Alright, I will kick this off!!! Thanks
@amirm for setting this up.
First, I believe in measurements. Every gear I buy I need to look at measurements if available. I own the Topping D90SE, because it measures the best, the reason why I brought it, amongst the functionality and the fact that it was on sale. However, I didn't keep it because it measures the best, because I thought it sounds terrific. I am a trained EE, albeit non practicing. As an engineer, I say, you need to measure it, in order to build it.
Also let me get out of the way, there are legit snake oil out there and you know what I am talking about.
But is measurement for electronics the end all be all to guage sound quality?
If two amps measured exactly alike, but they are from different manufacturers with different design, will they sound exactly alike?
Can one buy an amp or DAC, just by looking at the measurements without any audition and know that it will sound like any other amp or DAC only less or more distortion?
If so, why are there so many people not have the Benchmark AHB2 and LA4 and the Topping D90SE combination (budget and use case functionality aside). After all, they measured the best. Yes, yes, some will say because, I need more power (you can bridge the Benchmark into mono btw), some will say I need some other functionalities, etc etc.
Why does x SINAD, y THD and z SNR matter when your ears likely can't tell the difference once you hit a certain threshold? Is it for bragging rights? A peace of mind?
These are honest questions, maybe a bit exoteric and philosophical, but honest questions nevertheless.
