Master Review Index
If you wanted to find the ranking of speakers, where would you go in the ASR website? Because if it wasnt for this thread, new people to ASR would have a hard time finding things.
I don't think there is a global ranking of which speakers are best.
JSmith
Don't place too much importance though on the preference score;
You shouldn't focus on preference scores. It was only intended to help naive people interpret spinorama measurements and reduce it to a single number.
Buy a loudspeaker based on its spinoroma measurements and how loud it can play without distortion for your application. Look for flat, smooth on-axis well maintained off-axis and smooth directivity.
JSmith
Ahh I see, Thank you. I do wish there was a way that the SPINorama website could be imbedded in the ASR homepage because the SPINorama has a more through ranking.
I'm only seeing a list of 57 headphone reviews. Where's the rest of them?
If I search for "Wiim" the Pro Plus review is not listed.
True;
JSmith
Welcome to ASR.
I see 159 entries under headphones in the review index, which appears to be up to date as the last review was the 1st of July for the 1MORE Penta Driver IEM Review;
There is also the reviews page;
JSmith
I have gone to the master review index, which tells me there are 159 headphone reviews, but I can only access the latest reviews from there. Shouldn't there be a list somewhere of all 159 reviews that you can just click on?
Each listing has a link to the review on the far right. Just to make sure, are you scrolling down the list completely? At the bottom one can select the number per page etc.? The list can also be sorted by the column headings, such as date.
Are you on a PC or mobile device?
JSmith
JSmith
I found it now. I didn't notice the three horizontal lines at the top left of the screen that i had to click first. Then I have to click on the headphones tab that appears before I can see a list of the reviews. It is easy to miss on a mobile android device, but it is more visible on my laptop. Thanks for all your help.
Anyone know what happened to the database?
Master Review Index
The database is down again. Anybody know what's up?
Thanks.
... Nothing has changed since
So it's not down again, it's still down.
