I would not contradict our new AI overlords.The correct representation of a hand isn't five fingers, though.
It's four, and the thumb.
I'll be neutral and request we all leave the purely philosophical pondering and at least try and stick to the usual arguing about measurements telling (or not ) the whole story and all that jazz .So let's just briefly consider your hypothesis without the philosophical bent as a working scientific one. It clearly fails.
Why? Because blind testing (and much of the actual scientific work is not ABX) tells a coherent story. The vast majority of people give the same responses. If there was a "bias" it would be held to different strengths, or not at all, then the story told by blind testing would be incoherent. The blind testing tells us something about human hearing - not bias but properties. It's actually pretty pointless to ask why blind tests are wrong, and certainly a problem to do so in isolation from studying sighted response.
A reasonable question for study in the area is the opposite one: why does the coherent story of blind testing break down when testing is instead sighted?
I didn't think the fact that it "ressembles" some subjectivists claims was enough to make it "suspicious"
I agree with everything you said, so I think I have failed to make myself understood.
I had in mind the "sighted listening vs blinded listening" debate that happened here. What I got from it was something like that:
Bob says "I like speakers A a lot more than speakers B" in sighted conditions.
People (here) would apparently reply: "no but you can't trust your experience, it was biased by the fact that you could see the speakers".
to that I question: "wouldn't you be differently biased in blind listening?"
Maybe it helps when I say that with blind testing it is not just not seeing speakers but rather having no clues about what is playing. Of course you can't get rid of all clues. You are just testing for preference. It is not for gathering scientific info.
In a perfect world - but as I pointed out, doing back to back blind comparisons in one's own home isn't likely to happen due to the practicalities.
More pertinent, yes, but I suspect the answer again would be 'not many'.Perhaps it's more pertinent to consider how many of us actually used the results of properly conducted, statistically valid blind tests of loudspeakers when choosing our own.
Agreed.What's simple is tempering or qualifying one's claims about the device's sound, based on knowing the flaws of sighted evaluation.
So simple, really. But apparently so hard for many.
Maybe if we had a show of hands here to see how many did actually select their speakers by doing a blind comparison? Did anyone?
And many of these exist supporting most of the basic beliefs you see on this site. Unfortunately, most are behind the AES paywall (or, for audiology, other paywalls), but @amirm has summarized quite a few on the site.
It can be when doing scientific research for preference.Please stop writing this. Testing for preference absolutely can be an instance of 'gathering scientific info'.
Of course; and almost no one does controlled tests of audible difference at home, either.It can be when doing scientific research for preference.
It hardly is when comparing 2 speakers for personal preference to make a purchase decision.
IME about 99% of people buying speakers is simply comparing them and not do any blind testing. They end up buying the one they prefer based on how it sounds and looks.
They usually don't do any blind listening tests just for preference for the sake of knowing which they prefer and not buying them.
But I want to always emphasize on ASR that preference CAN be (and HAS BEEN) subjected to scientific measurement, because some posters here seem to believe that because preference is 'inviolable' (in the sense that there is no 'right' or 'wrong') it is also outside the purview of science.
A lot of luxury goods, guitars, clothes, cigars, wine, etc. Consider the intrinsic value of a Goyard Bag.Why is it that stereo speakers are treated like a spouse? Can you think of anything else people make such a fuss over?
Point 2 should really make the point that you can be wrong about the reasons for your preference.I strongly agree.
Preference certainly can be and has been studied scientifically. It’s studied all the time.
But the sharpen up the point even more, I think I would put it:
1. It is true to say there is no right and wrong with regard to preference, when we are talking about someone’s actual preference.
However
2. It’s possible to be wrong when making statements of preference. You can be wrong in stating what most people prefer. You can even, to a degree, be wrong about what you yourself prefer!
You may think you prefer the sound of one cable or another, but it can be discovered through testing that you can’t actually tell them apart.
You may think you prefer A loudspeaker over B, but it can be discovered through testing that you are wrong and that you actually prefer B. (At least sonically. You would not be in fact wrong about what you prefer under sighted conditions, but could be wrong in what you believe about why you prefer the speaker, believing you prefer simply the sound itself, when other factors actually are influencing your preference).
I did.Perhaps it's more pertinent to consider how many of us actually used the results of properly conducted, statistically valid blind tests of loudspeakers when choosing our own.
Good answer: but I'd add that without the preference testing, we wouldn't know which speakers to choose from a Spinorama or any other frequency response measurement. Choosing an earlier paradigm such as flat in-room wouldn't have sounded any better because of a better testing method.I did.
But I'll also say this: I think it is fair to answer that making intelligent readings of high-grade Spinorama tests of speakers is a rational and reasonable proxy for conducting blind tests of the speakers themselves.
That was one of the major outcomes of all that research: if we understand the research properly, we understand its value to our own decision making. It's actually a better indicator of our preferences for the sound waves themselves than if we had done sighted listening to the speakers in person.
cheers
We still get (by necessity) that final exercise of sighted listening, of course, when we actually use them if not before purchase. So I'd still say that the research we have is the best starting point, rather than necessarily the final act. If that sighted response is overall negative, we still have to move on...
I would put myself in that camp that I don't particularly trust my ears. I've done enough blind testing of different types and I'm usually disappointed by my individual performance and ability to identify or distinguish between things.There have been people on this forum
who’ve said they are seeking high Fidelity equipment and they don’t actually trust their own ears to make that decision. So even listening, in sighted conditions they don’t trust their sighted impressions (presumably even if negative) and would go on measurements.
