No. At Benchmark we are not interested in determining how bad a defect needs to be before it can be heard in music.
Then your article needs extensive re-writing, because it emphasises music as if you are interested in it.
Instead, we aim to reduce noise, THD, phase errors, and frequency response errors to levels that are inaudible (even when using test tones).
Err, doesn't everyone?
Music can hide many defects, but these defects may be revealed by the right piece of music. Running these tests on music would be a long and arduous task. Inaudibility on a few music test tracks does not prove inaudibility. Instead, you need to find a music track that proves audibility.
You can never prove inaudibility using music tracks. You can only prove audibility.
The fact that audibility with a pure tone was confirmed is enough to suggest that we should avoid this particular distortion problem.
We should avoid all distortion problems that exceed audibility thresholds. And frequency response problems that exceed audibility thresholds.
If it can be heard with a pure tone, there is probably some piece of music somewhere that will reveal the same defect. After all, a musical recording could be a series of pure tones.
Honestly, and I mean this:
big deal. "Probably"? "Some piece"? "Somewhere"? "Could be"? I am reminded of the mp3 at 320 kbps audibility debate: yes, there will be the odd moment of music, probably, somewhere, could be, that will be audibly different to PCM in an ABX...but too many people claim that it sounds audibly inferior all the time, and cite some tone test as their evidence.
John, I am not sure that you entered the discussion with the correct understanding of what the core misunderstandings are that need repeated correction in threads like this. For example:-
- Nobody here thinks that all amplifiers sound the same. So, there is no need to provide evidence that some sound detectably different. It is accepted that some sound different, because their response or distortion levels exceed audibility thresholds.
- Some people here think that amplifiers with excellent measurements sound significantly different. You entered this discussion in reply to a new member making his third post. His first post was largely a claim that class A amplifiers sound audibly superior in the bass and the treble to all other amplifier classes, and his evidence was his sighted listening to music. His second post was that one watt does not equal one watt, citing Pass amps, clearly meaning class A amps sound better 'at one watt' than class AB and class D, and do so in sighted listening to music. His third post said that (his) sighted listening perceptions are important because there are things that are
immeasurable (and sighted listening will detect these). He added that Class D gives him a headache after 30 minutes of use because of the harshness of the treble, and that Class AB has the same issue of harshness in the treble but to a lesser degree. When he was challenged on this
third post with a request for evidence,
that's when you chipped in and said you have the evidence.
If you read what you were responding to, it was a request for evidence that immeasurable things are audible in sighted listening to music.
