Master Thread: Are Measurements Everything or Nothing?
As regards scientific inquiry, there is no such thing as an "uncomfortable" question. Discomfort indicates emotional involvement. That's not science. We need to separate the sword from the swordsman.
There is discomfort when things are questioned.
wow. solid argument (not). ad hominem's are always weak but fairly common here. uh, huh... it's a salient point, if one can't hear it, it doesn't matter. Are you typing while on a treadmill or exercise bike? Perhaps while at a concert? Time to go walk my dogs...
Respond to mild ad hominem with a retort ad hominem? Weak argument!
Most of us are aware of - and respect -@SIY 's experience, expertise and credentials. What is your background in relevant fields? You seem to believe many things that go against the findings of the audio sciences. Have you successfully challenged any of the works and findings of Toole & Olive?
I'm referring to hearing. Auditory thresholds which definitely change and varies among individuals. I was responding to this:
ofer said:
"Below well-researched limitations of human hearing." Something that has stilll not been addressed in any hifi measurements I've seen and should be. What may be important equipment measurements for a 20 yr old may not be in a 60 or 70 yo.
What do you mean by hifi measurements? We know the effect of estrogen on hearing and can characterize hearing across the population. We can measure any individual FR sensitivity. We know thresholds of sensitivity to distortion and how that is effected by behavior.
I work at a university so have at home access to many databases and have gone down the rabbit hole of scientific literature. There is a lot of it about any aspect of hearing. Auditory memory structures were especially interesting. If you are US based and have a public university in town, you can use their libraries. Though it can be intimidating as safety precautions now mean getting a pass at many. So if you have a particular hearing element you are interested in, you can likely find the original research if it isn’t on Wikipedia.
Let’s get deeper. Stationary random signals have a spectrum which is continuously distributed with frequency. This is in contrast to stationary deterministic signals, that are made up entirely of sinusaidal components at discrete frequencies. Let’s be exact, if we ask the others to be.
This is true, but because we force periodicity, in reality the spectrum is still discrete for signals of finite length. Admittedly the frequencies are spaced close enough that we can approximate it as a continuous spectrum (the one minute sound capture I mentioned earlier will have frequency components spaced 1/60 Hz apart), but if we want to be exact...:cool:
Totally understand your preference for extra harmonics, but of course, you would not want your source component to do anything but be neutral.
Uh-oh. I also listen to plenty of vinyl.
I want all the wrong things, apparently. :-)
which is another variable that should be considered. it is not static (pardon the pun)
But we know where the right tail is, so that is a practical extreme. (search, for instance, ISO 7029. And be humbled, with respect to this conversation, if you are over 30)
People with a certain preference DO want/prefer anything but neutral and gives them more enjoyment. The latter is what music is all about in the end.
That said... I prefer 'good enough' reproduction gear when listening to music.
Well enough measuring gear does that for me but even when it does not measure well I can still thoroughly enjoy music with it unless it is really broken or the music is not my taste or recorded well enough.
Yep. Horrifyingly enough, I also enjoy music through our smart speaker, my car stereo, my desktop computer and even from my iPhone's speakers.
Nothing wrong with anyone seeking accurate equipment, but if in the end it's not about how much one enjoys listening to music through a system, I'd wonder what it's all for.
fight fire with fire. Live by the sword... No, I hold several advanced degrees in science but not directly related to audio products. Anatomy and physiology of hearing, yes. So I believe my question is valid and based on expertise. Do need me to cite some studies on the effects of aging on hearing?
This is also true in the analog domain to ? Is it not . There is some flawed beliefs that analog has infinite resolution ?
Absolutely. Any system that produces, transmits or receives a signal is bandwidth limited either electrically, mechanically or both.
It's easy: The older you get, them more f¤¤ked you are, and the less you have to worry about the things your tweeters are handling ;)
I am talking about how hearing relates to measurements of equipment. eg, "this amp produces distortion at this frequency but can't generally be sensed by those over 50." or this "defect would be inaudible to most over 40". Likely much more important consideration than what DAC to buy for most consumers. If one is attempting to recreate a concert experience for example, their hearing thresholds are the same at the concert or in the listening room.
I suppose, but, since it is trivial to get electronics that are transparent to 6 year olds (when the HF hearing starts to be differentiated and decay), why not get electronics that would be transparent to you and anyone else who might come to your house. Again, we know these limits, and there is affordable equipment that surpasses them.
Speakers, as always, are more complicated.
I did once suggest this thread be named something more falsifiable, such as "can measurements describe everything that is audible to humans"
That is one area it would be nice to see more directly in reviews. Having to extrapolate from the studies to their implication for audio products can be very difficult. At least for me.
most of my friends are close to my age. Most of their kids don't like my music. Our parties are generally loud enough that it doesn't matter. I'm thinking particularly about the recent Denonx3700 review. Are the defects found relevant to everyone?
Can you reproduce the original [music] waveform from its Fourier Transform?
Yes, seems to work for me.
