I count 182 audio equipment reviews (with measurements)
ASR has moved audio science forward like nothing I've seen!
thanks Amir
Bill
thanks Amir
Bill
No unfortunately.Has anyone ever sent you a Sony WM1A / WM1Z to review?
I think someone has donated one. I will have to look....Would you ever review a Schiit Magni 2?
We have debated this before and consensus has been that I should not do that. Putting that aside, my top picks that come to mind are JDS Labs atom and Massdrop THX AAA 789 headphone amplifiers. Topping DX3 Pro for combo DAC and headphone amp. SMSL SU-8 for balanced dac at bargain price. Octo research DAC8 for multi-channel (or even stereo) dac. Khadas Tone board for a bare board DAC.Can you list some of these items as top picks or a percentage of how good you think the item is. Example siskel and ebert gives two thumbs up, lol
No D50 for single ended DAC?We have debated this before and consensus has been that I should not do that. Putting that aside, my top picks that come to mind are JDS Labs atom and Massdrop THX AAA 789 headphone amplifiers. Topping DX3 Pro for combo DAC and headphone amp. SMSL SU-8 for balanced dac at bargain price. Octo research DAC8 for multi-channel (or even stereo) dac. Khadas Tone board for a bare board DAC.
It is the same price as SMSL SU-80 but doesn't have a remote, nor balanced output. It is a good fit for JDS Labs Atom though from looks point of view.No D50 for single ended DAC?
DX3 Pro as that is what I use in exactly the same situation. Unfortunately there are some reliability issues reported on it so if you go that way, be sure to buy it from Amazon and such for easy return and use it heavily during your return period.thanks for some highlighted picks. I have the Sennheiser 650HDs but prob will buy some higher end headphones soon. What would you suggest to buy that would drive those headphones and also the ability to hook up a good pair of studio speakers?
Bingo and it fits so nicely!It is the same price as SMSL SU-80 but doesn't have a remote, nor balanced output. It is a good fit for JDS Labs Atom though from looks point of view.
If you don't want to go that route, then the combination of Topping D10 or D50 are good with JDS Labs Atom.
Will the DX3Pro work well with a heavy amount of PC Gaming? I hear these units will make the soundstage sound better so that would mean it would at least not hinder my pc gaming correct?
As noted there is no processing in any of these DACs so what the game delivers, is what you hear.Will the DX3Pro work well with a heavy amount of PC Gaming? I hear these units will make the soundstage sound better so that would mean it would at least not hinder my pc gaming correct?
