Master Preference Ratings for Loudspeakers
edechamps
London, United Kingdom
If we can agree that PIR with slope of 5 deg would intuitively sound "bright" and the one with slope of 45 deg would sound "dark" we can also agree that indicates there is an optimally sounding region of slopes somewhere in between. :)
I think we discussed this before, and I'm still unconvinced. It's really not obvious to me that an idealized perfectly omnidirectional speaker, with both ON/LW and PIR perfectly flat and horizontal, would sound "bright". I'm not saying it wouldn't, either; I'm saying we don't know. So far I haven't seen a persuasive argument that the perception of overall balance is determined by PIR as opposed to direct sound.
Blumlein 88
I think we discussed this before, and I'm still unconvinced. It's really not obvious to me that an idealized perfectly omnidirectional speaker, with both ON and PIR perfectly flat and horizontal, would sound "bright". I'm not saying it wouldn't, either; I'm saying we don't know. So far I haven't seen a persuasive argument that the perception of overall balance is determined by PIR as opposed to direct sound.
We need testing of those MBL speakers. Both Klippel and controlled listening.
M
MZKM
Land O’ Lakes, FL
Since the scoring would rate them poorly due to the PIR slope, a bunch of controlled listening would be needed to be done to see if in this extreme case, if the PIR slope doesn’t matter.
https://www.stereophile.com/content/mbl-101e-radialstrahler-loudspeaker-measurements
QMuse
I cannot offer any kind of proof, my opinion is formed/based on my limited experience with EQ-ing different kind of speakers and noticing the difference.
IME it is the slope of the PIR that dictates the LF/MF/HF tonal balance that we actually hear.
Blumlein 88
I also wonder if we had a slope built in via EQ how it would score in blind comparisons. You could use a top scorer and rate the MBL by comparison using a MUSHRA type evaluation. Another interesting comparison would be the MBL flat vs MBL with sloping EQ.
QMuse
Let's not forget that the absolutely flat anechoic response would result in an inherently sloped PIR at app 9-10dB over the 20Hz-20kHz range.
napilopez
NYC
Have you applied 1/12 smoothing as warned by REW to avoid anti-aliasing before doing this export?
I did not. When I tested computing the scores with my own measurements I found using 1/12 smoothing gave too much of a boost. Moreover Toole describes Harman as using "unsmoothed, 200-point, log-spaced stepped-tone anechoic measurements (1/ 20-octave)" so 24ppo unsmoothed seems like the closest approximation.
QMuse
Well, when I think about it I don't really see how anti-aliasing would be an issue here, but 1/12 smoothing actually would as it would indeed boost the score. So yes, skipping smoothing is a way to do it. :)
M
MZKM
Land O’ Lakes, FL
I have tried 1 speaker with 1/24 and 1/96 smoothing and the 1/96 actually scored higher, my thinking is that since there is more data between the min/max, the averages get brought closer to neutral.
QMuse
My guess is that it would vary from case to case, but the difference should be small.
MattHooper
That would be fun, though even when I had my MBL speakers I would be loathe to ship those delicate/expensive speakers anywhere once I had them.
I've mentioned before, anecdotally as an owner: my MBLs did not sound bright. (I don't like too bright sounding speakers). But my room is not an overly "bright/reflective" sounding room to begin with and I tend to situate myself a bit closer than the norm for more direct sound.
napilopez
NYC
Do you mean smoothing or points per octave in the data? REW only does 1/48 smoothing at the minimum. When exporting data, you have the option to select both the points per octave and the smoothing.
Assuming you meant PPO, that echoes my experience with my own measurements: stronger smoothing makes the score better, but lower PPO actually makes the score worse. I think the most I saw was a .2 change
M
MZKM
Land O’ Lakes, FL
I just finished calculating the scores (and generating the Spinoramas) for all 13 speakers from the sample. and besides 2 that scored <1, I can see that the scores in Olive's Measured vs Predicted plot do line up pretty well.
On another note, I just realized my Radar charts have been incorrect for LFX thus far. The way I do it is take the best (results in a 10) and "worst" (results in a 0) and then use those to turn whatever scores a speaker got into percentages. Well, I just realized that I put ~2.48 instead of ~3.48 for the worst case for LFX :facepalm:.
QMuse
I also understood he meant PPO. :)
pierre
Switzerland
AHA! I've got the list of Paper 1 speakers. Journalist skills coming in handy.
Here is the article from the August 2001 edition of Consumer Reports used to select the Paper 1 speakers:
Along with brief descriptions of each:
To save you the time reading, by matching the 23 bookshelf speakers above to Table 1 in the paper, we can isolate the ones used in the study.
Here they are as ranked by Consumer Reports. In brackets is their 'Accuracy score' based on CR's flat sound power model, as well as CR's "Bass Handling" score. In the article, CR says the overall ranking is mostly based on the accuracy score, with some weight given to " the ability to play bass notes very loud without distortion."
  1. Pioneer S-DF3-K [89/Excellent]
  2. Bose 301 Series IV [89/Very Good]
  3. Cambridge Soundworks Model Six [88/Very Good]
  4. BIC America Venturi DV72si [90/Good]
  5. Infinity Entra One [87/Excellent]
  6. JBL Northridge Series N28 [85/Excellent]
  7. Polk Audio RT15i [88/Good]
  8. Yamaha NS-A638 [83/Excellent]
  9. Bose 141 [89/Very Good]
  10. JBL Studio Series S26 [82/Very Good]
  11. Infinity Interlude IL10 [76/Excellent]
  12. Klipsch Synergy SB-3 Monitor [76/Excellent]
  13. KLH 911B [79/Good]
And here is how they actually ranked in Olive's double-blind tests, along with images for a visual. In brackets is each speaker's previous ranking for quick reference.
  1. Infinity Interlude IL10 [11]
  2. JBL Series S26 [10]
  3. Infinity Entra One [5]
  4. Pioneer S-DF3-K [1]
  5. JBL Northridge Series N28 [10]
  6. Klipsch Synergy SB-3 Monitor [12]
  7. Polk Audio RT15i [7]
  8. Cambridge Soundworks Model Six [3]
  9. BIC America Venturi DV62si [4]
  10. Bose 301 Series IV [2]
  11. Yamaha NS-A638 [8]
  12. Bose 141 [9]
  13. KLH 911B [13]
    (Poor KLH can't catch a break)
So, as we already knew, they are mostly 2-way bookshelves. And unsurprisingly, most of the top performers are Harman speakers. But the one consistent thing among top performers is the use of what appear to be purposeful waveguides.
@amirm , in case you were curious.
P.S. I see a pair of Infinity IL10 for $79 a pair on eBay. Just sayin'
Thanks. I imported them.
M
MZKM
Land O’ Lakes, FL
In terms of my Performance : Price graphs, I currently have 3 categories:
• Passive (blue)
• Active (red)
• DIY (green)
It is just a matter of time (hint hint) until Amir measures an active speakers with digital connections (Bluetooth, USB, optical, etc.). Since this should be separated from those that only accept analog connections, any ideas on the colors (and naming)?