Here's 30 sec of left channel of "Blågutten / Quiet Winter Night / Hoff Ensemble" from 24/96 file that was available on http://www.2l.no/hires/ (sadly, not anymore):
Code:
sox "2L-087_stereo-96kHz_06.flac" left.flac trim 0 30 remix 1
Using octave we can do FFT:
Code:
[X, Fs] = audioread("left.flac");
Y = fft(X);
save left_fft.txt Y;
exit
We get a bunch of complex numbers:
Code:
]$ head left_fft.txt
# Created by Octave 5.2.0, Wed Dec 28 20:03:53 2022 CET <danadam@ubuntu>
# name: Y
# type: complex matrix
# rows: 2880000
# columns: 1
 (-331.73065268993378,0)
 (30.937272302294723,-13.218130854760776)
 (25.130550944365645,-54.867404060761906)
 (-19.95362865681485,0.96937455479392065)
 (27.960966137448651,-18.215475665983263)
Back in octave we can plot amplitude of this FFT:
Code:
load left_fft.txt
Fs = 96000;
L = length(Y);
P2 = abs(Y/L);
P1 = P2(1:L/2+1);
P1(2:end-1) = 2*P1(2:end-1);
f = Fs*(0:(L/2))/L;
figure(1)
plot(f, 20 * log(P1) / log(10) )
title('Amplitude Spectrum')
xlabel('Hz')
ylabel('dBFS')
pause
Still in octave we can do inverse FFT to recover our waveform:
Code:
load left_fft.txt
X2 = ifft(Y);
audiowrite("left_back.flac", X2, 96000, "BitsPerSample", 24);
exit
Finally, using sox we can subtract one file from the other and check peaks:
Code:
]$ sox -m -v 1 "left.flac" -v -1 "left_back.flac" "null.flac"
]$ sox null.flac -n stats
DC offset   0.000000
Min level   0.000000
Max level   0.000000
Pk lev dB       -inf
RMS lev dB      -inf
RMS Pk dB       -inf
RMS Tr dB       -inf
They are identical. All files available at the mega link mentioned earlier.
Obviously a very reasonable question!
I'll give my answer, and it will appeal to why I continue to use tube amplification.
But first, there are two different questions: 1. Whether some distortion is audible. 2. If it is, why would you want it?
I'm not offering in this post an answer to #1 because only #2 would be relevant to answering your question. So it's up to you if, for the sake of argument, you accept that my tube amplification is distorting the sound enough to be audible, so we'd talk about why that might be desirable at all. (I'll be referencing my tube preamp, which I have identified in blind tests against my Benchmark preamp).
Ok, moving on:
I can switch between my Benchmark preamp (utterly neutral solid state) and my CJ tube preamp at the click of my remote, while listening. I had a typical experience last night, listening to Talk Talk's track Happiness Is Easy. For many years that track has always produced an extremely palpable sense of the drum kit through my system. I could close my eyes and the drums would be easily sensed as fairly solid sounding. But listening through my Benchmark LA4 (a newer addition to my system) it just wasn't "there" as much as I was used to - the snare, the high hat, the kick drum, the toms, were all super clean and clear, but didn't have the density. I switch over to the signal going through the tube preamp and...boom!...the drum kit just became that much more solid and dimensional sounding, the sense of a solid snare being hit, solid toms, solid high hat. It was now easier for me to slip in to the illusion of hearing right through the recording to 'real drums.' I'm talking subtle, but to my ears significant.
It wasn't just the drums, it was everything: the acoustic guitar, the keyboards, percussion, everything took on this added density and solidity to my ears.
This is a fantastic recording, and yet it took this step forward in realism for me.
I find this to be the case on every single recording. Whether it's "audiophile level" recordings of vocals and accompaniment, or excellent orchestral recordings,
this "everything sounds more dense, there, palpable, solid, real" applies. String sections sound less wispy and see through. Horn sections less ghostly, more dense. It applies to pop recordings. It applies to much of my beloved electronica, where all the dancing synth parts, sequencers, synth drums etc take on more corporality. I find it a very gratifying effect for all music.
But it's a trade-off. I do lose something too. Through the CJ preamp I lose a bit of clarity and nuance, and there is slightly more homogenization. Slightly.
So the question is always "which do I find more gratifying, the slightly better retrieval of detail from the recording, including some timbral nuance from the Benchmark preamp? Or do I choose the added sense of "thereness" and believability with the tube preamp? I go back and forth, but often when I really want to sink in to that stronger illusion of hearing solid instruments and voices, I choose the tube preamp. Which, again, works for any recording, high quality or low quality.
Cheers.
I really have no objection at all to your reasoning. As I understand it, it is your perception that your tube-amp is coloring the sound, and that this in your opinion sounds better. Fair enough. I myself have a tube-power amp that I listen to sometimes, and it can sound nice. But I usually prefer my purifi class D stage. But one thing that comes to my mind is that acoustic classical music never sounds as well defined and precise in real life as it does on recordings. The recordings are in this respect ”better than reality”. When played and amplified by a tube-amplifier, I wonder if this type of amplifier, ie tube amplifiers, takes away the ”edginess” (in lack of a better word) from the recordings and in some way makes the musik appear with a higher degree of realism. I do not know. This is a bit of a speculation.
if there is much transparent equipment available, it begs the question, what is the point of reviewing in depth at all? The reviewer could just say "it's transparent" and be done with it. I don't believe I've ever seen this written. A list of transparent equipment would be invaluable to electronics consumers.
RAISES or POSES the question (sorry, pet peeve of mine. "begs the question" has a specific meaning).
I've seen the term used a lot here. There are also features and price to consider. With that said, I've heard the term transparent a lot. There IS an argument that the noise and distortion can accumulate through the chain of electronics, and therefore minimizing it at every step is worthwhile. And, of course, there is a great thread on audible thresholds.
