I realise this may be controversial but here goes..
I’ve been a HiFi man all my teenage and now adult life – I’m now 61.
Like the rest of the world, where I never thought to buy a standalone DAC, in this streaming age, I now need to.
And here’s where I have encountered the whole “measurements vs sound” debate, with fiercely entrenched views
So, because it interests me, here is a perspective.
There is a lot of guff about the difference in sound of one cable vs the other.
Even specialist power supplies – I remember doing AB comparisons with a Cyrus Amp with/without the smoothed power supply – there was no audible difference (that I could detect anyway)
However, I cannot agree that if two devices measure the same, then they will necessarily sound the same (in this case DACs)
Why?
I come from an engineering background in silicon chip manufacturing. Here you measure everything to death, and then some more. All kinds of real and derived parameters, correlations between one and another etc. Hundreds of measurements on stock components to authenticate each wafer is what is wanted.
But – Your vision is only as good as the parameters you measure. You absolutely cannot fully describe the behaviour of an electronic device by measurements alone.
Sometimes, despite the standard components on a wafer measuring exactly as required, the product chip fails to work as expected – because measurements only give you a veiled picture of things.
The point is, for all the measurements you can think of doing, (and those done on this site look pretty comprehensive) there are always some characteristics that you have never thought of measuring, or that you simply cannot get at to measure.
Or it can be a eg a correlation between parameters at particular voltages that causes two seemingly identically measuring products to end up functioning slightly differently.
So a set of measurements (on a particular DAC) that looks the same as those of a different DAC absolutely cannot be a guarantee that the sound will be the same.
So I love the measurements done here, but they are not the full story - would be great if they were supplemented by blind testing AB sound checks.
