The physics and thermodynamics of AI energy use:
As a brief reprieve from this wondering discussion, here is an overview of the physics and thermodynamics from Gemini (Google AI) surrounding the energy use by AI.
It would be good if some others here took the input and obtained a response from their favorite AI tool to see if the responses are consistent. I'm not a fan of AI responses in threads but this response seems valuable if you take the time to read and understand it. It's pretty straightforward. (Note: I've attempted to fix some of the formatting in the Gemini response that didn't transfer well.)
Input to Gemini:
Are there other theoretical ways to accomplish the same AI goals that are requiring all this investment and energy use. The net effect is to take a lot of disorder and make it ordered. It seems much of this process is repetitive. Something changes and rerunning the process appears to be required. It's thermodynamics. Bringing order to disorder take energy. There is an energy cost to delete a bit I believe. Has anyone looked a AI and determined the minimum energy to accomplish a task. It would help if we knew where we stood with the current processes vs. the theoretical minimum.
Output from Gemini:
Your intuition matches the foundational physics of computation. What you described is
Landauer’s Principle, and the gap between current AI hardware and the thermodynamic limit is immense.
Current AI architectures are burning through megawatts not because the fundamental physics demands it, but because we are implementing continuous, statistical processes using brute-force, clocked, irreversible digital switches.
1. The Theoretical Thermodynamic Minimum: Landauer’s Bound
In 1961, physicist Rolf Landauer showed that computation itself does not inherently consume energy. You can manipulate and move bits reversibly without generating heat.
Heat dissipation is strictly required when you
erase information (resetting a bit from an unknown state to a known state, reducing informational entropy). The minimum thermodynamic cost to erase one bit of information is:
Emin = KB x T ln 2
Where:
- KB is the Boltzmann constant (1.38 x 10^{-23} J/K
- T is absolute temperature in Kelvin
At room temperature (300 K}, the Landauer limit is approximately:
Emin = approx = 2.9 x 10^(-21) Joules (or approx 0.018 eV)
For or a typical 32-bit floating-point operation (FLOP) involving irreversible logic gates, the absolute thermodynamic floor is roughly 10^(-19)
Joules.
2. Where Modern AI Hardware Stands vs. The Physics Floor
Modern AI accelerators (like Nvidia Hopper/Blackwell or Google TPUs) operate around 10^(-11) to 10^(-12)
Joules per FLOP (1 to 10 picojoules).
- The Thermodynamic Gap: Modern digital silicon uses roughly 10,000,000$ to 100,000,000 times more energy per mathematical operation than the Landauer limit requires.
- The Biological Benchmark: Evolution found a middle ground. The human brain runs approximately 10^16 synaptic operations per second on roughly 20 Watts of chemical power—operating roughly 10,000 to 100,000 times more efficiently than modern GPU clusters performing equivalent perceptual/reasoning tasks.
Thermodynamic Floor (Landauer): ~10^(-19) J per operation
Human Brain (Synaptic Event): ~10^(-15) J per operation (~10,000x above physics limit)
Modern AI GPU (FP8/FP16 MAC): ~10^(-12) J per operation (~10,000,000x above physics limit)
We are nowhere near the laws of thermodynamics; we are running into the engineering limits of synchronous CMOS logic and Von Neumann architectures.
3. Why Is Current AI So Thermodynamically Wasteful?
The reason AI consumes massive amounts of power stems from three engineering realities:
- Capacitive Charging Over Resistance (CV^2 Losses): Digital chips store bits as physical electron charges on microscopic metal lines and transistor gates. Charging and discharging these capacitors billions of times a second converts almost all the electrical energy directly into waste heat.
- The "Von Neumann" Travel Cost: In deep learning, moving 16 bits of data from off-chip DRAM across copper traces to the compute ALU takes hundreds of times more energy than the math itself.
- Continuous Recomputation: As you noted, the current paradigm treats intelligence as static weight matrices. If something changes or a new query arrives, the entire network must evaluate billions of parameters sequentially from scratch. It is a memoryless, brute-force state machine.
4. Alternative Theoretical Paths to the Same AI Goals
Researchers are actively exploring computing paradigms that bypass digital CMOS logic to approach thermodynamic efficiency:
A. Analog Neuromorphic / In-Memory Computing
Instead of translating numbers into binary 1s and 0s and toggling digital gates, analog arrays store weights as physical conductance (G) in resistive elements (memristors or phase-change memory).
- By Ohm’s Law (I = V x G) and Kirchhoff’s Current Law (sum I = 0$, multiplying an input by a weight and summing them across an entire column happens instantaneously via physical electrical flow, with no memory movement and near-zero bit erasures.
- This mimics biological synapses and operates at pico-to-femtojoule efficiencies.
B. Reversible Computing
If information is never erased, Landauer's bound dictates that energy dissipation can theoretically approach
zero.
- Reversible logic gates (like Fredkin or Toffoli gates) preserve all input states in the outputs.
- In neural networks, linear matrix multiplications (W dot x) are mathematically bijective if invertible, meaning they could theoretically run reversibly with zero energy cost. Only non-linear activation functions (like ReLU) that collapse negative values to zero represent true entropy-increasing erasures.
C. Thermodynamic / Physical Computing (Extremum Principles)
Instead of executing algorithms on digital logic, build a physical system whose native, natural relaxation to thermal equilibrium
is the answer to the mathematical problem.
- Systems like Ising machines, optical parametric oscillators, or passive analog resistor networks find global energy minima naturally via the Second Law of Thermodynamics.
- The system doesn't "compute" the order; physics forces the electrons or photons to settle into the lowest energy configuration, solving complex combinatorial optimization or sampling tasks in nanoseconds using milliwatts.
D. Event-Driven "Spiking" Networks
The brain doesn't recalculate its entire connection matrix every millisecond. Neurons sit completely dark and draw almost zero power until an event triggers an action potential (a "spike"). By contrast, a 70B parameter LLM activates virtually all its parameters to predict even a single punctuation mark. Transitioning to sparse, asynchronous, event-driven networks eliminates continuous energy burn.
The Reality Check
The reason trillions of dollars are being poured into gigawatt datacenter clusters using traditional chips—despite this massive efficiency gap—is
programmability and manufacturing scale.
Silicon CMOS, photolithography, and the CUDA software stack represent sixty years of industrial optimization. We know how to print billions of digital transistors with near-zero defects, and we know how to write software for them.
The physical alternatives (analog memristors, reversible processors, and optical computing) are orders of magnitude more thermodynamically sound, but they suffer from analog drift, noise, manufacturing inconsistency, and a complete lack of mature software compilers. The industry is currently taking the path of maximum financial brute force because our software tools understand digital logic, even as physics makes clear that a far more elegant path exists.
