$79.90 is the current 'in-cart' price for an O-Noorus D1 Pro amplifier at Amazon USA - this price may be a targeted listing.
Amazon suggests that I bundle this "Audiophile" silver-plated power cable with the O-Noorus amp for another $195 .... might have to force fit. :facepalm:
Makes sense to their AI I'm sure. Best to run your $80 amp through a $6000 power conditioner to get the best sound possible.
An option for a center channel loudspeaker with wide horizontal dispersion.
Authorized dealer Accessories4Less dot com, is selling single, recertified, KEF Q1 Meta loudspeakers in Black, with a same as new, 5-year, KEF warranty for $249.
Reactions: MCH
The 'Nobsound Official Store' on Ebay offers the Douk Audio A5 Amplifier without a power supply unit for $58.49 with an additional discount on purchases of more units.
Wondom / Sure Electronics has currently reduced their BRU5 TPA3255 DSP/PC UI Stereo Amplifier reduced to $30 on Amazon US. No power supply is included. This is the cheapest I've seen it in the U.S.
However, DSP programming software, ACP Workbench is included and the USB-C DSP interface is built into the amp. There is a 200+ post ASR thread about the BRU5, its benefits and limitations HERE. An 18-48v power supply is required. I would be concerned about heat at anything above 38v but the chassis is all aluminum and the chip has a heatsink block that is pressed (and gooped) to the chassis bottom.
Because of its always on DSP, it will not be the cleanest quietest amp. I think its about the most interesting one you can find for $30 if you think learning DSP software is fun.
This may be a targeted listing....
Amazon USA is currently showing an 'after coupon' price of $55.99 for the FX Audio FX1602A TPA3255 amplifier with a Pre Out jack, 32 volt power supply unit and a low-profile enclosure.
At Amazon USA, Sweetwater Sound is currently selling the JBL Pro 306P MKII for $119 each and the JBL 308P MKII for $149 each
ASR members have reported JBL is bringing out new, 'MKIII' versions of these active loudspeakers.
Amazon USA is currently selling a TPA3116 chip-based, MONO amplifier with AUX, Bluetooth, and input for USB memory stick for $19.94
Per Slickdeals,
Adorama in New York City is offering a pair of Energy CF-70 tower loudspeakers for $299 after applying a coupon code at checkout.
According to the link below, the Energy CF-70 weighs about 45 pounds each, uses a 3-way crossover and was introduced in Fall 2008.
Per Slickdeals,
Adorama in NYC is now selling the Energy CF-70 loudspeaker for $249 a pair.
Adorama is also selling the Energy Take Classic 5.1 speaker system for $159.
$209 for a refurbished WiiM Amp with 1-year warranty
Back in stock at Linkplay's outlet store on Ebay - with 3 units available as of now,
I appreciate that the USB-A jack on the back panel of a WiiM Amp can be set to be an input for a memory stick or an output for a headphone amplifier with a USB input.
EDIT - I also appreciate the inclusion of built-in power supply units in select WiiM devices like the WiiM Amp.
Only one output at a time – Wiim Ultra (no amp) give more flexibility. But that is a killer price even for use just as a power amp!
Oh no, silver plated. Whoever thought that a good idea... no matter how non corroding the alloy is, it inevitably invokes pictures of grandma's silver cutlery that needed polishing all the time lol
Some good Prime Day deals on (what appear to be) closeout Loxjie and Sabaj products from HiFi Express prime shipped from Amazon.
The Loxjie D60 Balanced DAC is $288 in silver or black. This is the same DAC as the SMSL DO400 ($450-$499) just golfing panther reviewed by Amir for slight cosmetic differences I think.
The Loxjie D40 Pro Balanced DAC at $215 (all time low I think) and is almost identical to the above except for Bluetooth 5 instead of 5.1, a rudimentary display but adding an XLR Balanced Headphone jack along with 4.4mm.
The older Loxjie D40 non-pro goes for $168. It's headphone section is not balanced, but Amir Golf Panthered it in 2022 here.
Most all of their retro Silver Sabaj stuff is discounted a lot. I ended up buying an a20d 2023 for $194...the D40 Pro is probably better but I like the smaller size and nicer display. The SMSL Tabebuia mini passive speakers are down to $165 after coupon. The Wavecor drivers sell for more than that from what I can tell. I wish Amir had spinorama-ed them.
can you give me a heads up if you see blowouts on the loxjie gear again? im in the market. thanks!
There is a good chance the above links and perhaps others from the Amz Vendor Hifi-Express will be discounted on Fall Prime Deal Days Oct 6-7. That is just my guess, I have no inside information.
Amazon USA is offering Prime members a TPA3255 chip-based amplifier for $31.99
It typically sells for $39.99.
The back panel specifies a voltage of 24 to 36 volts and the amp ships with a 24 volt, 5 ampere power supply unit.
