The distortion produced by the other amplifier is typical of many class AB amplifiers. It is rated at 0.02% THD+N with a SNR of 105 dB. Rated output power is 150 Watts into 8 ohms. 0.02% THD+N is -74 dB near full output.Wow John, that looks like a ton of distortion on the competitor's amp! Are you saying there are no other options outside of your amps and Class A?
Seriously, I am trying to visualize the scale on your scope trace, is that thing just broken? Is it even close to typical?
Just asking since there are many ways to make an amp sonically differentiate, and this is one that will stick out especially as volume is reduced, right?
This means that the THD is -74 dB relative to a high-level signal while the noise is 105 dB relative to maximum output. Like many class AB amplifiers, the actual amplitude of the THD does not change much with signal level. At 1 Watt, 0.1 Watt, and 0.01 Watt, the THD is still about -74 dB relative to the rated output of the amplifier. In other words, the amplifier distortion was always produced at about the same level (due to the fixed-level push-pull crossover distortion of the output stage). This distortion level was high enough to produce a distortion SPL of 14 dB at the listening position when using speakers with an 87 dB sensitivity. This is not unusual in any way. This test clearly exposes the shortcomings of traditional class AB amplifiers.
See more information about these measurements.
The distortion residual waveforms for both amplifiers have exactly the same scale factor. The trace for the distortion residual is boosted by 60 dB relative to the trace for the output waveform (top trace). There is a 35 dB difference in THD between the AHB2 and a typical class AB amplifier when operating at 0.01 dB. This is a huge difference and the difference is clearly audible at low test levels.
The THD from the traditional class AB amplifier was 14 dBSPL at the listening position and, in contrast, the THD from the AHB2 was -21 dBSPL. 14 dB above the threshold of hearing vs. 21 dB below the threshold of hearing.
Keep in mind that these differences we clearly audible through a set of speakers!
