simulate with a fixed value resistor.If Matt wants to try it for himself pretty easy. Put a resistor of comparable value to the output impedance in series with his speakers
Well lucky for me I have no interest in simulating such an amp, but Matt may. Every SE tube amp, even a para-feed design like this one, was a circus-like caricature of the input signal. One could always use it as a preamp driver feeding a real power amp for the sound if one needs more than 15 highly distorted unruly watts.That output resistance may well be frequency dependent which would be hard to simulate with a fixed value resistor.![]()
I've described recently an audio show I went to which was basically a bunch of enthusiasts filling a hotel with their home systems. A massive mix from FOSI powered budget systems, through all the audiophile fantasies you could think of. I'd say roughly 30% tube powered.These tube amps are toys for (rich) boys and requires a belief system ....
I missed your show report somehow. One year I went someone was attempting to use single ended valve power amps with some Focal towers and that didn't really work out, but otherwise you're right - speakers and rooms. Even vinyl vs digital front ends are at best a minor change.I've described recently an audio show I went to which was basically a bunch of enthusiasts filling a hotel with their home systems. A massive mix from FOSI powered budget systems, through all the audiophile fantasies you could think of. I'd say roughly 30% tube powered.
Every room sounded different. But the differences between any two tube powered rooms, were just as significant as tube to solid state.
Or vinyl to streaming, or streaming to CD, or tape to vinyl, even cassette to digital etc etc.
I'm 100% convinced audible differences were all just speakers and rooms. Everything else was audibly undetectable when the speaker and room were also changing.
I dont understand any, im not an engineer. However, i do believe i have some of the best ears and eyes in the business. My tragedy is that in most cases i pick apart sound and vision instead of enjoying the music and picture. Im always on the quest to find something better. Ive been buying and selling gear since i was 13 years old. I'm 52 now. Still searching and loving every minute of it. Thats why i love these sites and respect the opinions of all.
I love that Amir is into audio and takes the time to do this. I find it interesting.
To answer your question, what i do UNDERSTAND is the ARCAM AVR390 is better than any Denon receiver. I will never buy another Denon regardless of what any charts say.
Asking for better performance would be akin to ordering a drop forge when all you need is a tack hammer.Likelihood is that the DACs are all pretty much dead flat in frequency response and have very low distortion & noise, so I would be hard pressed to hear a difference in them. Once measurements get very good, then getting better does not necessarily translate into better sound quality.
The technical details of the impedance are unimportant. All that matters is that some frequency response coloration exists, even if barely audible.That output resistance may well be frequency dependent which would be hard to simulate with a fixed value resistor.![]()
I can't help but love Matt's persistence. I think he knows where ASR stands on this.
