Thanks for the reply there. So by subtracting the Diffuse Field Target from the Harman Target, what is it that you are wanting to show/achieve, what does it prove? It's only showing the difference between the two targets, and you seem to be trying to relate that graph showing the difference directly to graphs of speaker sound power....I'm not really sure how that is possible to compare them, I'm not joining the dots there at all....it seems like apples to oranges. It seems that you're relating them simply because they look similar, but just because they look similar doesn't mean a thing....I'm missing your logical step of why/how you're comparing the two.Sorry about that. I was coming to this as well, Robbo. But got sidetracked by some other stuff.
The diffuse field plots of the 2018 Harman over-ear curve were produced essentially the same way as the sound power plot above in Equalizer APO's Configuration Editor.
You are absolutely correct that the bass on the Harman curve should rise above the baseline. This is true also on a diffuse field compensated plot, because the DF curve is essentially flat below about the 160-200 Hz range in the bass. Without the negative Preamp enabled, you can see above that the compensated plot in the Analysis Panel does indeed rise above the baseline of 0 dBFS.
Just to clarify what's going on above, the raw plot of the Harman curve is the first filter or item in the stack, plotted using a variable graphic EQ curve. The second curve below that is Oratory's new 2021 diffuse field curve, turned upside-down (inverted to the geeks). Both curves are plotted in high precision, using a large number of points or bands The third filter is a Preamp control, which is currently disabled above. (You can tell it's off because its "power button" on the left isn't highlighted in light blue like the other filters.)
The bass level on Oratory's new 2021 DF curve is slightly above 0 dB. So when it's flipped upside down, it adds a small amount of negative gain on the order of -0.3 to -0.4 dB. Which brings the peak bass level on the Harman curve's compensated plot down by just a small amount. Otherwise the peak level in the Harman curve's bass response would be closer to 6.1 dB above the baseline. You can see the difference though after the two curves were combined in the lower right of the Analysis Panel, where it says "Peak gain: 5.7 dB". The area that excurses above the 0 dBFS baseline is shown in red, btw, to warn you that audio in that area could be clipped, because it exceeds the unity gain level.
With the -8.00 dB Preamp filter enabled though, the whole curve falls somewhat below the 0 dBFS clip point, So the bass is no longer red, as shown below.
Since these curves and plots are mostly for my own informational/analytical purposes, and not for actual listening use (at least not in this particular form). And my primary concerns are the overall shape, tonal balance, and slope of the curve, what I'll generally do is drop the curve low enough so it's below the 0 dBFS clip point. And in the case of a diffuse field or sound power plot, I'll usually try to align or normalize the resulting response curve to one of the horizontal gridlines at around 1000 kHz or thereabouts, using the Preamp control. (If I'm in a hurry though, sometimes I may forget to do this.)
The choice of the normalization frequency is somewhat arbitrary though. And sometimes I may try to normalize other parts of the curve, such as the bass instead. It just sort of depends on what I'm focusing on at the moment.
Normalizing to a point somewhere around 1 kHz in the midrange though helps me to better assess how much of a dip there is in the curve at the crossover point of the treble and midrange at around 2 to 2.5 kHz. The level of that dip is particularly important to me because my ears seem overly sensitive in that range. Probably because alot of the pop recordings I listen to are mixed too hot there, because the in-room monitors used for mixing and mastering the content likely have a similar depression there in their dispersion and off-axis response.
It also helps me to gauge some of the differences in the levels between the midrange and bass. And also the midrange and the treble, particularly around 6 to 8 kHz in the low treble. Imo, the treble in that 6 to 8k range on Oratory's DF graphs probably shouldn't exceed the level in the mids at about 500 Hz to 1kHz by too much, or the headphones may begin to sound a bit too bright. (This is just a general rule of thumb though, which may not apply to all headphones or listeners.)
The Harman curve does not represent a perfectly neutral response to my ears btw. But I can go into some more detail on that another time. The main area that I have some issues with though is the lack of air in the upper treble. There is some unevenness in the upper mids as well imo, which leads me to believe that it's possibly also a bit too forward in some spots there. Perhaps around 1.5 to 2 kHz, and maybe also in some other area around 4k or so. This is still something I'm experimenting with though.
The dip in the Harman curve's DF response in the upper mids is positioned a little higher in frequency than a typical loudspeaker's midrange-tweeter crossover. Which tends to be more around the 2 to 2.5k band range (though it can technically occur almost anywhere from 1 to 3 kHz, depending on the speaker's design). The artificial pinna that Oratory uses complicates the response in the upper mids and treble though. So it's not quite an ideal match to the average sound power response of the good loudspeakers. So that's why I use various references, including the measured responses of headphones, to try to get a better handle on what should be going on in that area. I think Ora's pinna can produce both bumps and dips/notches around that whole area though, which may make his plots look slightly off, or uneven, or overly bright or depressed in some parts of that range.
I'll have some more thoughts on diffuse field, and on your other post above with the HD560S plots another day.
That is another headphone I've been looking at pretty closely though lately. Although I haven't tried them yet myself, the new polymer drivers and good bass extension supposedly give those HPs a some wider sounding soundstage than some of Sennheiser's other classic 6-series HPs. Some reviewers also claim that they have a pretty neutral sound. And it looks that way from the graphs I've seen so far. They look like they might be just a bit uneven in some spots in the upper mids and treble though. And maybe just a tad bright around 4.5k or so. Which should be easily correctable with an EQ.
Although the Senn 5 and 6 series headphones tend to have pretty good driver symmetry overall, I've noticed that some of the models in those lines will sometimes appear a little imbalanced in some spots in the upper mids or treble. And it looks like the HD560S may possibly fall into this category as well, due to a little dip in the right channel at around 2k. Based on this compensated Rtings graph...
https://www.rtings.com/headphones/1-5/graph#18492/7903
A feature like this is slightly harder (but certainly not impossible) to correct with an EQ, because it requires a somewhat different adjustment for the right and left channels.
I don't currently have any open back HPs (or Senns) though. And this looks like it could be one of the better options in the Sennheiser lineup in my general price range. So the HD560S is still very much on my radar. There's a local store where I can easily get one, which also helps.
The audio gear I'm currently using is listed in the link in my signature btw.
About the HD560s, yes it's a good headphone, currently my joint favourite with the K702....they are the two of my headphones that do soundstage uniquely & accurately in comparison to my others headphones. K702 is an impressive immersive wide soundstage and has more detail & nuance around female vocals, and HD560s is narrower than the K702 but potentially more accurate spatially within that smaller soundstage. Bass is really good on HD560s, well defined, and soundstage on 560s is certainly wider and more integrated between the two cups than the HD600.....HD600 is terrible for soundstage in my experience, worst of my headphones, but it does everything else really well (apart from average bass). All my experience listed here is when EQ'd to Harman. I would definitely recommend you the HD560s over the HD600. Re the RTings HD560s review, I reckon they had an unlucky sample with poor channel matching as solderdude's diyaudioheaven website showed HD560s to have good channel matching, and if you look at the graph showing the 3 measurements that I posted earlier you can see that there is very close & strong agreement between all the measurements between 100-10000Hz and even above that, so I would expect that would mean that channel matching is also likely to be good.....having said that Oratory said channel matching was average on his sample he tested, but that seems to go against the strong agreement between all the 3 different measurements I showed.
